Схема и сервис мануал телевизоров PHILIPS 42PFL8404H/60
Файл в формате PDF на английском языкеШасси Q548.1E LA
Table of contents
- 1. Revision List
- 2. Technical Specifications and Connections
- 3. Precautions, Notes, and Abbreviation List
- 4. Mechanical Instructions
- 5. Service Modes, Error Codes, and Fault Finding
- 6. Alignments
- 7. Circuit Descriptions
- 8. IC Data Sheets
- 9. Block Diagrams
- Wiring Diagram 32" (Frame)
- Wiring Diagram 37" (Roadrunner)
- Wiring Diagram 42" (Frame/Roadrunner)
- Wiring Diagram 47" (Frame / Roadrunner)
- Wiring Diagram 52" (Frame)
- Block Diagram Video
- Block Diagram Audio
- Block Diagram Control & Clock Signals
- Block Diagram I2C Inter-Integrated Circuit; Последовательная асимметричная шина для связи между интегральными схемами. Использует линии связи (SDA и SCL)
- Supply Lines Overview
- 10. Circuit Diagrams and PWB Layouts Drawing
- Interface Ambilight + Single DC-DC (AB1)
- Interface Ambilight Dual DC-DC (AB2)
- Interface Ambilight Microcontrollerblock (AB3)
- 6 LED Ambilight Microcontroller
- 8 LED Ambilight Microcontroller
- 10 LED Ambilight Microcontroller
- 12 LED Ambilight Microcontroller
- SSB: DC/DC +3V3 +1V2 (B01A)
- SSB: DC/DC +3V3 +1V2 Standby (B01B)
- SSB: Front End (B02A)
- SSB: PNX8543 - Power (B03A)
- SSB: PNX8543 - Video/LVDS Out
- (B03B) 96 127
- SSB: PNX8543 Audio Amplifier (B03C)
- SSB: PNX8543 Audio (B03D)
- SSB: PNX8543 Analog AV (B03E)
- SSB: PNX8543 SDRAM (B03F)
- SSB: PNX8543 Control MIPS/Flash/PCI (B03G)
- SSB: PNX8543 Standby Control/Debug (B03H)
- SSB: Bolt-on (Pt. no. 1) (B04A)
- SSB: Bolt-on (Pt. no. 3) (B04A)
- SSB: Analog IO - Scart 1 & 2 (Pt. no. 1) (B04B)
- SSB: Analog IO - Scart 1 & 2 (Pt. no. 3) (B04B)
- SSB: YPbPr / Side I/O / S-video (B04C)
- SSB: HDMI (B05A)
- SSB: Ethernet (Pt. no. 1) (B05B)
- SSB: Ethernet (Pt. no. 3) (B05B)
- SSB: PCMCIA (B05C)
- SSB: Class-D (B06A)
- SSB: Display Interface (Common) (B07A)
- SSB: Display Supply (Pt. no. 1) (B07B)
- SSB: Display Supply (Pt. no. 3) (B07B)
- SSB: PNX5100 - Power (B08A)
- SSB: PNX5100 - SDRAM (B08B)
- SSB: PNX5100-Ctrl/PCI/Debug (Pt. no. 1)(B08C)
- SSB: PNX5100-Ctrl/PCI/Debug (Pt. no. 3)(B08C)
- SSB: PNX5100 - LVDS In/Out (B08D)
- SSB: PNX5100 - AmbiLight (B08E)
- SSB: SRP List Explanation
- SSB: SRP List Part 1 (Pt. no. 1)
- SSB: SRP List Part 2 (Pt. no. 1)
- SSB: SRP List Part 1 (Pt. no. 3)
- SSB: SRP List Part 2 (Pt. no. 3)
Фото основной платы PHILIPS 42PFL8404H/60 шасси Q548.1E
- Main Board: 3139_123_64423V2
- Chassis: Q548.1E LA
- LCD Panel: LC420WUF-SBN1 code 183 p/n: 932226646682
- PWM Inverter: DAA003A, DDA002B
- Power Supply (PSU): DPS-298CP -4A
- PWM Power: 1606B (PFC), 3BS3LJ (PWM 8pin), DDA005 (6), DDA002B (PWM 20 pin)
- IC MainBoard: PNX8539EH24182 LAN9420-NU
- Tuner: HD1816AF/BHXP
Основная плата 3139-123-64423V2 (Q548.1E LA) может применяться в телевизорах:
- PHILIPS 32PFL7864H/60 (Panel LC320WUF-SBN1)
- PHILIPS 32PFL8404H/60 (Panel LC320WUF (SB)(N1) code 181 p/n: 932226687682)
- PHILIPS 37PFL8404H/60 (Panel T370HW03 V.2 code 189)
- PHILIPS 42PFL7674H/60 (Panel LC420WUF(SB)(N1))
- PHILIPS 42PFL7864
- PHILIPS 42PFL8404H/60 (Panel LC420WUF-SBN1 code 183 p/n: 932226646682).
- и других
Информация Ремонт ТВ PHILIPS Программный ремонт Ремонт блока питания Шасси телевизора Ссылки на схемы
samsung ue40eh5000wСвою прикладываем. сначала он не работал Короткое замыкание есть вольтарен поднял Короткое замыкание ушел после другой вольтарен я положил когда экран открыт так показываетalıdjan
SkyWorth 40E2AS mainboard 5851-A7NT12T-0P00 Ищу Схему TVС проца BL_ON/OFF Благодарю ) а все же полной схемы нет ?81beastie
Схема Тв Samsung, модель: ue46d5000pw, шасси: U57aсхему BN44-00422A Power Supply / схему BN44-00421A Power Supplyrparmas
найти схемы SMPS MINT1400 PCB 02-36230-2371-3 SL POWER ELECTRONICSнайти схемы за SMPS 24V 10A SL POWER ELECTRONICS модели MINT1400A2410L01, за Stille ImagiQ2 Главная плата: 02-36230-2371-3 SL POWER ELECTRONICS Плата управления: 02-36230-4272-3 SL POWER ELECTRONICSrparmas
Автомобильный видеорегистратор Prestigio RoadRunner 450gpsdl. Нужен дампИщу дамп с qh32bh1g на автомобильный видеорегистратор Prestigio RoadRunner 450GPSDLDUMOV
