yaroch Участник Сообщения: 110
Всем знатокам частотников привет!
Нужно настроить частотник Altivar ATV31 H075M2.
Проблем никаких, если бы предыдущий коллега не установил код блокировки.
То есть, SUP- Cod- On.
Теперь можно только посмотреть параметры в меню SUP-, Остальные меню недоступны.
P.S. Исходно проблема стоит в том, чтобы поднять рабочую частоту.
Спасибо за подсказку!
IMG_20180113_165257.jpg 84,37 КБ Скачано: 43 раз(а)
o_l_e_g Предупреждений: 1 Сообщения: 4090
| Цитата: | FCS Return to factory settings/restore configuration
(1)
nO
nO: Function inactive
rECI: The current configuration becomes identical to the backup configuration previously saved by
SCS = StrI. rECI is only visible if the backup has been carried out. FCS automatically changes to nO as soon
as this action has been performed.
InI: The current configuration is replaced by the configuration selected by parameter CFG (2). FCS
automatically changes to nO as soon as this action has been performed.
• If the remote terminal option is connected to the drive, the following additional selection options appear,
as long as the corresponding files have been loaded in the remote terminal's EEPROM memory (0 to 4
files): FIL1, FIL2, FIL3, FIL4. They enable the current configuration to be replaced with one
of the 4 configurations which may be loaded on the remote terminal.
FCS automatically changes to nO as soon as this action has been performed.
Caution: If nAd appears on the display briefly once the parameter has switched to nO, this means that
the configuration transfer is not possible and has not been performed (different drive ratings for example).
If ntr appears on the display briefly once the parameter has switched to nO, this means that a
configuration transfer error has occurred and the factory settings must be restored using InI.
In both cases, check the configuration to be transferred before trying again.
For rECI, InI and FL1 to FL4 to be taken into account, the ENT key must be held down for 2 s. |
Делается записав на бумажку все остальные параметры.
| Цитата: | Assigning LAC to L3 will restore the factory settings of the Fr1 (below), Cd1 (page 39),
CHCF (page 39), and tCC (page 27) parameters. The latter is forced to "2C" on ATV31pppA.
L3 can only be restored to L2 or L1 and L2 to L1 by means of a "factory setting" via FCS
(page 41). |
В конце концов, начинайте с чтения мануалов, а не постов на форумах!  |
Спасибо, с них всегда и начинаю с любых непонятных случаях.
Просто, захотелось пообщаться с коллегами)
Короче если по русски, заходим в FCS, выбираем INI, и жмём 2 сек Enter.
Спасибо, и с наступающим очередным) |
kratmel Участник Сообщения: 316
По инфе от самого шнейдера
The master password in order to unlock the Altivar 31 Drive is 6969.
This code overrides and resets the set password |
О, спасибо за ценнуюю инфу!  |
o_l_e_g, спасибо за выдержку из инструкции но она не помогла по причине написания топика - данное меню заблокировано...
kratmel, пароль сбросил, настроил, всё работает, спасибо!!! |
