Сервис мануал и схема ТВ на шасси SIS231C1CI, main board T.SIS231.T76
Файл в формате PDF на английским языкеОсновная плата T.SIS231.T76 может использоваться в телевизорах:
- HAIER LE50B7000TF
- HAIER LE29G690C
- DNS M46DM8
- DNS M50DM8
- MANTA LED5003
- MYSTERY MTV-4223LT2
- и других
CONTENTS
- Chapter 1. General Information
- 1-1. Document Information
- 1-2. General Guidelines
- 1-3. Important Notice
- 1-3-1. Follow the regulations and warnings
- 1-3-2. Be careful to the electrical shock
- 1-3-3. Electro static discharge (ESD)
- 1-3-4. About lead free solder (PbF)
- 1-3-5. Use the genewing parts (specified parts)
- 1-3-6 Safety check after repairment
- 1-3-7. Ordering Spare Parts
- 1-3-8. Photo used in this manual
- 1-4. How to Read this Service Manual
- Using icons
- Chapter 2. Specification
- 2-1. Specification list
- 2-2. External pictures (four faces)
- Chapter 3. Disassemble and Assemble
- 3-1-1. Remove the Stand
- 3-1-2. Remove the Back Cabinet
- 3-1-3. Remove the Mainboard
- 3-1-4. Remove the Power Supply Module
- 3-1-5. Remove the Speaker
- 3-1-6. Remove the Remote Control Board
- 3-1-7. Remove the Key Board
- Chapter 4. Location of Controls and Components
- 4-1. Board Location
- 4-2. Mainboard
- 4-2-1. Function Description
- 4-2-2. Connector definition
- 4-3. Power Supply Module
- 4-3-1. Function Description
- 4-3-2. Connector definition
- 4-4. LCD Panel
- Chapter 5. Installation Instructions
- 5-1. Accessories
- 5-2. External Equipment Connections
- Chapter 6. Operation Instructions
- 6-1. Front Panel Controls
- 6-2. Back Panel Controls
- 6-3. Setting Up Your Remote Control
- Chapter 7. Electrical Parts
- 7-1. Block Diagram
- 7-2. Circuit Diagram
- Chapter 8. Measurements and Adjustments
- 8-1. Service Mode
- 8-1-1.How to enter into Service Mode
- 8-1-2.How to exit
- 8-2. Measurements and Adjustments
- 8-2-1. The Main Menu
- 8-2-2. General Setting
- 8-2-3. Picture
- 8-2-4. Sound
- 8-2-5. Debug
- 8-3. Software Update
- Chapter 9. Trouble shooting
- 9-1. Simple check
- 9-2. Mainboard IC Introduction
- 9-3. Mainboard Failure Check
- 9-4. Pannel Failure
Информация Ремонт ТВ HAIER Программный ремонт Ремонт блока питания Шасси телевизора Ссылки на схемы
Ищу схему телевизора Mystery MTV720Спасибо, но вроде как процессор другой. Требуется MST720-A-LF и звук TDA7052AйегреС
Liberton 24AS1HDTA1нужна прошивка через usbfgggffc, так ты пройди регистрацию там и тебе сразу 50 баллов как бонус, а за скачивание 2 балла снимают. Вроде как никаких там проблем нету даже если ты из Гондураса.tutu7
Аудиоресивер Pioneer VSX-420 прошивка CPUИщу прошивку процессора M3030RFEPFP. Можно на коммерческой основе. Шить есть чем.Black Raven
HOFFMANN 49F3200F прошивкаТак здесь его и нету. Похоже это не андроид. Есть такая же плата, с такойже проблемой. Подскажите какой раздел залить в дамп донора, что бы тв запустился. На андроиде менял mpool и mboot и все работает. А здесь не знаю.jcai
ERGO 43CU6500AK прошивка по USBHamber 43HRP8508 LDM538A HV430QUB-H11 Тоже перебрал цвета - касяк в шлейфе, контакты вклеены со смещениемVolich
Sony KE65A8, шасси GN6UR, ищу прошивку Tcon EMMC U3 KLM4G1FETE-B041Пока не смотрел, он вроде не криптованный, По шапке в начале сравнивал, страниц 10 совпадает.Soleg_1
