Сервис мануал и схема ТВ на шасси HLT57EJ, main board JUC7.820.00143963
Файл в формате PDF на английским языкеОсновная плата JUC7.820.00143963 может использоваться в телевизорах:
- DEXP F24B7000C
- DEXP F22B7200C
- SUPRA STV-LC24T440WL
- ERISSON 32LEC2500
- CHANGHONG LED50D3000ISX
- и других
CATALOG
- Chapter 1 Safety and notes
- 1-1 Installation notes
- 1-2 Attention points of operation and using
- 1-3 Storage notes
- 1-4 Dismantling notes
- 1-5 High-voltage warning
- Chapter 2 whole machine standard and terminal functions
- 2-1 Basic standard
- 2-2 Introduction of terminals(practicality photos)
- Chapter 3 Main chip functions and the introductions of power supply
- 3-1 Main IC and functions of HLT57EJ
- 3-2 Pin function description of HTL57EJ chip
- 3-2-1 9206B recommended operating power conditons
- 3-2-2 Pin function of DMI21-C8I2RH(JUB2.891.367-1) tuner
- 3-2-3 GD25Q64CSIG 64Mbit (8M x 8bit) brief introduction
- 4-1 9206B Power Block Diagram
- 4-2 Power supply system
- 4-2-1 Pin voltage of the voltage adjustor on the mainboard
- 4-2-3 Interface definition
- 4-3 The waveform of key points
- Chapter 5 Software upgrade instructions
- 5-1 UART Upgrade
- 5.2 USB Upgrade
- Chapter6: Classical accident maintenance procedures and examples
- 6-1 The thinking of don’t boot
- 6-2 Common problems for your reference
- Chapter 7 High voltage and high current wearing parts list
- Chapter 8 Factory mode parameter setting instructions and notes
- 8-1 Enter into the factory mode
- 8-2 Setting method of factory menu
Информация Ремонт ТВ CHINA TV Программный ремонт Ремонт блока питания Шасси телевизора Ссылки на схемы
Liberton 24AS1HDTA1нужна прошивка через usbBARTONUA,Тут тоже есть: https://remont-aud.net/dump/lcd_pdp_tv/liberton/liberton_24as1hdta1_shassi_main_board_hkt_rt2831p531/365-1-0-127535vlad08
BBK 39LEX-5026/T2C замена MainBoard CV338H-T42??? клыент Пробуй - https://drive.google.com/file/d/1_z4vX7j6ZMwMDoT3Ns1dVKpFcjVsabqW/view?usp=sharing ссылка не вечна. Остальное вопросы в личку за наличные.И90
HOFFMANN 49F3200F прошивкаТак здесь его и нету. Похоже это не андроид. Есть такая же плата, с такойже проблемой. Подскажите какой раздел залить в дамп донора, что бы тв запустился. На андроиде менял mpool и mboot и все работает. А здесь не знаю.jcai
ERGO 43CU6500AK прошивка по USBHamber 43HRP8508 LDM538A HV430QUB-H11 Тоже перебрал цвета - касяк в шлейфе, контакты вклеены со смещениемVolich
Sony KE65A8, шасси GN6UR, ищу прошивку Tcon EMMC U3 KLM4G1FETE-B041Пока не смотрел, он вроде не криптованный, По шапке в начале сравнивал, страниц 10 совпадает.Soleg_1
