- Производитель
- Macronix International Co., Ltd
DataSheet MX25L8035E
8M-BIT [x 1/x 2/x 4] CMOS SERIAL FLASHGENERAL
- Serial Peripheral Interface compatible -- Mode 0 and Mode 3
- 8M:8,388,608 x 1 bit structure or 4,194,304 x 2 bits (two I/O read mode) structure or 2,097,152 x 4 bits (four I/O read mode) structure
- 256 Equal Sectors with 4K byte each
- - Any Sector can be erased individually
- 16 Equal Blocks with 64K byte each
- - Any Block can be erased individually
- Single Power Supply Operation
- - 2.7 to 3.6 volt for read, erase, and program operations
- Latch-up protected to 100mA from -1V to Vcc +1V
PERFORMANCE
- High Performance
- - Fast read
- - 1 I/O: 108MHz with 8 dummy cycles
- - 2 I/O: 80MHz (2.7V~3.6V) ; 104MHz (3.0V~3.6V) with 4 dummy cycles
- - 4 I/O: 108MHz with 6 dummy cycles
- - Fast access time: 108MHz serial clock
- - Serial clock of two I/O read mode : 80MHz (2.7V~3.6V); 104MHz (3.0V~3.6V)
- - Serial clock of four I/O read mode : 108MHz, which is equivalent to 432MHz
- - Fast program time: 0.7ms(typ.) and 3ms(max.)/page (256-byte per page)
- - Byte program time: 9us (typical)
- - Fast erase time: 60ms (typ.)/sector (4K-byte per sector) ; 0.4s(typ.) /block (64K-byte per block); 3s(typ.) /chip
- Low Power Consumption
- - Low active read current: 25mA(max.) at 108MHz, and 10mA(max.) at 50MHz
- - Low active programming current: 20mA (max.)
- - Low active erase current: 20mA (max.)
- - Low standby current: 20uA (typ.) ; 50uA (max.)
- - Deep power-down current: 3uA (typ.) ; 20uA (max.)
- Minimum 100,000 erase/program
AOC 32m3080/60s майн msd3663m2c1 ищу прошивку U204https://remont-aud.net/dump/lcd_pdp_tv/prochee/aoc_32m3080_60s_shassi_main_board_msd3663m2c1/248-1-0-77922 Грел чё нибудь ? Обычно есть дежурка ,но из неё не включаетсяMMMMAX
Samsung PS50C6970, PDP - S50FH-YB07 ищу прошивку лоджика.Ищу прошивку SPI на ложик LJ41-08481A, model - 50US2, Rev - R1.2 (10.03.30) на шильдике - 50"US2 945Eh 100416 SEC 3D Нет выхода сигнала Yfr, подкидывал прошивку с D серии появляется сигнал, но меняется распиновка выходов на игрек с лоджика.Shef
Прошивка на LEFF 43U540S / Yandex TBЗдравствуйте. Необходима прошивка на телевизор LEFF 43U540S / Yandex TB. Висит на заставке Yandex/ Есть прошивка которая полностью подходит Liberton 43AS1UHDTA1.5 TP.SK706S.PC822 HV430QUB-N1A , но это Android с логотипом Liberton и НЕ ПОДХОДИТ ПУЛЬТ!!!Arlo
Lg 43LF590V Emmc FileПривет друзья У меня есть необходимость Файл дампа EMMC Светодиодный телевизор в режиме ожидания благодарю васrtn16979
