- Производитель
- Macronix International
DataSheet 25L6445E; MX25L6445E; MX25L6445
64M-BIT [x 1/x 2/x 4] CMOS MXSMIOTM (SERIAL MULTI I/O) FLASH MEMORYGENERAL
- Serial Peripheral Interface compatible -- Mode 0 and Mode 3
- 64Mb: 67,108,864 x 1 bit structure or 33,554,432 x 2 bits (two I/O mode) structure or 16,777,216 x 4 bits (four I/O mode) structure
- 2048 Equal Sectors with 4K bytes each
- - Any Sector can be erased individually
- 256 Equal Blocks with 32K bytes each
- - Any Block can be erased individually
- 128 Equal Blocks with 64K bytes each
- Power Supply Operation
- - 2.7 to 3.6 volt for read, erase, and program operations
- Latch-up protected to 100mA from -1V to Vcc +1V
PERFORMANCE
- High Performance
- VCC = 2.7~3.6V
- - Normal read
- - 50MHz
- - Fast read (Normal Serial Mode)
- - 1 I/O: 104MHz with 8 dummy cycles
- - 2 I/O: 70MHz with 4 dummy cycles
- - 4 I/O: 70MHz with 6 dummy cycles
- - Fast read (Double Transfer Rate Mode)
- - 1 I/O: 50MHz with 6 dummy cycles
- - 2 I/O: 50MHz with 6 dummy cycles
- - 4 I/O: 50MHz with 8 dummy cycles
- - Fast program time: 1.4ms(typ.) and 5ms(max.)/page (256-byte per page)
- - Byte program time: 9us (typical)
- - Continuously Program mode (automatically increase address under word program mode)
- - Fast erase time: 60ms (typ.)/sector (4K-byte per sector) ; 0.7s(typ.) /block (64K-byte per block); 50s(typ.) /chip
- Low Power Consumption
- - Low active read current: 19mA(max.) at 104MHz, 15mA(max.) at 66MHz and 10mA(max.) at 33MHz
- - Low active programming current: 25mA (max.)
- - Low active erase current: 25mA (max.)
- - Low standby current: 50uA (max.)
- - Deep power down current: 20uA (max.)
- Typical 100,000 erase/program cycles
- 20 years data retention
Витязь 43LU1204 Прошивка USBСаша, ну глаз могу лечить или ещё что, я много что умею, на рыбках тренировался. Маг короче Старый становлюсь. Не все сразу понял. :pray:ФАРТ
BQ 58fsu32b завис на логотипеBq58fsu32b. main hk.t.rt 2851v09. в интернете ни чего не могу найти. может кто то сливал дамп? покажи свой слитый дамп , тогда сможем помочь ... 1656213188 тв в сервисе. (горе мастера не могут его сделать, видимо сервис не айс). дамп еще не сливал.spybot888
Нужна прошивка на духовой шкаф whirlpool , Mod:AKZ444 ,service 10Всем привет! Помогите с прошивкой на духовой шкаф AKZ444 servese 10Сергей ж
UE32D6510WSXRU BN41-01587E версия 1018.0 прошивкаПрошивка 100%. ТВ поступил с отсутствием звука, слегка погрел феном проц, звук появился. Проц заменён на новый. Теперь выключается через 30 сек. Похоже, пока менял проц, вышла из строя EMMC, не читается.Sergey_S
Решено SAMSUNG LE26C350D1W помощь в прошивке ONE NAND IC1201 KFG1G16U2DВ общем наверное MMMMAX прав,но у меня нет опыта(то есть есть,но отрицательный) по реболу процессоров. Сегодня раза три нормально включился,потом стал включаться ,но без изображения. Затем только отмаргиванием светодиода 6 раз без изо и звука. Клиент купит новый тв.nail--72
