STR2A153D; 2A153D | DataSheet микросхем (PDF)
top
  • , DataSheet STR2A153D; 2A153D - Power ICs for switching power supplies
Производитель
Sanken
DataSheet STR2A153D; 2A153D​
Power ICs for switching power supplies, incorporating a power MOSFET and a current mode PWM controller IC in one package (STR2A100 series)
  • DIP8 package, connecting one side (pin5 to pin8) with a power MOSFET drain.
  • The distance between high voltage terminal and low voltage terminal is 0.762mm (0.3inches), and the wider drain trace is available to enhance thermal dissipation of the IC.
  • Current Mode PWM control
  • Built-in Random Switching Function, reducing EMI noise, and simplifying EMI filters, by the slight random change of PWM frequency, fOSC.
  • Auto Standby Function (Input Power, PIN
  • Normal load operation - PWM mode
  • Light load operation - Standby mode (Burst oscillation)
  • Built-in Audible Noise Suppression Function for standby mode
  • Built-in Startup Circuit, reducing power consumption in standby operation, and eliminating external components.
  • Bias Assist Function, improving startup operation, suppressing VCC voltage drop in operation, and allowing use of smaller VCC capacitor.
  • Soft Start Function, reducing stress of a power MOSFET and secondary rectifiers at startup
  • Built-in Leading Edge Blanking Function
  • Built-in Slope Compensation Function, avoiding subharmonic oscillation.
  • Two Chip Structure, with a controller and a power MOSFET guaranteed Avalanche Energy which is available to simplify surge absorber circuits
  • Какой аналог у STR2A153D; 2A153D?
    Списки аналогов находятся в разделе форума, в отдельных темах. Если Вы не нашли чем заменить STR2A153D; 2A153D, создайте свою тему с вопросом.
  • Чем заменить STR2A153D; 2A153D?
  • Какие параметры STR2A153D; 2A153D?
  • Схема включения STR2A153D; 2A153D
    В зависимости от типа аппарата в котором используется электронный компонент возможны различные схемы включения STR2A153D; 2A153D.
  • Как проверить STR2A153D; 2A153D?
  • Какая маркировка STR2A153D; 2A153D?
  • Где купить STR2A153D; 2A153D?
Behringer
Скачивания
182
Посмотрено
3.162
Первый выпуск
Обновление
Рейтинг
Оценок: 0
Другие файлы Behringer
  • TO-252
    DataSheet на корпус TO-252 (TO252) Размеры (мм) Чертеж Спецификация
  • SSOP-8
    DataSheet на корпус SSOP-8 (SSOP8) Размеры (мм) Чертеж Спецификация
  • MSOP-8
    DataSheet на корпус MSOP-8 (MSOP8) Размеры (мм) Чертеж Спецификация
  • TO-220F-3
    DataSheet на корпус TO-220F-3; TO220F Размеры (мм) Чертеж Спецификация
  • DIP-8
    DataSheet на корпус DIP-8; DIP8 Размеры (мм) Чертеж Спецификация
  • SOP-8 208-mil
    DataSheet на корпус SOP-8; SOP8 208-mil Размеры (мм) Чертеж Спецификация Обратите внимание на другой, "узкий" корпус - SOP-8 150-mil
  • SOP-8 150-mil
    DataSheet на корпус SOP-8; SOP8 150mil Размеры (мм) Чертеж Спецификация Обратите внимание на другой, "широкий" корпус - SOP-8 208-mil
  • SOT89-5
    DataSheet на корпус SOT89-5; SOT-89-5 Размеры (мм) Чертеж Спецификация
  • SOT23-5
    DataSheet на корпус SOT23-5; SOT-23-5 Размеры (мм) Чертеж Спецификация
  • SOT23-6
    DataSheet на корпус SOT23-6 (SOT-23-6) Размеры (мм) Чертеж Спецификация
  • YD1517; YD1517P
    DataSheet YD1517; YD1517P 2 x 6 W Stereo Power Amplifier Requires very few external components High output power Fixed gain Good ripple rejection Mute/stand-by switch Load dump protection AC and...
  • 25L6445E; MX25L6445E; MX25L6445
    DataSheet 25L6445E; MX25L6445E; MX25L6445 64M-BIT [x 1/x 2/x 4] CMOS MXSMIOTM (SERIAL MULTI I/O) FLASH MEMORY GENERAL Serial Peripheral Interface compatible -- Mode 0 and Mode 3 64Mb: 67,108,864...
  • 24C64; AT24C64
    DataSheet 24C64; AT24C64 64Kbit 2-Wire Serial EEPROM Low-Voltage and Standard-Voltage Operation 2.7 (VCC = 2.7V to 5.5V) 1.8 (VCC = 1.8V to 5.5V) Low-Power Devices (ISB = 2 ?A at 5.5V) Available...
  • Samsung NP-RV508-A02RU
    Прошивка BIOS ноутбука Samsung NP-RV508-A02RU
  • ASUS X550C (X550CC REV 2.0)
    Прошивка BIOS ноутбука ASUS X550C (X550CC REV 2.0) SPI Flash: 25Q64
Поделиться ссылкой на файл
