Сервисный мануал и схема телевизоров SAMSUNG UE32F6400AW - UE75F6400AW
Файл в формате PDF на английском языкеМодели:
- SAMSUNG UE32F6400AW
- SAMSUNG UE40F6400AW
- SAMSUNG UE46F6400AW
- SAMSUNG UE55F6400AW
- SAMSUNG UE50F6400AW
- SAMSUNG UE65F6400AW
- SAMSUNG UE75F6400AW
Содержание:
- 1. Precautions
- 1-1. Safety Precautions
- 1-1-1. Warnings
- 1-1-2. Servicing the LED TV
- 1-1-3. Fire and Shock Hazard
- 1-1-4. Product Safety Notices
- 1-2. Servicing Precautions
- 1-2-1. General Servicing Precautions
- 1-3. Static Electricity Precautions
- 1-4. Installation Precautions
- 2. Product Specifications
- 2-1. Product information
- 2-2. Product specification
- 2-2-1. Product specification
- 2-2-2. Feature & Specifications
- 2-3. Accessories
- 2-4. Viewing the Functions
- 2-4-1. Auto Motion Plus 120 Hz
- 2-4-2. Supported Formats
- 2-4-3. Smart Control
- 2-4-4. IR Blaster
- 2-4-5. SMART Interaction (The camera is sold separately.)
- 2-4-6. SMART HUB
- 2-4-7. 3D Display
- 3. Disassembly and Reassembly
- 3-1. Disassembly and Reassembly
- 3-1-1. LED TV
- 3-1-2. ASSY BOARD P-RF-MODULE
- 3-1-3. NETWORK
- 4. Troubleshooting
- 4-1. Troubleshooting
- 4-1-1. Previous Check
- 4-1-2. Simple flow chart of malfunction
- 4-2. How to Check Fault Symptom
- 4-2-1. NO Power
- 4-2-2. No Video (HDMI 1, 2, 3, 4 - Digital Signal)
- 4-2-3. No Video (Tuner_CVBS)
- 4-2-4. No Vido (Tuner DTV)
- 4-2-5. No Video (Video AV)
- 4-2-6. No Video (COMPONENT)
- 4-2-7. No Sound (1.Speaker 2.Monitor_out 3.Optical)
- 4-3. Factory Mode Adjustments
- 4-3-1. Detail Factory Option
- 4-3-2. Entering Factory Mode
- 4-3-3. Factory Data
- 4-4. White Balance
- 4-4-1. Calibration
- 4-4-2. Service Adjustment
- 4-4-3. Adjustment
- 4-5. RS-232C
- 4-6. AV Control Tabe
- 4-7. Software Upgrade
- 4-7-1. How to Check the Software Version
- 4-7-2. How to Upgade Software
- 5. Wiring Diagram
- 5-1. Wiring Diagram
- 5-2. Connector
- 5-3. Connector Functions
- Main Board: BN41-01958A BN94-06704D
- Chassis: U85A
- LED backlight: D2GE-460SCA-R3, D2GE-460SCB-R3
- T-CON: BN41-01938B LSF460HN02
- LED driver (backlight): integrated into PSU
- Power Supply (PSU): BN44-00611A PSLF141S05A
- CPU: SEMS30
- SPI FLASH: W25Q40
- SDRAM: K4B2G1646E
Информация Ремонт ТВ SAMSUNG Программный ремонт Ремонт блока питания Шасси телевизора Ссылки на схемы
Hyundai H-LED32ET4100 main JUC7.820.00208835 Нужна прошивка LCDнарод тупо сливал не выложив состояния статус-регистров Они влияют на результат чтения программатором?artur008
tv Samsung ue65ks9002t нужна прошивка 25q80 ic804http://televid-sib.ru/index.php?topic=26680.msg179216#msg179216 https://remont-aud.net/dump/lcd_pdp_tv/samsung/samsung_ue55ks9000txxe_shassi_main_board_bn41_02504a_jazz_m_usit/241-1-0-94951artur008
Telefunken TF-LED43S05T2SU Ищу USB обновление длядоброго времени суток уважаемые. имею спросить следующее: TELEFUNKEN TF-LED43S05T2SU маин HK.T.RT2871P738 панель ST4251D01-7 заменил плату на аналогичную но от Hyundai H-LED43EU7001 залил прошивку...Polo
SUPRA STV-LC60GT5000U Ищу файл прошивки для панели V580DJ4-QE1 Rev.T4В сервисном меню нашел , что тип панели меняется через загрузку файла панели по USB. Factory menu--->Other--->Project ID ? Отвечаю. В сервисном меню пункта Other нет. Есть строка PID - 9K04G000S000003AndreySk
Решено UPS FSP EP1500 (ppf9000105) требуется схемаОт FSP тоже ответа нет, тему придётся закрыть.AZrx
SHARP LC60LE822ERU Ищу прошивку на телевизорИщу прошивку на телевизор LC60LE822ERU (майн DKEYDF455FM07)родную потеряли в прежнем месте ремонта, залили с SHARP_LC-40LE810E не включается. Пытался найти родной майн DKEYDF455FM07 не удачно.Генерал
