PHILIPS 32PFL3258T/60 (Service Manual) | Схема телевизора
  • , Сервисный мануал и схема телевизора PHILIPS 32PFL3258T/60
Сервис мануал и схема телевизора PHILIPS 32PFL3258T/60​
Какой сервис мануал и схема телевизора PHILIPS 32PFL3258T/60
Содержание:
  • 1. Revision List 2
  • 2. Technical Specs, Diversity, and Connections 2
  • 3. Precautions, Notes, and Abbreviation List 8
  • 4. Mechanical Instructions 12
  • 5. Service Modes, Error Codes, and Fault Finding 30
  • 6. Alignments 40
  • 7. Circuit Descriptions 44
  • 8. IC Data Sheets 50
  • 9. Block Diagrams
  • Wiring diagram 3000 series 32" 61
  • Wiring diagram 3200 series 32" 62
  • Wiring diagram 4200 series 32" 63
  • Wiring diagram 4300 series 32" 64
  • Wiring diagram 4500 series 32" 65
  • Wiring diagram 5000 series 32" 66
  • Wiring diagram 3200 series 39" 80
  • Wiring diagram 4200 series 39" 67
  • Wiring diagram 4300 series 40" 68
  • Wiring diagram 4400 & 4500 series 40" 69
  • Wiring diagram 3200 series 42" 70
  • Wiring diagram 4200 series 42" 71
  • Wiring diagram 5000 series 42" 72
  • Wiring diagram 3000 series 40"- 46" 73
  • Wiring diagram 3200 series 46" 74
  • Wiring diagram 4200 series 46"-50" 75
  • Wiring diagram 4300 series 46"-55" 76
  • Wiring diagram 4400 & 4500 series 46" 77
  • Wiring diagram 5000 series 47"-50" 78
  • Wiring diagram 4500 series 55" 79
  • Block diagram 3200/4200/4500/5000 series 81
  • Block diagram 3000/4300 series 82
  • 10. Circuit Diagrams and PWB Layouts Drawing PWB
  • A 715G5778 PSU 83 85-86
  • A 715G5787 PSU 87 89-90
  • A 715G5790 PSU 91 93-94
  • A 715G5792 PSU 95 100-101
  • A 715G5793 PSU 102 104-105
  • B 715G5675 SSB 106 119-120
  • B 715G5713 SSB 121 135-136
  • J 715G5762 IR/LED Panel 137 138
  • J 715G5763 IR/LED panel 139 140
  • J 715G5766 IR/LED Panel 141 142
  • J 715G5772 IR/LED Panel 143 144
  • E 715G5771 Keyboard control panel 145 146
  • 11. Styling Sheets
Фото основной платы TPM10.1E LA
Какая основная плата LCD телевизора PHILIPS 32PFL3258T/60 TPM10.1E LA
  • Chassis: TPM10.1E LA
  • LCD Panel: TPT315B5-EUJFFA REV:S1A
  • LED backlight: 31.5 2K13 32PCS-V3 2PGLCTXF8C624-F46
  • T-CON: TVP_LC320EUJ-FFA1_VER 3.0
  • LED driver (backlight): integrated into PSU
  • PWM LED driver: PF7900S, PF7700A
  • Power Supply (PSU): 715G5793-P02-000-002H
  • PWM Power: PF6200 (PWM flyback), NR111D (PWM Step-down)
  • Main Board: 715G5713-M0F-000-005K
  • IC Main Board: CPU: MT5580MPOI; DRAM: H5TQ2G83DFR; NAND Flash: TC58NVG2S3ETAI0; SOUND: STA3818
  • Tuner: TDSY-G230D
  • Control: IR: 715G5772-R01-000-004S
Информация Ремонт ТВ PHILIPS Программный ремонт Ремонт блока питания Шасси телевизора Ссылки на схемы
  • Общая информация
  • Ремонт телевизоров PHILIPS
  • Программный ремонт PHILIPS
  • Ремонт блока питания PHILIPS
  • Шасси в ТВ PHILIPS
  • Не нашли схему ?
Георгий Полищук
Скачивания
7
Посмотрено
589
Первый выпуск
Обновление
Рейтинг
Оценок: 0
Другие файлы Георгий Полищук
  • TELEFUNKEN TF-LED40S6T2
    Прошивка телевизора TELEFUNKEN TF-LED40S6T2 Main Board: CV9202H-TPW LCD Panel: CX400DLEDM SPI FLASH: 25Q64FVSIG Фото основной платы CV9202H-TPW
  • SUPRA STV-LC2395WL
    Прошивка телевизора SUPRA STV-LC2395WL Main Board: 35016539 LCD Panel: LTA230AP01 FLASH: 25FL032 Фото основной платы 35016539
  • THOMSON 24FU5253C
    Прошивка телевизора THOMSON 24FU5253C Main Board: 40-MT31L1-MAF2HD LCD Panel: V240AE1N01-1 SPI Flash: 25Q64 Фото основной платы 40-MT31L1-MAF2HD
  • THOMSON 27MT02E64
    Прошивка телевизора THOMSON 27MT02E64 Main Board: 40-MT02MF-MAA4XG LCD Panel: V270B1-L03 REV.C1 Eeprom: 24C32, 24C08, 24C02 Фото основной платы 40-MT02MF-MAA4XG
  • THOMSON 32M71NH20
    Прошивка телевизора THOMSON 32M71NH20 Main Board: 40-MT01TI-MAD2XG LCD Panel: LC420WX7(SL)(A1) , LK315T3LZ54 IC: ULB800057A Фото основной платы 40-MT01TI-MAD2XG
  • THOMSON T32C30U
    Прошивка телевизора THOMSON T32C30U Main Board: 40-MT27C1-MAC2XG LCD Panel: LVW320CSTM C3 V2 SPI Flash: 25Q32BVSIG Фото основной платы 40-MT31EPA-MAB2HG
  • SAMSUNG UE32F6400AW - UE75F6400AW (Service Manual BN41-01958A)
    Сервисный мануал и схема телевизоров SAMSUNG UE32F6400AW - UE75F6400AW Файл в формате PDF на английском языке Модели: SAMSUNG UE32F6400AW SAMSUNG UE40F6400AW SAMSUNG UE46F6400AW SAMSUNG...
  • SAMSUNG UE46F6100AK (Service manual BN41-01954B)
    Схема LCD телевизора SAMSUNG UE46F6100AK (Service manual BN41-01954B) Main Board: BN41-01954B BN94-07077L Chassis/Version: U88A LCD Panel: CY-HF460CSLV1V T-CON: BN41-01939C LSF460HJ02 LED driver...
  • PHILIPS 46PFL3008T/60 (Service Manual)
    Схема LCD телевизора PHILIPS 46PFL3008T/60 Chassis: TPM10.1E LA LCD Panel: TPT460H1-HM01 Rev-C1J code 195 LED backlight: 46 AD00(72)-078 EVERLIGHT LBM460P0601-AJ-5(HF)(0)...
  • PHILIPS 42PFL4208T/60 (Service Manual)
    Схема LCD телевизора PHILIPS 42PFL4208T/60 Chassis: TPM10.1E LA LCD Panel: TPT420H2-DUJFFE LED backlight: 015B8000-A97-102-6840 V-6840-A97-20 T-CON: 6870C-0452A LED driver (backlight): integrated...
  • PHILIPS 40PFL4308T/60 (Service Manual)
    Схема LCD телевизора PHILIPS 40PFL4308T/60 Chassis: TPM10.1E LA LCD Panel: LTA400HM23 T-CON: DLED400S4LV0.1; LQF6041T0B-Q1, DC/DC SM4152, I7939A LED driver (backlight): SSL400-0D5A Rev:1.0 PWM...
  • PHILIPS 39PFL3208T/60 (Service Manual)
    Схема LCD телевизора PHILIPS 39PFL3208T/60 Chassis: TPM10.1E LA LCD Panel: TPT390J1-HJ1L02 LED driver (backlight): integrated into PSU PWM LED driver: PF7900S (PWM), PF7700A (Current Balance)...
  • PHILIPS 32PFL5008T/60 (Service Manual)
    Схема LCD телевизора PHILIPS 32PFL5008T/60 Chassis: TPM10.1E LA LCD Panel: LC320EUE (FF)(F1) code 189 p/n: 932229831682 LED driver (backlight): integrated into PSU PWM LED driver: PF7900S...
  • PHILIPS 32PFL4208T/60 (Service Manual)
    Схема LCD телевизора PHILIPS 32PFL4208T/60 Chassis: TPM10.1E LA LCD Panel: TPT315B5-DXJSFE LED backlight: LBM320M0904-BC-2(HF)(0) T-CON: 32-37 R0W2.1 HD VER 0.1 6870C-0442B LED driver...
Поделиться ссылкой на файл
