vaso5 Замечательный сотрудник Сообщения: 5920
Со слов клиента были установлены карты GPS, после немного поработал и пошли перегрузы. Думаю прошить, но засада в следующем:
Лог UFSа:
info:
MCU SW : V ICPR82_09w24 12-06-09 RM-469 (c) Nokia
APE Core: 021.013
APE Var : 021.013021.013.01.01021.013.202.01
Prd.Code: 0585050
Bpr.Code: 0565921
Prod.Sn : SEL607706
HW Vers : 6000
APE HW : 256
APE Adsp: 256
EM GAZOO: 40
EM PEARL: 00
RFIC Ver: |Vapaus_5.1 | ???
DSP Vers: ICPR82_09w24_RIO
WLAN Id : C0163BAC86
IMEI : 35хххххххххххх
SL Serv : SIMLOCK SERVER
SL Conf : 244-07-00000000000
SL Prof : 0000000000000000
SL Count: 00 00
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: Nokia Test;Finland
check:
1ST BOOT : C0,07 [Rm-469] [2.0.9.0]
RAPx ID : 000000030000022600010007600C192102011104
EM 1 ID : 00001040
EM 2 ID : 00001030
RAPx PBID : 0B50010C3564034405F2FCDFE900C10DF941B6E4
RAPx MODE : 00
RAPx HASH : 25B977A055BE9B5DEC0C38A2A279C695
RAPx ROID : 3E273BF637BE26FA
CMT 1ST Boot OK
CMT 2ND Bt: RAPUv11_2nd.fg, Ver: 1.37.1
CMT FLID0 : 00200040-00000031, St OneNAND-2G
CMT FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAPUv11_algo_xsr16.fg, Ver: 1.40.0
CMT FLASH DEVICE NOT SUPPORTED by: RAPUv11_algo_xsr16.fg, Ver: 1.40.0
Check Product, Use newer Flash Loader Pack
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
INFO_2ND : APE Chip Absent
INFO_ALG : APE Chip Absent
Rebooting Mobile
а вот JAF:
JAF version 1.98.62
Detected PKEY: 90009699
Card life counter: 99.99%
P-key nokia module version 01.02
Detected UFS_USB V2.8 (c) SarasSoft 2007. version: 01.B1, Driver version: 0, Library version: 0
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 7.0.2.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V ICPR82_09w24
12-06-09
RM-469
(c) Nokia
HW version: 6000
PCI version:
RFIC version:
DSP version:
APE SW Core version: 021.013
APE Variant version: 021.013021.013.01.01021.013.202.01
APE Test version: 0.068
Retu version: 40
Tahvo version: 00
APE HW version: 256
APE ADSP SW version: 256
Production serial number: SEL607706
Product code: 0585050
Module code:
Basic production code: 0565921
Flash code:
Order number:
Product specific data:
Long production SN: 0
ATO:
Default SN type:
IMEI plain: 35ххххххххххххх
IMEI spare to net: 3A 55 12 06 33 46 98 02
IMEI SV to net: 33 55 12 06 33 46 98 12 F2
LOCK STATUS:
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-469.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0585050
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-469\
Searching for default location of ini...
Checking path: \Products\RM-469\
No ini files found...
Done!
Booting phone...
CMT Boot Data:
Asic ID: 000000030000022600010007600C192102011104
Asic Mode ID: 00
Asic EM ID: 00001030
Asic Public ID: 0B50010C3564034405F2FCDFE900C10DF941B6E4
HASH: 25B977A055BE9B5DEC0C38A2A279C69500000000
ROM ID: 3E273BF637BE26FA
Error finding cmt boot file...
я так понимаю, что не поддерживается тип флэши, или я не прав? Что делать? |
voron300 Участник Сообщения: 165
Катать флеш и проц.
Однажды после перекатки тел спокойно прошивался, но не включался, хотя логи были четкие. Еще раз перекатал проц и усё. Получается даже хороший лог не показатель
Добавлено 13-12-2009 08:23
Были клиенты без антены, которые утверждали, что пропала после смены симки, а усилитель вдребезги |
voron300, батенька, Вы почитайте для начало на просторах инета по поводу CMT FLASH DEVICE NOT SUPPORTED by: RAPUv11_algo_xsr16.fg, Ver: 1.40.0
Check Product, Use newer Flash Loader Pack , а потом предлагайте. Проблема встречается не только у меня, и даже на абсолютно рабочих телах.
Добавлено 13-12-2009 20:46
| voron300 писал: | | Катать флеш и проц. Еще раз перекатал проц и усё. |
Интересно, а разве там не бутерброд? В глаза хоть тело видел? |
Vad Мобильщик  Сообщения: 5840
vaso5, Как говорят, что пока его шьет Phoenix по USB. Либо ждем новых лоадеров.
Но, так же много встречается проблем и с самим RAP. |
Vad, про Phoenix я знаю, интересовал вариант UFSа или JAFа. Гдето читал, что вроде решается заливкой лоадеров, но толкового решения так и не нашёл. |
vaso5, Рабочие лоадеры нашел?  |
В том то и дело что нет. Суюту ставил 18 августа. Сейчас заметил что на сапорте файлы обновили наверное, так как дата позже. Попробую переустановить, посмотрим что выйдет. |
Astrakhan Гость 89.179.*.*
Попробуй ломаным MXKey, в принципе если не железо, то должен прошить. |
SS Rottenfuehrer Новичок Сообщения: 4
Попробуй ломаным jafом прошить в dead mode. |
