LUNA 240 Fi - Honeywell CS0167B card - repeated FAN ERROR
mesut
21-03-2016 22:56
I solved the problem today. first thought was right. I changed the relay
Thank you to everyone who tried to help me улыбка
Спасибо всем, кто пытался помочь мне улыбка
Honeywell CS0167B LS control card - BAXI LUNA-240 Fi boiler - repeated fan error. рёв в три ручья
boiler is working normaly when reset or waiting off for a while. But it gives error again after heat water and home one or two times.
i changed the new one the honeywell Presostat but it wasnt help. fan motor is looking good and working. i also lubrication with oil.
when boiler first opened, if fan is working, It sounds a loud sound and no problem. if fan is not working, there is only water pump sound than it waiting and gives fan error two minutes later.
when first times this error appear. I pulled cables of fan and measured the fan voltage on the board.
when boiler opened, a voltage about 100 volt appear for a moment and than disappear immediately.
therefore i didn't think fan faulty.
i opened and not find any faulty component on the control card honeywell CS0167B - LS.
Picture of this model: http://monitor.net.ru/forum/files/honeywell_cs0167b-ls_990.jpg
Connector A2: Pin 5 and 7 belongs to FAN. Pin 6,8,9 belongs to Presostat.
i dont know what can i do. Only think is if there is a relay sound than fan is working. there is 4-5 relay. As i saw one of them is related to fan cables and big one, 48volt FBR161. I refresh solder its and a few more of them. But it wasnt help me again..
I tried to explain as best I can.
this boiler belong to me, mine. I'm trying to fix myself улыбка
I'm electronic technician. i can change part of the motherboard. but of course i don't know exact problem, therefore i wrote here for your help. it seems be relay or something running it.
it isn't fully distorted. it isn't complete works, What could be the problem ?
Gaz
21-03-2016 23:15
mesut писал:
Can you help me, what can I do ?
Locate the service BAXI. I think that in Istanbul it's no problem.
mesut
21-03-2016 23:33
service is not a problem. but why did you write it. are we not do the repair motherboard ?
iner
22-03-2016 00:08
Давай Андрей дерзай ... тебе там через море раз плюнуть в Турцию Луне плату отремонтировать ... гы-гы пускай Новой почтой передаст ... а вообще то прикольно ... границы расширяются аж до Турции ... Мир, Дружба, Жвачка улыбка
Ярошевский Андрей
22-03-2016 00:12
mesut, если вентилятор, при работе, сильно шумит,- скорей всего его нужно ремонтировать, а, правильнее- менять на новый.
попробуй подать на него (вентилятор) питание, отключив от платы.
если он гудит и работает нестабильно - меняй
iner
22-03-2016 00:15
там видно проблема в "работает - не работает" ... вентилятор ... улыбка
Ярошевский Андрей
22-03-2016 00:19
ну и, естественно, проверить- приходит ли на него питание
mesut
22-03-2016 00:34
iner "the boundaries are expanded up to Turkey" . Hi to you from Turkey улыбка
Ярошевский Андрей "if the fan when working, very noisy it is necessary to repair" :
when firs times this error apear. I pulled cables of fan and measured the fan voltage on the board.
when boiler opened, a voltage about 100volt apear for under one second and than disapear.
therefore i didn think fan faulty.
iner
22-03-2016 00:41
тяжкий перевод ... если есть 100 вольт а должно быть 220 ? в Турции за стандарт взято 220 вольт в сети??? если так то копайте с платы ... или в поисковик за готовым решением ...
Добавлено 21-03-2016 23:42
или как писал Андрей в розетку его отдельным проводом ...
Ярошевский Андрей
22-03-2016 00:44
mesut, да, похоже вентилятор не виноват улыбка
ну с платой разбирайся на месте, попробуй заменить реле.
iner
22-03-2016 00:44
mesut, а вы кто по жизни? профессионально занимаетесь ремонтом котлов или так ? только свой отремонтировать ?
mesut
22-03-2016 01:13
I'm sorry you have to do the translation. but only a little English can establish communication for me.
you're right in Turkey 220 volt. Moterboard not give 220v and also electric disapear immediately
I'm electronic technician. i can change part of the motherboard. but ofcourse i dont know exact problem, therefore i wrrte here for your help. it seems be relay or something running it.
this boiler belong to me, mine. and I'm trying to fix myself улыбка
ВладИг
Гость 178.212.*.*
22-03-2016 01:58
у нас есть участники с европы, Так вот они при возникновении вопросов не ленятся перевести свой текст на русский и выложить ...
mesut
22-03-2016 03:15
ВладИг, I'm doing translation into English. Google does not translate properly. недовольство, огорчение i can understand a little bit English. i see if there is an error. So I want to be sure I'm not writing wrong something here. улыбка
Konstantin_18
22-03-2016 11:55
mesut писал:
одобряю
Добавлено 22-03-2016 10:59
Насколько я понял по русски он тоже не понимает, только немного по английски, поэтому наши ответы переводит для себя в Гугле на английский.
Ну что-же будем объяснять на пальцах. подшучивать, дразнить улыбка
Геннадий66
23-03-2016 23:46
тебе сказали поменяй реле турбины, как минимум, выпаяй реле, подай 24в и проверь тестером сопротивление контактов много раз подряд, что то вырисуется (может придется так же проверять соседние реле???). Проверь не коротит обмотка двигателя на корпус... ?
mesut
24-03-2016 00:10
Konstantin_18, you talked about the right issue улыбка I've been in contact with you by turning from russian улыбка and you're communicating well with fingers улыбка
Геннадий66, I solved the problem today. first thought was right. I changed the relay
As you say. Although the relay coil voltage contacts are not closed улыбка
Геннадий66
24-03-2016 14:28
вот и хорошо, просто сгорели контакты на реле, часто бывает Ярошевский Андрей, правильно подсказывал.
Список форумов» Бытовая техника» Газовые котлы» LUNA 240 Fi - Honeywell CS0167B card - repeated FAN ERROR
  • Котел Baxi Luna плата Honeywell CS0167B опознать элемент
  • Не работает плата Honeywell CS0167B - LS
  • Подключение на столе Baxi Luna Honeywell cs0116c-ls
  • BAXI LUNA-3 ошибка 25Е
  • baxi luna ht 1.850 ошибка 128
