Сервисный мануал и схема телевизора AIWA VX-T1470
Файл в формате PDF на английском языкеCONTENTS
- SPECIFICATIONS
- TABLE OF CONTENTS
- SERVICING NOTICES ON CHECKING
- VCR TEST TAPE INTERCHANGEABILITY TABLE
- DISASSEMBLY INSTRUCTIONS
- REMOVAL OF MECHANICAL PARTS AND P.C. BOARDS
- REMOVAL OF DECK PARTS
- REMOVAL OF ANODE CAP
- KEY TO ABBREVIATIONS
- PREVENTIVE CHECKS AND SERVICE INTERVALS
- NOTE FOR THE REPLACING OF MEMORY IC
- DECK PARTS LOCATIONS
- SERVICING FIXTURES AND TOOLS
- PREPARATION FOR SERVICING
- ADJUSTMENTS
- MECHANICAL ADJUSTMENTS
- MAJOR COMPONENTS LOCATION GUIDE (VCR)
- ELECTRICAL ADJUSTMENTS (VCR)
- MAJOR COMPONENTS LOCATION GUIDE (TV)
- ELECTRICAL ADJUSTMENTS (TV)
- TROUBLESHOOTING GUIDES
- IC DESCRIPTIONS
- SERVO TIMING CHART
- SYSTEM SWITCH MODE
- SEMICONDUCTOR BASE CONNECTIONS
- BLOCK DIAGRAMS
- TV
- Y/C/HEAD AMP
- SYSTEM CONTROL/OPERATION/POWER/IN/OUT
- TUNER/AUDIO/IF
- PRINTED CIRCUIT BOARDS (OPERATION/HEAD AMP/IF)
- OPERATION SCHEMATIC DIAGRAM
- HEAD AMP SCHEMATIC DIAGRAM
- IF SCHEMATIC DIAGRAM
- PRINTED CIRCUIT BOARDS (SYSCON)
- Y/C SCHEMATIC DIAGRAM
- SYSTEM CONTROL SCHEMATIC DIAGRAM
- TUNER/AUDIO SCHEMATIC DIAGRAM
- POWER/IN/OUT SCHEMATIC DIAGRAM
- MICON SCHEMATIC DIAGRAM
- CHROMA SCHEMATIC DIAGRAM
- SOUND AMP SCHEMATIC DIAGRAM
- OPERATION 1 SCHEMATIC DIAGRAM
- DELAY SCHEMATIC DIAGRAM
- PRINTED CIRCUIT BOARDS (MAIN/CRT/POWER SW)
- DEFLECTION SCHEMATIC DIAGRAM
- TV POWER SCHEMATIC DIAGRAM
- CRT SCHEMATIC DIAGRAM
- INTERCONNECTION DIAGRAM
- WAVEFORMS
- MECHANICAL EXPLODED VIEW
- MECHANICAL REPLACEMENT PARTS LIST
- ACCESSORY REPLACEMENT PARTS LIST
- CHASSIS EXPLODED VIEW (TOP VIEW)
- CHASSIS EXPLODED VIEW (BOTTOM VIEW)
- FRONT LOADING UNIT 15 EXPLODED VIEW
- CHASSIS/FRONT LOADING UNIT 15 REPLACEMENT PARTS LIST
- ELECTRICAL REPLACEMENT PARTS LIST
Информация Ремонт ТВ AIWA Программный ремонт Ремонт блока питания Шасси телевизора Ссылки на схемы
avel AVS2230MPP прошивка Spi Q32C-104HIPSandu, сперва смотреть две преобразователи FR9886 (So-8) и пятиногий преобразователь sot25-25 на кз в случае заменить/ заменишь дальше видно будет 1656422764 Sandu, Ты можешь слить прошивку Q32 и выложить сюда?ryzp
Витязь 43LU1204 Прошивка USBСаша, ну глаз могу лечить или ещё что, я много что умею, на рыбках тренировался. Маг короче Старый становлюсь. Не все сразу понял. :pray:ФАРТ
BQ 58fsu32b завис на логотипеBq58fsu32b. main hk.t.rt 2851v09. в интернете ни чего не могу найти. может кто то сливал дамп? покажи свой слитый дамп , тогда сможем помочь ... 1656213188 тв в сервисе. (горе мастера не могут его сделать, видимо сервис не айс). дамп еще не сливал.spybot888
Нужна прошивка на духовой шкаф whirlpool , Mod:AKZ444 ,service 10Всем привет! Помогите с прошивкой на духовой шкаф AKZ444 servese 10Сергей ж
UE32D6510WSXRU BN41-01587E версия 1018.0 прошивкаПрошивка 100%. ТВ поступил с отсутствием звука, слегка погрел феном проц, звук появился. Проц заменён на новый. Теперь выключается через 30 сек. Похоже, пока менял проц, вышла из строя EMMC, не читается.Sergey_S
