- Производитель
- Power Integrations
DataSheet TNY275; TNY275PN
Energy Efficient, Off-Line Switcher with Enhanced Flexibility and Extended Power RangeLowest System Cost with Enhanced Flexibility
- Simple ON/OFF control, no loop compensation needed
- Selectable current limit through BP/M capacitor value
- - Higher current limit extends peak power or, in open frame applications, maximum continuous power
- - Lower current limit improves efficiency in enclosed adapters/chargers
- - Allows optimum TinySwitch-III choice by swapping devices with no other circuit redesign
- Tight I2f parameter tolerance reduces system cost
- - Maximizes MOSFET and magnetics power delivery
- - Minimizes max overload power, reducing cost of transformer, primary clamp & secondary components
- ON-time extension – extends low line regulation range/hold-up time to reduce input bulk capacitance
- Self-biased: no bias winding or bias components
- Frequency jittering reduces EMI filter costs
- Pin-out simplifies heatsinking to the PCB
- SOURCE pins are electrically quiet for low EMI
Enhanced Safety and Reliability Features
- Accurate hysteretic thermal shutdown protection with automatic recovery eliminates need for manual reset
- Improved auto-restart delivers
- Output overvoltage shutdown with optional Zener
- Line under-voltage detect threshold set using a single optional resistor
- Very low component count enhances reliability and enables single-sided printed circuit board layout
- High bandwidth provides fast turn on with no overshoot and excellent transient load response
- Extended creepage between DRAIN and all other pins improves field reliability
lg 55sm8600 нужен eppromнужен epprom под эту модель lg 55sm8600pla у кого есть поделитесь.фото мат.платы я прикрепил.буду ждать...vovan242787
Rolsen RL-26X20 с DVD (шасси: PLZM01 REV06) прошивка A29040BL-70F, позиция Q002Сие, эдак... но интуиция подсказывает не найду...CHETLAN
Toshiba 50U7880VQ - ищу USB прошивкуДмитрий_2023, оформи тему по правилам и я перенесу ее в правильный раздел. Игорь, спасибо за ответ - постарался оформить. Поправь, пожалуйста, если ошибся.Дмитрий_2023
Принципиальная схема носимого видеорегистратора Dozor-77Здравствуйте дорогие друзья! Крайне необходима принципиальная схема для DOZOR-77 (обновленный)Ihuns
haier 43 tv dx light прошивкадобрый день у кого есть прошивка на haier 43 tv dx light скиньте пожалуйста main board cv6683h-c42P.Stasyn
Rolsen RL-26X20 с DVD (шасси: PLZM01 REV06) прошивка A29040BL-70F, позиция Q002Ильшат, прежде чем писать, читать что я прошу надо, там шасси другое !!!CHETLAN
Муз.центр Aiwa CSD-SR510EZ, ищу схемуAiwa CSD-SR510EZ ищу схему или сервис мануал. Заранее благодарен!e22-e44
