- Производитель
- NXP Semiconductors
DataSheet TEA1753; TEA1753T
HV start-up DCM/QR flyback controller with integrated DCM/QR PFC controllerDistinctive features
- Integrated PFC and flyback controller
- Universal mains supply operation (70 V AC to 276 V AC)
- Dual boost PFC with accurate maximum output voltage (NXP patented)
- High level of integration, resulting in a very low external component count and a cost-effective design
- Adjustable PFC switch-off delay
Green features
- On-chip start-up current source
- Power down functionality for very low standby power
PFC green features
- Valley/zero voltage switching for minimum switching losses (NXP patented)
- Frequency limitation to reduce switching losses
- PFC is switched off when a low load is detected at the flyback output
Flyback green features
- Valley switching for minimum switching losses (NXP patented)
- Frequency reduction with adjustable minimum peak current at low-power operation to maintain high efficiency at low output power levels
Protection features
- Safe restart mode for system fault conditions
- Continuous mode protection with demagnetization detection for both converters (NXP patented)
- UnderVoltage Protection (UVP) (foldback during overload)
- Accurate OverVoltage Protection (OVP) for both converters (adjustable for flyback converter)
- Mains voltage independent OverPower Protection (OPP)
- Open control loop protection for both converters. The open-loop protection on the flyback converter is a safe restart
- OverTemperature Protection (OTP)
- Low and adjustable OverCurrent Protection (OCP) trip level for both converters
- General-purpose input for latched protection, for system OverTemperature Protection (OTP) for example
Hyundai H-LED32ET4100 main JUC7.820.00208835 Нужна прошивка LCDнарод тупо сливал не выложив состояния статус-регистров Они влияют на результат чтения программатором?artur008
tv Samsung ue65ks9002t нужна прошивка 25q80 ic804http://televid-sib.ru/index.php?topic=26680.msg179216#msg179216 https://remont-aud.net/dump/lcd_pdp_tv/samsung/samsung_ue55ks9000txxe_shassi_main_board_bn41_02504a_jazz_m_usit/241-1-0-94951artur008
Telefunken TF-LED43S05T2SU Ищу USB обновление длядоброго времени суток уважаемые. имею спросить следующее: TELEFUNKEN TF-LED43S05T2SU маин HK.T.RT2871P738 панель ST4251D01-7 заменил плату на аналогичную но от Hyundai H-LED43EU7001 залил прошивку...Polo
SUPRA STV-LC60GT5000U Ищу файл прошивки для панели V580DJ4-QE1 Rev.T4В сервисном меню нашел , что тип панели меняется через загрузку файла панели по USB. Factory menu--->Other--->Project ID ? Отвечаю. В сервисном меню пункта Other нет. Есть строка PID - 9K04G000S000003AndreySk
Решено UPS FSP EP1500 (ppf9000105) требуется схемаОт FSP тоже ответа нет, тему придётся закрыть.AZrx
SHARP LC60LE822ERU Ищу прошивку на телевизорИщу прошивку на телевизор LC60LE822ERU (майн DKEYDF455FM07)родную потеряли в прежнем месте ремонта, залили с SHARP_LC-40LE810E не включается. Пытался найти родной майн DKEYDF455FM07 не удачно.Генерал
