- Производитель
- NXP Semiconductors
DataSheet TEA1752; TEA1752T
HV start-up DCM/QR flyback controller with integrated DCM/QR PFC controllerЦоколевка TEA1752T
Distinctive features
- Integrated PFC and flyback controller
- Universal mains supply operation (70 V AC to 276 V AC)
- Dual boost PFC with accurate maximum output voltage (NXP patented)
- High level of integration, resulting in a very low external component count and a cost-effective design
- Adjustable PFC switch-off delay
Green features
- On-chip start-up current source
PFC green features
- Valley/zero voltage switching for minimum switching losses (NXP patented)
- Frequency limitation to reduce switching losses
- PFC is switched off when a low load is detected at the flyback output
Flyback green features
- Valley switching for minimum switching losses (NXP patented)
- Frequency reduction with adjustable minimum peak current at low-power operation to maintain high efficiency at low output power levels
Protection features
- Safe restart mode for system fault conditions
- Continuous mode protection with demagnetization detection for both converters (NXP patented)
- UnderVoltage Protection (UVP) (foldback during overload)
- Accurate OverVoltage Protection (OVP) for both converters (adjustable for flyback converter)
- Mains voltage independent OverPower Protection (OPP)
- Open control loop protection for both converters. The open-loop protection on the flyback converter is a safe restart
- OverTemperature Protection (OTP)
- Low and adjustable OverCurrent Protection (OCP) trip level for both converters
- General-purpose input for latched protection, for system OverTemperature Protection (OTP) for example
Типовая схема включения TEA1752T
Магнитола автомобильная SONY DSX A212UI Нужна схема.Bogard, начни с сдувания наиболее используемых кнопок (включения/выбор режима/поиск вперёд)Porter
Решено Vekta LD-50SU8731SS ищу прошивку.Суоярви, не подскажите - можно где-то взять прошивку на VEKTA LD-50SU8731SS ? Буду очень признателен!HaltBoy
Решено HYUNDAI H-LED32ET3021 Ищу прошивку или подлечить родной дампПосле того как он тут поругался, что ждать то? Я не курсе, кто с кем, почему поругался. Моё дело было предложить вариант удобный для мастеров. Далее, решайте сами.Jovani
Решено HYUNDAI H-LED43F502BS2S, main T.MT5510S.82, ищу прошивку EMMC U8 KLM8G1GETFПроблему решил через терминалGenius
Решено Horizont 32LCD825. Шасси: B.TR901C 7355 прошивка U3 25X80VSIGТелевизор включался на короткое время на экране появлялся снег потом матрица переходила в режим теста с надписями в левом верхнем углу с переключением фона в синий, зелёный ,красный решилось заменой и прошивкой 24с64 от автора темы .В качестве теста замкнул 5и6 ножки и...dvdrs
Решено ASANO 43LU8010T.шасси TP.MT5522S.PC822. Прошивка USB. ТелевизорВсем спасибо! Помогла с сайта 4pda !!nail--72
