Hiren's BootCD - это загрузочный DOS диск
Список форумов» Программное обеспечение
Moshkin
14-02-2006 22:10
Hiren's BootCD 8.2 - это загрузочный DOS диск с кучей разных программ и утилит, список которых можно увидеть на этой странице.
http://homepage.ntlworld.com/hiren.thanki/bootcd.html
Там же можно и скачать Keyboard-Patch, чтобы поменять layout клавиатуры.
скачать >>> http://www.9down.com/story.php?sid=6598 63,5 mb
Добавлено Февраль 14 2006
список прог и утилит :
Hiren's BootCD 7.8
All in one Dos Bootable CD which has all these utilities
Partition Tools
Partition Magic Pro 8.05
Best software to partition hard drive
Acronis Disk Director Suite 9.0
Popular disk management functions in a single suite
Paragon Partition Manager 7.0.1057
Universal tool for partitions
Partition Commander 9.01
The safe way to partition your hard drive,with undo feature
Ranish Partition Manager 2.44
a boot manager and hard disk partitioner.
The Partition Resizer v1.3.4
move and resize your partitions in one step and more.
Smart Fdisk 2.05
a simple harddisk partition manager
SPecial Fdisk 2000
SPFDISK a partition tool.
eXtended Fdisk 0.9.3
XFDISK allows easy partition creation and edition
GDisk 1.1.1
Complete replacement for the DOS FDISK utility and more.
Disk Clone Tools
ImageCenter 5.6 (Drive Image 2002)
Best software to clone hard drive
Norton Ghost 8.2
Similar to Drive Image (with usb/scsi support)
Acronis True Image 8.0
Create an exact disk image for complete system backup and disk cloning.
Partition Saver 2.80
A tool to backup/restore partitions.
Antivirus Tools
F-Prot Antivirus 3.16b
Very good virus scanner (with ntfs support and easy to use menu)
McAfee Antivirus 4.40
a virus scanner (with ntfs support and easy to use menu)
Recovery Tools
Active Partition Recovery 3.0
To Recover a Deleted partition.
и т.д.
re: голливудская улыбка вроде все ...
vovi
15-02-2006 01:10
Неплохая штука для оживления хардов , пользовался и рекомендую .
Генчик
Гость 85.181.*.*
15-02-2006 01:57
Moshkin, в кои веки действительно нужную вещь выложил, за что тебе большое спасибо. улыбка
Vlad.
15-02-2006 22:29
Это уже не "модно"-есть аналогичный проект "Ultimate boot cd"то есть "ubcd"(количество программ больше чем на "Hirene")-пользовался обоими 3-4года назад пока не "поимел"диски сделанные на базе -Bart PE,Win PE,Erd com 2004-любые манипуляции с "незагружаемыми" системами Win9X,.W2K,XP-ломаем пароли,ловим вирусы,воруем инфу улыбка
Moshkin
15-02-2006 23:20
А что обсуждать ?
Надо - берем , не надо - проходим дальше ... улыбка
Viat
16-02-2006 00:56
Moshkin, напиши как диск-то сделать недовольство, огорчение и что все это на 59метрах шок )
Moshkin
16-02-2006 01:13
Качаем , пишем на болванку , работаем ! улыбка
re: пока качаем - смотрим http://homepage.ntlworld.com/hiren.thanki/funstuff/animations8.html голливудская улыбка
Генчик
Гость 85.181.*.*
16-02-2006 03:05
Moshkin, ну посмотрел, кроме Акрониса, они ничего ценного в эту версию не добавили.
Moshkin
16-02-2006 11:27
Генчик, - это для тебя ! улыбка
Генчик
Гость 85.181.*.*
16-02-2006 17:11
Moshkin, огласите весь список, пожалуйста. улыбка
igor.gm
Мастер по Eizo
16-02-2006 23:35
Генчик писал:
--A Acronis как раз таки там и не пашет .
NB
Гость 195.128.*.*
31-07-2006 13:07
Интересно, всё работает или так-себе?
A.T.Tappman
31-07-2006 14:29
Moshkin, спасибо за ссылку! По сравнению с версией 6 добавлено много полезностей, которых сильно не хватало.
Moshkin
31-07-2006 16:14
A.T.Tappman, пожалуйста . А что именно добавили ?
Если можно вкратце так ...
A.T.Tappman
31-07-2006 22:33
Добавлено изменение паролей входа в систему для Win2k/XP. Работа с бутами. Ну и всякого остального.
Moshkin
01-08-2006 09:49
Понятно ... Спасибо .
Список форумов» Программное обеспечение» Hiren's BootCD - это загрузочный DOS диск
Текущий раздел» Программное обеспечение (Вопросы и обсуждения программного обеспечения)
  • Как создать загрузочный диск с помощью BCDW1.50
  • Чем восстановить диск DVD
  • не запускается диск
  • Виртуальный диск
  • DVD диск с караоке
