Схема и сервисный мануал телевизоров SHARP LC-37SD1E; SHARP LC-37SD1RU
- MainBoard: KD890 + KD604WE20 (QPWBFD604WJN4)
- LCD Panel: LK370T3LZ5BX
- Power Supply (PSU): DUNTKD605WE (KD605WE18)
- PWM Power: MR4020, TA76431R, TA76431R
- IC MainBoard: VCT 6973G B3 000 (B3), LPM240T100G5N, DFN9M0637A(B823), SIL9023CTU, 24LC64
- Tuner: QPWBND609WJN4
Фото основной платы KD890 + KD604WE20 (QPWBFD604WJN4)
Основная плата KD890; QPWBFD604WJN4 может применяться в телевизорах:
- SHARP LC-37SD1E
- SHARP LC-37SD1RU
TABLE OF CONTENTS
- SAFETY PRECAUTION
- IMPORTANT SERVICE SAFETY PRECAUTION
- Precautions for using lead-free solder
- CHAPTER 1. OPERATION MANUAL
- [1] SPECIFICATIONS
- [2] OPERATION MANUAL
- [3] DIMENSIONS
- CHAPTER 2. REMOVING OF MAJOR PARTS
- [1] REMOVING OF MAJOR PARTS
- CHAPTER 3. ADJUSTMENT PROCEDURE
- [1] After replacement of any PWB and/or IC for repair, note the following.
- [2] SOFTWARE UPDATING
- [3] Entering and exiting the adjustment process mode
- [4] Remote controller key operation and description of display in adjustment process mode.
- [5] Adjustment process mode menu
- [6] Special features
- [7] Video signal adjustment procedure
- [8] White Balance Adjustment
- [9] Initialization to factory settings
- [10] Lamp error detection
- [11] Public Mode (Hotel Mode)
- CHAPTER 4. TROUBLESHOOTING TABLE
- [1] TROBLESHOOTING TABLE
- CHAPTER 5. MAJOR IC INFORMATIONS
- [1] MAJOR IC INFORMATIONS
- CHAPTER 6. OVERALL WIRING DIAGRAM/BLOCK DIAGRAM
- [1] OVERALL WIRING DIAGRAM
- [2] BLOCK DIAGRAM
- [3] POWER BLOCK DIAGRAM
- CHAPTER 7. PRINTED WIRING BOARD
- [1] OPERATION UNIT PRINTED WIRING BOARD
- [2] R/C, LED UNIT PRINTED WIRING BOARD
- [3] AV UNIT PRINTED WIRING BOARD
- [4] POWER UNIT PRINTED WIRING BOAR
- [5] D-TUNER UNIT PRINTED WIRING BOARD
- [6] DIGITAL UNIT PRINTED WIRING BOAR
- CHAPTER 8. SCHEMATIC DIAGRAM
- [1] DESCRIPTION OF SCHEMATIC DIAGRAM
- [2] SCHEMATIC DIAGRAM
- Parts Guide
Информация Ремонт ТВ SHARP Программный ремонт Ремонт блока питания Шасси телевизора Ссылки на схемы
AKAI UA32LEZ1T2S Поделитесь пожалуйста прошивкой ТВhttps://remont-aud.net/dump/lcd_pdp_tv/akai/akai_ua32lez1t2s_shassi_main_board_p75_2841v6_0/334-1-0-119620 Вот сдесь есть прошивка с такой матрицей. Кому надо могу скачать. Пишите в ЛК.zsvzsv
SUPRA STV-LC60GT5000U Ищу файл прошивки для панели V580DJ4-QE1 Rev.T4AndreySk, как вариант, можно поробовать по UART через команды загрузчика поколдовать с панелью. И ещё вопрос, что с родным майном приключилось? Гроза случилась, флешку выбило, проц тоже. Можно и без UART, через ADB.AndreySk
Нужна схема блока питания канального кондиционера Panasonic S-90MF2E5Занижены питания дежурного режима. БП на STR Y6763. Уткнулся в обратную связь, оптрон поз. PC314 открыт, тем самым не дает нормально работать. Монтаж залит компаудом и очень обширен, трудно проследить цепи. Хотя есть мысль, что на "столе" отдельно нельзя его в полной мере...GRAYD
Ищу прошивку или дамп emmc от китайского NoName ГУ на андроиде.Всем привет. Умерла EMMC. Ищу дамп или прошивку на это чудо. Экран 7". Отлично подошла прошивка с ремауда(от terrarist -- https://remont-aud.net/forum/125-23262-1?s=sym503), но все кнопки перепутаны. Прежде чем подбирать резисторы хотелось бы попробовать найти родное ПО...myth
Sony KDL-42W653A прошивкаApplicable Models This information is applicable for the following TV models: KD-65X9005A / X8505A KD-55X9005A / X8505A KDL-65W855A KDL-55W802A / W805A / W807A / W808A / W809A / W905A KDL-50W656A / W685A KDL-47W802A / W805A / W807A / W808A / W809A KDL-46W905A KDL-42W650A /...Charm
Telefunken TF-LED43S05T2SU Ищу USB обновление длянеужели нет мыслей по вопросу? 1660643041 может кто прошивкой поделится?Polo
