TNY277; TNY277PN | DataSheet микросхем (PDF)
  • , DataSheet TNY277; TNY277PN - Low Power Off-line Switcher IC
DataSheet TNY277; TNY277PN​
Lowest System Cost with Enhanced Flexibility
  • Simple ON/OFF control, no loop compensation needed
  • Selectable current limit through BP/M capacitor value
  • Higher current limit extends peak power or, in open frame applications, maximum continuous power
  • Lower current limit improves effi ciency in enclosed adapters/chargers
  • Allows optimum TinySwitch-III choice by swapping devices with no other circuit redesign
  • Tight I2f parameter tolerance reduces system cost
  • Maximizes MOSFET and magnetics power delivery
  • Minimizes max overload power, reducing cost of transformer, primary clamp & secondary components
  • ON-time extension – extends low line regulation range/hold-up time to reduce input bulk capacitance
  • Self-biased: no bias winding or bias components
  • Frequency jittering reduces EMI filter costs
  • Pin-out simplifi es heatsinking to the PCB
  • SOURCE pins are electrically quiet for low EMI
Enhanced Safety and Reliability Features
  • Accurate hysteretic thermal shutdown protection with automatic recovery eliminates need for manual reset
  • Improved auto-restart delivers <3% of maximum power in short circuit and open loop fault conditions
  • Output overvoltage shutdown with optional Zener
  • Line undervoltage detect threshold set using a single optional resistor
  • Very low component count enhances reliability and enables single-sided printed circuit board layout
  • High bandwidth provides fast turn on with no overshoot and excellent transient load response
  • Extended creepage between DRAIN and all other pins improves field reliability
  • Какой аналог у TNY277; TNY277PN?
    Списки аналогов находятся в разделе форума, в отдельных темах. Если Вы не нашли чем заменить TNY277; TNY277PN, создайте свою тему с вопросом.
  • Чем заменить TNY277; TNY277PN?
  • Какие параметры TNY277; TNY277PN?
  • Схема включения TNY277; TNY277PN
    В зависимости от типа аппарата в котором используется электронный компонент возможны различные схемы включения TNY277; TNY277PN.
  • Как проверить TNY277; TNY277PN?
  • Какая маркировка TNY277; TNY277PN?
  • Где купить TNY277; TNY277PN?
  • Vestel 17mb62-2.5 прошивка USB
  • AKAI UA32LEZ1T2S Поделитесь пожалуйста прошивкой ТВ
  • SUPRA STV-LC60GT5000U Ищу файл прошивки для панели V580DJ4-QE1 Rev.T4
  • Нужна схема блока питания канального кондиционера Panasonic S-90MF2E5
  • Ищу прошивку или дамп emmc от китайского NoName ГУ на андроиде.
  • Sony KDL-42W653A прошивка
  • Telefunken TF-LED43S05T2SU Ищу USB обновление для
TNT
Скачивания
127
Посмотрено
1.806
Первый выпуск
Обновление
Рейтинг
Оценок: 0
Другие файлы TNT
  • SUPRA STV-LC50T950UL
    Прошивка телевизора SUPRA STV-LC50T950UL Main Board: CV309H-F Chassis: V1N12 LCD Panel: ST4851D01-2 SPI FLASH: 25Q32 Фото основной платы CV309H-F
  • RUBIN RB-19K101
    Прошивка телевизора RUBIN RB-19K101 Main Board: 471-01A4-22001G LCD Panel: LTM185AT01 C01 SPI Flash: EN25F16 Фото основной платы 471-01A4-22001G
  • RUBIN RB-23K101F
    Прошивка телевизора RUBIN RB-23K101F Main Board: 471-01A4-22001G LCD Panel: LM230WF1 (TL)(F1) Фото основной платы 471-01A4-22001G
  • LG 37SL8000
    Прошивка телевизора LG 37SL8000 Main Board: EAX60890803 LCD Panel: LC370WUD (SB)(M3) SPI Flash: 25X32VSIG Фото основной платы EAX60890803
  • TCL 26A33H
    Прошивка телевизора TCL 26A33H Main Board: 40-MT5362-MAB4XG LCD Panel: T260XW02 V.P Eeprom: 24C16WP Фото основной платы 40-MT5362-MAB4XG
  • FUSION FLTV-16W7
    Прошивка телевизора FUSION FLTV-16W7 Main Board: CVMV26L-G LCD Panel: M156MWR1 Spi Flash: EN25F40 Фото основной платы CVMV26L-G
  • FUSION FLTV-24H100T
    Прошивка телевизора FUSION FLTV-24H100T Main Board: TP.S512.PA63 LCD Panel: CM238C01 SPI Flash: 25Q64 Фото основной платы TP.S512.PA63
  • FUSION FLTV-16T9D
    Прошивка телевизора FUSION FLTV-16T9D Main Board: T.VST59.62 LCD Panel: T156LL10-AW4 SPI Flash: 25Q32BSIG Фото основной платы T.VST59.62
  • FUSION FLTV-28T25 (40-T31TOT-MAB2HG)
    Прошивка телевизора FUSION FLTV-28T25 Main Board: 40-T31TOT-MAB2HG LCD Panel: LVW280CS0T E11 V3 SPI FLASH: Winbond 25Q64FVSIG Фото основной платы 40-T31TOT-MAB2HG
  • SUPRA STV-LC32440WL V2N07
    Прошивка ЖК телевизора SUPRA STV-LC32440WL V2N07 Main Board: TP.VST59S.PB702 CPU: TSUMV59XUS LCD Panel: HK315LEDM-0H72H SPI Flash: GD25Q32
  • SSC9522; SSC9522S
    DataSheet SSC9522; SSC9522S High Efficiency, Low noise, Automatic Dead Time Adjustment Control IC for Half-Bridge LLC Off-line Switching Regulators Switching power supplies for electronic devices...
  • FAN7930; FAN7930C; FAN7930B
    DataSheet FAN7930; FAN7930C; FAN7930B Critical Conduction Mode PFC Controller Цоколевка (распиновка) FAN7930; FAN7930C; FAN7930B Features PFC-Ready Signal VIN-Absent Detection Maximum...
  • SHARP LC-23LE448RU
    Схема и сервисный мануал телевизора SHARP LC-23LE448RU Main Board: TP.VST59.PA901 LCD Panel: LSC230AN01-001 CPU: TSUMV59XE SPI Flash: 25Q32
    Прошивка ЖК телевизора SHARP LC-23LE448RU Main Board: TP.VST59.PA901 LCD Panel: LSC230AN01-001 CPU: TSUMV59XE SPI Flash: 25Q32
  • FAN6961
    DataSheet FAN6961 Boundary Mode PFC Controller Features Boundary Mode PFC Controller Low Input Current THD Controlled On-Time PWM Zero-Current Detection Cycle-by-Cycle Current Limiting...
Поделиться ссылкой на файл
