сервисные режимы телевизоров_10.djvu
Содержание
FINLUX................................ 14A1 TX, 51A1 ГХ, 55А1 ТХ.......................................MONO PLUS 2................. 29
GRUNDIG.............................E72-911. M72-105, ST63-781....................................CUC1822/1823/'1852........ 32
GRUNDIG.............................ATLANTA SE7289 IDTV/LOG, SER150,
ST72-261 IDTV/LOG, ST72-261/8 IDTV/LOG.
ST72-261/8 IDTV/LOG...............................................CUC1826......................... 38
GRUNDIG............................. M95-105/9 IDTV/PIP..................................................CUC 1893 ......................... 42
GRUNDIG.............................M95-410/9 REFERENCE/PIP
M95-410/90 REFERENCE
M95-411/9 REFERENCE/PIP......................................CUC 1894 ......................... 48
GRUNDIG............................. M84-211/8 IDTV(NVM)..............................................CUC1929 ......................... 56
GRUNDIG.............................Arganto 70 MW70-510/8 DPL (VNM)
Berlin SE7050/8 PIP/DOLBY......................................CUC 1930 ......................... 61
HITACHI............................... CP2022T. CP2022T-491. CS2022R.............................F2.................................... 69
ITT....................................... 7171 .........................................................................DIGITAL B-E2................... 74
LUXOR................................. 6345, 6346. 7045. 7046. 7438...................................FEATURE STEREO FS....... 78
NOKIA.................................. 5521 .........................................................................MONO PLUS 2................. 85
NORDMENDE.........................................................................................................ICC 17.............................. 88
NORDMENDE.........................................................................................................7X807.............................. 95
OCEANIC,.......................... 7495. 7185VT............................................................EUROSTEREO
FEATURE PLUS................99
Panasonic............................ CT-F29992LV. CT-F29992V.
CT-F29992W. CT-F29992XV.......................................ATPEDP264.................... 105
Panasonic............................ TX-W28D2DP, TX-W28D3F, TX-W28D3F/P,
TX-W32D2. TX-W32D20. TX-W32D2DP. TX-W32D3DP. TX-W32D3DP/L.
TX-W32D3F, TX-W32D3F/P........................................EURO-3HW.................... 110
Panasonic............................ TC-25V50R, TC-29V50R. TX-25V50T. TX-29V50T........MX-2A............................ 713
SABA ......................................................................................................................7X807............................. 120
S A LOR A...............................25V80, 28V80............................................................FEATURE STEREO FS......124
SALORA............................... 14 S3. 20S3. 21 S3......................................................MONO PLUS.................. 131
SCHNEIDER......................... CTV2780. STV6708 ....................................................TV-8............................... 134
SCHNEIDER......................... STV2801T..................................................................7V9.8............................. 137
SHARP................................. DV-5935H..................................................................BCTV-A.......................... 141
SHARP................................. DV-5101H. DV-5103H................................................EURO-DS 1.................... 144
SONY................................... KV-A2133B. KV-A2541A. KV-A2541B.
KV-A2541D. KV-A2541K, KV-A2542U. KV-A2543E. KV-A2941A, KV-A2941B,
KV-A2941D. KV-A2942U, KV-A2943E..........................AE-2B............................ 147
SONY................................... KV-28FX60, KV-32FX60..............................................AE-5...............................156
SONY...................................KV-21M1, KV-21M3. KV-21T1. KV-21T3,
KV-M2170A, KV-M2170B. KV-M2170D. KV-M2170E, KV-M2170K. KV-M2170L. KV-M2170U, KV-M2171A. KV-M2171B, KV-M2171D, KV-M2171E, KV-M2171K,
KV-M2I71R. KV-M2171U...........................................BE-4A.............................165
SONY................................... KV-PF21L70. KV-PF21M40. KV-PF21M70,
KV-PF21M70. KV-PF21P10. KV-PF21P40.
KV-PF21P40. KV-PF21P41, KV-PF21Q70....................BG-3S............................ 170
TATUNG............................... DYN9B02, DYN9B51T................................................fl / ................................. /78
TELEFUNKEN..........................................................................................................7X807............................ 181
TOSHIBA..............................2163DB . 2163DD, 2163DF,
2163DN. 2163DS.......................................................C6S............................... 185
TOSHIBA.............................. 2112DBT, 2927DB.............................................................................................189
TOSHIBA.............................. 2505DBT, 2805DBT...........................................................................................193
UNIVERSUM......................... FT4261/A. FT4270. FT4281, FT4283...........................E-6.................................197
загружен 12-11-2008 09:57
Содержание
Samsung UE49MU6450UXRU прошивка 25Q40sergiy, скачал. Огромное спасибо. О результате отпишусь позже.Sergey_1
Парогенератор Tefal GV7460. Ищу Servis Manual.Парогенератор Tefal GV7460. Ищу Servis Manual. Или схему..Montajnik
avel AVS2230MPP прошивка Spi Q32C-104HIPSandu, сперва смотреть две преобразователи FR9886 (So-8) и пятиногий преобразователь sot25-25 на кз в случае заменить/ заменишь дальше видно будет 1656422764 Sandu, Ты можешь слить прошивку Q32 и выложить сюда?ryzp
Витязь 43LU1204 Прошивка USBСаша, ну глаз могу лечить или ещё что, я много что умею, на рыбках тренировался. Маг короче Старый становлюсь. Не все сразу понял. :pray:ФАРТ
BQ 58fsu32b завис на логотипеBq58fsu32b. main hk.t.rt 2851v09. в интернете ни чего не могу найти. может кто то сливал дамп? покажи свой слитый дамп , тогда сможем помочь ... 1656213188 тв в сервисе. (горе мастера не могут его сделать, видимо сервис не айс). дамп еще не сливал.spybot888
