rexar Новичок Сообщения: 5
Постояно моргает SYS.
Через служебный разьем считывается следующее:
Copyright (c) 2001 - 2006 ADSL Company
initialize ch = 0, IP175C, ethernet address: 00:30:4f:55:46:04
initialize ch = 1, ethernet address: 00:30:4f:55:46:04
Wan Channel init ........ done
Initializing ADSL F/W ........ done
Exception occured!
EPC= 0x800AAE4C
SR= 0x0000FF14
CR= 0x00000010
$RA= 0x800AAE30
AdEL Bad Virtual Address = 0xDEADC27D..\core\sys_isr.c:420 sysreset()
$r0= 0x00000000 $at= 0xBFBF0000 $v0= 0x0000006A $v1= 0x803A6A70
$a0= 0x803A6E71 $a1= 0x803A6960 $a2= 0xFFFFFFFF $a3= 0xFFFFFFF9
$t0= 0x8001FF80 $t1= 0x00000002 $t2= 0x803A6462 $t3= 0x00000000
$t4= 0x80257504 $t5= 0x00000001 $t6= 0x00000020 $t7= 0x00000000
$s0= 0x803A6560 $s1= 0x803A69A0 $s2= 0x802655B8 $s3= 0x000001A4
$s4= 0x0000FF14 $s5= 0x00000002 $s6= 0x00000000 $s7= 0x00000000
$t8= 0x80261A98 $t9= 0xAABBCCDD $k0= 0xDEADC27D $k1= 0x80000000
$gp= 0x8032C530 $sp= 0x803A6500 $fp= 0x803A6560 $ra= 0x80031C78
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
803a6560: 80 3a 65 80 80 03 ff bc 00 00 00 00 00 00 00 00 .:e.............
803a6570: 80 3e d0 44 0a 01 06 fd 00 00 00 00 80 02 54 98 .>.D..........T.
803a6580: 80 4c 69 68 80 25 74 4c 80 3a 65 90 80 02 43 58 .Lih.%tL.:e...CX
803a6590: 80 3a 64 e8 80 02 00 58 00 00 00 00 00 00 00 00 .:d....X........
803a65a0: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a65b0: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a65c0: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a65d0: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a65e0: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a65f0: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6600: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6610: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6620: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6630: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6640: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6650: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6660: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6670: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6680: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6690: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a66a0: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a66b0: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a66c0: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a66d0: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a66e0: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a66f0: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6700: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6710: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6720: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6730: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6740: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6750: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6760: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6770: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6780: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6790: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a67a0: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a67b0: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a67c0: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a67d0: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a67e0: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a67f0: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6800: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6810: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6820: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6830: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6840: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6850: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6860: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6870: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6880: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a6890: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a68a0: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a68b0: ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ef ................
803a68c0: 80 25 81 04 00 00 ff 15 80 3a b3 34 00 00 00 00 .%.......:.4....
803a68d0: 80 3a b3 34 80 25 69 d4 80 3a b3 34 80 3a b3 34 .:.4.%i..:.4.:.4
803a68e0: 00 00 00 00 80 03 2e 28 80 3a b3 34 00 00 00 04 .......(.:.4....
803a68f0: 80 3a 69 00 80 04 9d 60 80 3e 62 a4 00 00 00 00 .:i....`.>b.....
803a6900: 80 3a 69 30 80 04 a3 24 80 3e aa 38 00 00 00 04 .:i0...$.>.8....
803a6910: 80 03 56 6c 80 34 ab 9c 00 00 00 00 00 00 00 00 ..Vl.4..........
803a6920: 00 00 00 00 80 3e 49 24 00 00 00 00 00 00 00 00 .....>I$........
803a6930: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
803a6940: 80 3a a9 a8 80 25 5c 44 80 32 e1 28 00 00 ff 15 .:...%\D.2.(....
803a6950: 00 00 00 00 00 00 00 00 80 25 7f 44 00 00 ff 15 .........%.D....
Bootbase Version: VTC1.10 | 2006/3/16 15:21:52
RAM: Size = 8192 Kbytes
FLASH: AMD 16M *1
RAS Version: 2.7.0.26(UE0.C2C)3.5.10.5
System ID: 2.7.0.26(UE0.C2C)3.5.10.5| 2006/4/6
Командой ATUR (upload router firmware to flash ROM) перепрошивается, но проблема остается.
HELP!? |
Может быть есть fullflash на этот модем?
Или может эту ошибку можно исправить служебными командами через telnet, как? |
Эгегегееееей!
-ей! -ей! -ей!
Есть кто живой?!
-ой! -ой!
А в ответ только эхо :-) |
Продолжим монолог.
Нужен калькулятор Planet-а (генератор пароля) чтобы подсчитать отладочный пароль, для доступа к working buffer.
ATSE
094ECA554604
OK
Не подскажете где такой есть? |
KucherMan Участник Сообщения: 115
Есть дамп на модем любезно предоставленный коллегой zxbor1 - http://monitor.net.ru/forum/viewtopic.php?t=343352
Версия модема - ADE-4400A B500226200519 (065)
На флеше:
2.2.29(WS2 B2) 3.2.0.4
check sum:3b58
Но нужно быть уверенным с ревизией. Я прошил, но до ума пока не довел, что-то глючит. По крайней мере он ожил, что уже хорошо. Могу выслать на мыло если еще актуально. |
Прошил модем через сервисный кабель по методике описанной здесь - http://zyxel.ru/content/support/knowledgebase/KB-1229
"Вопрос:
Как записать микропрограммное обеспечение в устройство через консольный порт?
Ответ:
Запись микропрограммы нужно производить по приведенной ниже схеме и затем заново вручную настроить устройства. Для замены микропрограммы откройте терминальную программу (например, HyperTerminal из состава Windows), установив работу через COM-порт (например, прямое соединение COM1). Скорость последовательного порта установите равной 9600 бит/с.
1. Маршрутизатор при загрузке напишет сообщение:
Press any key to enter Debug Mode within 3 seconds
нажмите любую клавишу, чтобы перейти в режим отладки;
2. Дайте команду ATBA5, чтобы установить скорость порта 115200;
3. Поменяйте скорость порта в терминальной программе;
4. Дайте команду ATLC (в некоторых устройствах ATUR3) и подождите, пока устройство ответит "Starting XMODEM upload", чтобы начать передачу файла с заводскими настройками (*.rom);
5. После появления сообщения "Starting XMODEM upload" можно начинать передачу файла с настройками при помощи протокола X-modem. В программе HyperTerminal для этого следует обратиться к меню "Передача" (Transfer) и выбрать "Отправить файл" (Send file). В открывшемся окне выберите протокол передачи файлов X-модем и укажите 6.программе в каком месте на жестком диске находится требуемый файл. Затем нажмите кнопку "Отправить" (Send);
После дайте команду ATUR и подождите, пока модем ответит "Starting XMODEM upload", чтобы начать передачу файла с микропрограммным обеспечением (*.bin);
# После успешной загрузки микропрограммы устройство должно автоматически перезагрузиться. Если это не произошло, дайте команду ATGO, чтобы перезапустить устройство;
# Измените скорость порта в коммуникационной программе на 9600 бит/с."
Зашел в debug mode, дал комманду ATUR, отправил файл прошивки - http://www.planet.com.tw/en/dl_file.php?fn=product/images/2538/FW-ADE4 ... через гипертерминал по протоколу Xmodem. Модем ожил и даже заработал! |
Ссори за оффлайн. | KucherMan писал: | | Могу выслать на мыло если еще актуально. |
Пожалуйста вышли, очень актуально:
Правда версия прошивки другая:
System ID: 2.7.0.26(UE0.C2C)3.5.10.5| 2006/4/6 |
Я могу выслать, но прошивка не подойдет, судя по всему, у тебя иная версия модема, а они отличаются аппаратно. У меня дамп на версию 1, а у тебя похоже версия 2. |
Murz0id Гость 217.19.*.*
Друзья подскажите пожалуйста, у меня та же проблема как и у автора топика. После отключения света моргает SYS и модем не стартует. Прошил модем прошивкой 2.2.2.9., но проблема осталась. Может прошивку не ту заливаю, как определить версию модема? Снизу написано ADE-4400A B500226401908 (065). Заранее благодарю за отзывы! |
dinаmik Предупреждений: 1 Сообщения: 2476
Murz0id, жаль что живёшь не в Украине. Выслал бы тебе пару штук совершенно бесплатно. Валяются тупо. У нас им цена 3 коп.  |
