вот лог JAF
JAF version 1.98.62
Detected PKEY: 9000DA9A
Card life counter: 99.99%
P-key nokia module version 01.02
FBUS INTERFACE NOT CONNECTED!!!
USB Cable Driver version: 7.1.17.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-240\
Searching for default location of ini...
Checking path: D:\Program Files\Common Files\Nokia\DataPackage\Products\RM-240\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-240\rm240__10.00.mcusw
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-240\rm240__10.00.ppm_i
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-240\rm240__10.00_ism_022.image_i_ru
Languages in ppm: English,German,Russian,Bulgarian,Romanian,Ukrainian
Detected P-KEY: 9000DA9A
Init usb communication...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using 06.02.002
Elf2flash 07.14.000
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step3...
Sending RAW Loader...
...................Loader Sent!
Stage 2 starting...........................................................................Loader Sent!
Stage 3 starting..................Phone prepared OK!
Waiting for the phone to boot...
Fail to reboot the phone...
Backing up CRT...
Reading IMEI...
Failed! Aborting!
Failed to backup CRT...
PRESS POWER ON NOW!
Using 06.02.002
Elf2flash 07.14.000
CMT RAW loader...
Status byte: 0400
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 2448, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-240\rm240__10.00.mcusw...
Erasing cmt zone 00000000 - 0001FFFF ... Erase result: 0000
Erasing cmt zone 00040000 - 000BFFFF ... Erase result: 0000
Erasing cmt zone 000C0000 - 0013FFFF ... Erase result: 0000
Erasing cmt zone 01480000 - 015FFFFF ... Erase result: 0000
Erasing cmt zone 00140000 - 0147FFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-240\rm240__10.00.ppm_i...
Erasing cmt zone 01600000 - 01CBFFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-240\rm240__10.00_ism_022.image_i_ru...
Erasing cmt zone 01FC0000 - 03F9FFFF ... Erase result: 0000
Erasing cmt zone 01CC0000 - 01FBFFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for NOLO
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for PASUBTOC
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
Sending CMT HASH for UPDAPP
Sending CMT HASH for DSP0
Sending CMT HASH for MCUSW
Rebooting...
Restarting CMT...
Pooling phone...
Phone not found...
Second try...
MCUSW: (null)
APESW: (null)
VariantSW: (null)
Prodcode:
Setting test mode...
Failed! Aborting!
Done!
Бутер это проц а сверху флеш да еще под компаундом тоже была такая беда только у меня сам перезагружался при работе был ударник со сколом на проце и прошивался тоже на ура
