Panasonic TH-40DX600U Tuner circuit Diagram
  • pclogicnz
pclogicnz
  • 20 Июл 2020
Someone broke the Arial connection off and I had to drill the TV tunner shield to get to the inside, but mistakingly drilled off one component of the TV arial sectection.
Does anyone have a circuit diagram of where the arieal comes in and what components it would normally use.? i assume i only have to put the right one back in to make it work.
ut3eo
  • 20 Июл 2020
pclogicnz, What type of tuner? Photo of the damaged area?
    • Нет изображения на экране
    • Пятна на панели
    • Потух экран, а звук остался
    • Нет картинки на дисплее
    • Мерцает изображение
    • и другие
pclogicnz
  • 21 Июл 2020
I posted files and now they are gone? Why?
I will attach them again.
So all I need is some idea of a circuit diagram from the arial socket into the TV.
    1,4 МБ · Посмотрено: 119
    2 МБ · Посмотрено: 116
    1,6 МБ · Посмотрено: 118
ut3eo
  • 21 Июл 2020
pclogicnz,
It is not realistic to find the internal tuner circuit. The filter is assembled on the elements in the photo. You have to experiment. You can put a jumper instead of the missing element.
Here is a service manual, but it is unlikely to help.  ссылка скрыта от публикации
pclogicnz
  • 22 Июл 2020
Wow, thank you so much for the service manual. I can actually find the tuner circuit components on page 56. It shows the same circuit layout of what I have. It also shows the component numbers. And it looks like I am only missing L6961 which is a COIL, So I assume a simple jumper should work.
I will try that and let you know how it went.
    63,3 КБ · Посмотрено: 94
ut3eo
  • 22 Июл 2020
pclogicnz, OK
