Ремонт модема DSL2600U/NRU
Uipobpf
3 Май 2019
Странная неисправность, которая встречается у некоторых обладателей сего чуда.
Проблема вот в чём.
При загрузке на некотором моменте выдаёт D%G и перезагружается.
Вот логи:
HELO
CPUI
L1CI
DRAM
PHYS
ZQDN
PHYE
DINT
LSYN
USYN
MSYN
LMBE
PASS
ZBSS
CODE
DATA
L12F
MAIN
CFE version 1.0.37-106.24 for BCM96328 (32bit,SP,BE)
Build Date: Срд Мар 21 08:38:40 UTC 2012 (legath@desk)
Copyright (C) 2000-2009 Broadcom Corporation.
HS Serial flash device: name ID_W25X32, id 0xef16 size 4096KB
Total Flash size: 4096K with 1024 sectors
Chip ID: BCM6328B0, MIPS: 320MHz, DDR: 320MHz, Bus: 160MHz
Main Thread: TP0
Memory Test Passed
Total Memory: 33554432 bytes (32MB)
Boot Address: 0xb8000000
Board IP address : 192.168.1.1:ffffff00
Host IP address : 192.168.1.100
Gateway IP address :
Run from flash/host (f/h) : f
Default host run file name : vmlinux
Default host flash file name : bcm963xx_fs_kernel
Boot delay (0-9 seconds) : 1
Board Id (0-6) : DSL_2600NRU
Number of MAC Addresses (1-32) : 11
Base MAC Address : 28:10:7b:3a:ab:38
PSI Size (1-64) KBytes : 24
Enable Backup PSI [0|1] : 0
System Log Size (0-256) KBytes : 0
Main Thread Number [0|1] : 0
Voice Board Configuration (0-11) :
*** Press any key to stop auto run (1 seconds) ***
Auto run second count down: 110
Booting from only image (0xb8010000) ...
Code Address: 0x80010000, Entry Address: 0x800144a0
Decompression OK!
Entry at 0x800144a0
Closing network.
Disabling Switch ports.
Flushing Receive Buffers...
0 buffers found.
Closing DMA Channels.
Starting program at 0x800144a0
Linux version 2.6.30 (builder@rd) (gcc version 4.4.2 (Buildroot 2010.02-git) ) #1 Mon May 14 09:51:31 MSK 2012
DSL_2600NRU prom init
CPU revision is: 0002a075 (Broadcom4350)
Determined physical RAM map:
memory: 01f00000 @ 00000000 (usable)
Zone PFN ranges:
DMA 0x00000000 -> 0x00001000
Normal 0x00001000 -> 0x00001f00
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
0: 0x00000000 -> 0x00001f00
On node 0 totalpages: 7936
free_area_init_node: node 0, pgdat 802bdab0, node_mem_map 81000000
DMA zone: 32 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 4064 pages, LIFO batch:0
Normal zone: 30 pages used for memmap
Normal zone: 3810 pages, LIFO batch:0
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 7874
Kernel command line: root=31:0 ro noinitrd console=ttyS0,115200
wait instruction: enabled
Primary instruction cache 32kB, VIPT, 4-way, linesize 16 bytes.
Primary data cache 32kB, 2-way, VIPT, cache aliases, linesize 16 bytes
RCU-based detection of stalled CPUs is enabled.
NR_IRQS:128
PID hash table entries: 128 (order: 7, 512 bytes)
console [ttyS0] enabled
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory: 28256k/31744k available (2291k kernel code, 3488k reserved, 458k data, 120k init, 0k highmem)
Calibrating delay loop... 319.48 BogoMIPS (lpj=159744)
Mount-cache hash table entries: 512
net_namespace: 820 bytes
NET: Registered protocol family 16
registering PCI controller with io_map_base unset
bio: create slab <bio-0> at 0
pci 0000:01:00.0: PME# supported from D0 D3hot
pci 0000:01:00.0: PME# disabled
pci 0000:02:00.0: reg 10 64bit mmio: [0x000000-0x003fff]
pci 0000:02:00.0: supports D1 D2
pci 0000:01:00.0: PCI bridge, secondary bus 0000:02
pci 0000:01:00.0: IO window: disabled
pci 0000:01:00.0: MEM window: 0x10f00000-0x10ffffff
pci 0000:01:00.0: PREFETCH window: disabled
PCI: Enabling device 0000:01:00.0 (0000 -> 0002)
PCI: Setting latency timer of device 0000:01:00.0 to 64
BLOG v3.0 Initialized
NET: Registered protocol family 8
NET: Registered protocol family 20
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
squashfs: version 4.0 (2009/01/31) Phillip Lougher
squashfs: version 4.0 with LZMA457 ported by BRCM
msgmni has been set to 55
io scheduler noop registered (default)
pcieport-driver 0000:01:00.0: device [14e4:6328] has invalid IRQ; check vendor BIOS
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
NET: Registered protocol family 24
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
bcm963xx_mtd driver v1.0
File system address: 0xb8010100
brcmboard: brcm_board_init entry
SES: Button Interrupt 0x1 is enabled
SES: LED GPIO 0x8009 is enabled
D%G
В самом конце есть это загадочное D%G.
Кто знает что это???
    Ответ в тему Ремонт модема DSL2600U/NRU как и все другие советы публикуются всем сообществом. Большинство участников это профессиональные мастера по ремонту и специалисты в области электроники.
Porter
3 Май 2019
Считай, что загадочное D%G - признак проблем с вторичными питаниями или отвала проца. Ибо это основные болячки сих девайсов.
grunin
10 Май 2019
Из лога видно что есть память SPI
Я бы дамп рабочий залил. А потом снова ЛОГ.
Uipobpf
22 Май 2019
Я так сначала и сделал, но это не помогло.
Uipobpf
13 Мар 2020
проблема решена
Serge3
13 Мар 2020
И как она решена?
