Д
ДядяЮра
- 2 Май 2018
Матрицы
МИКРОСХЕМЫ
PT6523
PT6578
SC75823E
LC75823E
MST720C-T-LF
MST717A-LF
MST726A-LF
IRM58M
T118FS
T118EL
T108
SPHE8281D
SPHE8202TQ 128 pin демонтаж
ZR36882ELCG
ES6629FF
F1C500
TDA7388
TDA7580
TB2929HQ
16219796 (PAL0003A) MALTA
FSP3307 converters drive up to six LEDs
BA6951FS DC Motor Driver
TDA7703 tuner for AM/FM car radio
TEF6606T AM/FM radio including Phase-Locked Loop (PLL) tuning
TEF6624T AM/FM radio including Phase-Locked Loop (PLL) tuning
PT7313E audio processor
M62490FP C1BB00000284 CQ-TS7170LC electric volume control with tone controller for 4-SPEAKER applications
AN8065SE1 DATT/ACC DET RESET
LC75010 CAR AUDIO DSP
MB90438LS 16-bit Proprietary Microcontroller CQ-C7401W
TA8264AHQ BTL × 4 Ch Audio Power IC
784225YGC146 CQ-D5501N
A5657N System Power Supply IC for Car AV Systems
HIP4081AIP IC DRIVER FULL-BRIDGE 20-DIP
MR4040 ШИМ-контроллер со встроенным ключом, 900В, 180Вт.
AN7134NR DUAL 7.5W AUDIO POWER AMPLIFIER
HA13164AN Multiple Voltage Regulator
AN7062 High Voltage Input Amplifier Circuit for Hi-Fi Power Amplifier
BA5992FP Драйвер двигателя DVD, 5 каналов
5LS308 C1AB00002076
BD6904FP драйвер трехфазного двигателя и драйвер двигателя загрузки
A030DW01 V0 59.03A33.001 | 59.03A33.T01 |
LG96244QS11-1A | 307294000 |
A030DL01 | |
TD030MHEA2 | 304000028_A G/P |
TD035SHEB4 | 2000000052 |
PT035TN1+Touch | 20000175-11 |
PW035XU1(LF) PMV035E3GC | |
PW035XS4(LF) PMV035EGC | |
TJ035NC06AA (035WUE001)990000738 | 304000220A |
035WUE001 | 304000220A |
LPH8874-1 | |
99000475P 837N1AA11 40400010-GP | 800x480 |
CYX-BLG8736B-V1-100921 | FPC8736A-V1-B |
S95278A-V02-SG-080512 N0805-02-46 | FPC-S95278-1 V01 |
A040FL01 V.2 | 54.20019.013 |
PW045XS1(LF) DGL-140CF-B | |
EDTCA39QCF | 39N T LNF0025 |
A050WVN04A0 800*480 | 32-D038784 CMO T50W |
A061VW01 V0 59.06A16.003 | 69.06A16.T01 |
TM062RDS01 | |
FF062D-G0 | |
HSD062IDW1-0A02 | 721H410012-A0/E203460 |
HSD062IDW1 Rev:0-A02 | 721CR60012-A0/E318184 CHD-4 |
C065GW01 V0 (AUO065B1G) 59.06.C01.003 | 65.06A05.002 |
PW065XS1(LF) 1200x234 | |
LTA065B626A 1200x234 | |
TM068RDS01/02 | 15470000991 |
LTA070B383A | LNF0079 |
CPT7ALCM-15LED | 730100048 |
C070FW02 V2 | 69.07C04.001 |
C070FW03 V0 480х234 CCFL 26 pin | 69.07C05.002 |
LT070W02-TME2/QZ.F.224-070-09F | 6850L-0133A FPC LB070WO2 |
A070FW03 V8 A070FW00 V7 59.07A04.024 | 69.07A04.T01 |
A070FW03 V8 59.07A04.024 | |
A070FW00 V7 | 69.07A04.T01 |
A070FW03 VD 59.07A04.035 | 59.07A04.035 |
A070FW05 V3 | 59.07A14.005 |
A070WVN07F1 | |
AT070TN07 V.A | 20000161-12 |
AT070TN7/AC070BA009 | 417000010304 |
AT070TN84 V.1 +Touch HLD-TP-1706 | 20000531-00 |
AT070TN94 +Touch HLD-TP-1166-R1 6mm 50 pin | 20000600-22 800x480 шл 65мм |
TM070RDH01 | |
TM070RDH12 / HSD070IDW3-XHS | 1540231540 |
TX18D11VM1CAA | |
LW700AT9005 | 418000022303 |
B/L070WA08B-3S | |
FB-D027-21 HSD.0-LED12+R4 | 7214H00B35-A0/20000864-00 |
HSD070GT09-HL/HSD070GT09-AT | 721Q510D35-A0/E250743 |
XFA070LED1170-S | |
HSD070I651 | 721H430A35-A0 |
HSD7DLCM-21LED | 7214H10C44-A0 |
HSD1+1LCM-21LED | FPC-HSD070-3H |
HSD1+1LCM-21LED | FPC-H0070W3-A2/FPC-HSD070-3H |
HSD070IDW1 REV 0-E11 | 7214H10008-A1 |
HSD070IDW1 Rev 0-D00 | |
HSD070IDW1 Rev 0-D00+Touch R-1052R1 | |
INNOLUUX7DLCM-27LED | 7DD1+1 FPC/AT070TN92 V.X |
AT080TN03 V.1 /V.2 | 20000036-32 20000137-02 |
AT080TN64 | 20000938-00 |
A080SN01 V.0 59.08A07.004 | 69.08A07.003 |
A080SN03 V0 800x600 | 54.20024.100 |
TL080SN100-V0 TM080SFFH01 800x600, 50pin | 1540009312 |
AT090TN10 50pin 800x480 | 20000938-30 |
HLY090ML106-15A 26pin | 721H10C19-A1/721H440B19-A1 |
LTA090A055F | |
LTA090A144A | |
CLAA090JB01CW 26pin | 7610007175/E248908 |
CLAA090JB02CW 26pin | 7610007175/E248908 |
LQ092Y3DG01 X0003TP TW10794V-0 | QPWM0057TPZZ-99BN |
H-H101D-18W | H-H10118FPC-C0 |
Тачскрины Pioneer,Clarion,Prolody,Philips,Sony и другие Оригинальный. Новые.Резистивные.Шлейф только снизу. Размеры - 192х116mm/165x100mm/164,5х99,8mm/163х97,5mm/ 161x96.5mm/161X93mm/160x90mm/159x94mm/159x89mm/155x88mm/155x87mm/149х82.5mm/137*80 мм Pioneer AVH-3500/3550/3700/3750 AVH-(P)1400/1450/1490/2300/ P3200/3300/3400/3450/3490(DVD-BH-BT) AVIC-F900BT Sony XAV-65/68BT CLARION-NX-501/VX401-GPS Prology MDN-270/1360/1430/1710/1715/1725/2300/2310/2640/2650/2660/2670/ 2680 /2745/2750 /2800/2820/2900/2772/2770/2800 MPC-62 DNU-2610/2630/2650 DVS -270/1345/1440/1450T/2135/2140/2470 MDD-70/ 714/715/716/719/724/740/745/ DVU-600 /710 | |
МИКРОСХЕМЫ
PT6523
PT6578
SC75823E
LC75823E
MST720C-T-LF
MST717A-LF
MST726A-LF
IRM58M
T118FS
T118EL
T108
SPHE8281D
ZR36882ELCG
ES6629FF
F1C500
TDA7388
TDA7580
TB2929HQ
5LS308 C1AB00002076
