Важно! Обсуждаем сброс и решение проблем видеорегистраторов
SSDTUPS
  • 22 Авг 2020
Добрый. Пробую по UART подключиться не пускает.
U-Boot 2010.06 (Apr 14 2018 - 13:58:30)
Check Flash Memory Controller v100 ... Found
SPI Nor(cs 0) ID: 0xc2 0x20 0x17
Block:64KB Chip:8MB Name:"MX25L6406E"
CONFIG_CLOSE_SPI_8PIN_4IO = y.
at hifmc100_setTB() mid:0xc2,chipsize:0x800000 <no>.
at xm_get_macronix_type() cr:0x8.
at hifmc100_spi_nor_scan() eMXICFashType:2.
lk[7 => 0x400000]
SPI Nor total size: 8MB
In: serial
Out: serial
Err: serial
USB: scanning bus for devices... 1 USB Device(s) found
0 Storage Device(s) found
i:0, No usb storage device found!
PHY 0x02: OUI = 0x01F0, Model = 0x0F, Rev = 0x01
Net PHY: LAN8710
at higmac_demux() phy_intf:0 [0:mii,1:rmii,2:rgmii];MAC_TXCKOUT_MUX_REG value:0x2 [1,rgmii;2,mii;3,rmii;]
change register for 8710
PHY reg: 0x12, value:0x62
CONFIG MII
ETH0: PHY(phyaddr=2, mii) not link!
higmac init fail!
Press CTRL-C to abort autoboot in 2 seconds8192 KiB hi_fmc at 0:0 is now current device
CFG_BOOT_ADDR:0x0
### /UbootLogo UbootLogoload complete: 40208 bytes loaded to 0x8e800000
jpeg decoding ...
<<addr=0x8e800000, size=0xb85f9, vobuf=0x8f000000>>
<<imgwidth=800, imgheight=600, linebytes=1600>>
decode success!!!!
decode jpeg success.
decode jpeg ImgWidth:800,ImgHeight:600!
at do_jpgd() <VO_OUTPUT_800x600_60>.
OpenDev vo:0 intf_type:36 out_sync:16
OpenDev vo:1 intf_type:1 out_sync:0
srcAddr 0x82000000, dstAddr 0x82000000
find_squashfs_file: name bin, start_block 0, offset 1311, type 1
find_squashfs_file: name boot, start_block 0, offset 1403, type 1
read inode: name boot, sb 0, of 1403, type 1
find_squashfs_file: name zImage.img, start_block 0, offset 1343, type 2
read inode: name zImage.img, sb 0, of 1343, type 2
### FS load complete: 1593968 bytes loaded to 0x82000000
## Booting kernel from Legacy Image at 82000000 ...
Image Name: linux
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 1593904 Bytes = 1.5 MiB
Load Address: 80008000
Entry Point: 80008000
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Строка Press CTRL-C to abort autoboot in 2 seconds появляется но не реагирует. Соединения перепроверял.
Может как то заблокировано?
    Вопросы по Обсуждаем сброс и решение проблем видеорегистраторов Если у вас есть вопрос по ремонту и определении дефекта, Вы должны создать свою, новую тему в форуме. По этой теме уже рассмотрены следующие неисправности:
    Как мне дополнить свой вопрос по теме Обсуждаем сброс и решение проблем видеорегистраторов?
    Ответ в тему Обсуждаем сброс и решение проблем видеорегистраторов как и все другие советы публикуются всем сообществом. Большинство участников это профессиональные мастера по ремонту и специалисты в области электроники.
satarmen
  • 24 Авг 2020
Приветствую всех.
Помогите сбросить пароль NT-9826CE-F1.
Попробывал код 0474391007013418 пишет Неверный пароль
    221,7 КБ · Посмотрено: 23
    243 КБ · Посмотрено: 26
    231,8 КБ · Посмотрено: 29
    218,2 КБ · Посмотрено: 26
    220,5 КБ · Посмотрено: 26
    214,7 КБ · Посмотрено: 24
    204,8 КБ · Посмотрено: 22
sania-owner
  • 24 Авг 2020
satarmen сказал(а):
Приветствую всех.
Попробуй эту утилиту  ссылка скрыта от гостей
satarmen
  • 24 Авг 2020
sania-owner сказал(а):
satarmen сказал(а):
Приветствую всех.
    90,7 КБ · Посмотрено: 30
sania-owner
  • 24 Авг 2020
satarmen сказал(а):
Приветствую всех.
SSDTUPS
  • 28 Авг 2020
Добрый день. Выпало время для дальнейшего восстановления аппарата. Апарат запустил, пока буду тестить.
Скачал общий дамп с  ссылка скрыта от гостей  от пользователя "Sonya" за что ему большое спасибо за подсказки. Со своего дампа выдернул крипту и вставил в его дамп. Апарат завелся все как и должно работать. Потестирую пока с жестким на запись.
stankodoc
  • 29 Авг 2020
Добрый день. Не работает ссылка на прогу  ссылка скрыта от гостей  . Можете отправить на мыло?
Casper
  • 29 Авг 2020
stankodoc, ты с кем разговариваешь?
Влвдимир
  • 15 Сен 2020
Подскажите как скинуть пароль к HIQ-9304 MTH PRO
    5,9 МБ · Посмотрено: 26
    9,1 МБ · Посмотрено: 27
Casper
  • 15 Сен 2020
Влвдимир, самим, что сделано.
Влвдимир
  • 15 Сен 2020
Батарейку вынал,дата время не скидывается. перемычек нет. 2 генератора паролей не помогли,приложение электролампочного хамелеона из юзал,не сбросилось.По лану к SADPTool не конектится.Что можно попробовать. Вот сейчас ищу по интернету какие ножки замыкают чтоб дату время хотяб скинуть.Программатора нет но и прошивку к этому аппарату не знаю где найти. наверное над поковырять глубже.процессор посмотреть прошивку с аналога подобрать
sania-owner
  • 15 Сен 2020
Это обычный XMEYE с другим GUI. Потому 5 раз ввод любого пароля и фото результата выложите
Влвдимир
  • 16 Сен 2020
5 раз не правильный пароль. С шестой попытки блок..Интересно GUI можно обычную залить.Поглядел что такое GUI! Извиняюсь за возможно глупые вопросы. Это первый такого рода девайс в руках.Подумал,поискал,разобрался, в утиль платку) на алишки цена 1700р.один в один
    8,4 МБ · Посмотрено: 24
    8 МБ · Посмотрено: 24
    6,6 МБ · Посмотрено: 25
    6,6 МБ · Посмотрено: 21
    7,3 МБ · Посмотрено: 18
    6,1 МБ · Посмотрено: 19
sania-owner
  • 16 Сен 2020
Вот коды на 13 число:
q8GAcp1201 или q8GAcp
14 число:
kcYa1y4808 или kcYa1y
если не сработает напиши мне в личку  ссылка скрыта от гостей
VPlotko
  • 20 Сен 2020
Доброго времени суток.
Продублирую в этой теме.
Умер NOVUS NDR-BA3104-II. Пищал без признаков жизни.
На программаторе залили выложенный ранее дамп 2304SS-C. Писк снялся, но виснет на заставке. Может есть у кого-нибудь рабочий под этот аппарат. Заранее благодарен откликнувшимся.
Фотки платы и процессора прилагаются. Убитый дамп тоже приаттачен.
    2 МБ · Посмотрено: 10
    1,6 МБ · Посмотрено: 10
kuc4in
  • 29 Сен 2020
Видеорегистратор IMPREZA STS SDVR-401-100M​
Попало ко мне сие чудо. Инструкции нет, пароль не знаю. Пробовал все возможные пароли - не подходят. Батарейку выдергивал, зажимал reset - дата и время сбрасываются, а пароль так и не подходит. Ввод только цифры, генераторы пробовал не подходят.
Схемы:
S29GL256P, ATMLH004 (в просторах интернета вычитал что это Atmel AT24C04B, но считать ее не получилось)
На S29GL256P замыкал контакты 29-31, без результата... 29-33 перегрузился но ничего не изменилось...
Помогите узнать пароль по умолчанию, или сбросить его
    5,7 МБ · Посмотрено: 14
    5,5 МБ · Посмотрено: 14
    4,8 МБ · Посмотрено: 11
    3,9 МБ · Посмотрено: 10
    4,3 МБ · Посмотрено: 12
Userr1981
  • 10 Окт 2020
Доброго времени суток! Прошу помощи в сбросе пароля. Регистратор Techvision tv-7604he, при снятии батарейки дата сбрасывается на 01.01.1970, калькуляторы-генераторы пробовал, в телнете пишет неправильный логин, uart ещё не подключал, фото и дамп 25q64 прилагаю, хелп плиз. И ещё при вводе логина и пароля в локале больше 10 символов не лезет.IMG_20201010_135327.jpgIMG_20201010_135816_HDR.jpgIMG_20201010_140140_HDR.jpgIMG_20201010_141037_HDR.jpgIMG_20201010_142111_HDR.jpgIMG_20201010_140243_HDR.jpgIMG_20201010_140710_HDR.jpg
  • 25q64 rodnoytechvision tv7604he.zip
    7,2 МБ · Посмотрено: 3
sania-owner
  • 10 Окт 2020
Это регистратор Juan.
Программа для сброса  ссылка скрыта от гостей
Userr1981
  • 10 Окт 2020
Спасибо, конечно, но то ли мышки не те, то ли я что-то не так делаю
sania-owner
  • 10 Окт 2020
Попробуйте этот вариант  ссылка скрыта от гостей
Для доступа по телнету root:juantech
Userr1981
  • 10 Окт 2020
Ура, теперь хоть пароль есть! Спасибо
Userr1981
  • 11 Окт 2020
Не могу найти файл конфигурации, иду спать!
Userr1981
  • 11 Окт 2020
Вот лог по uart
Вот ответ printenv, я так понимаю создается 6 разделов?
  • Текстовый документ.txt
    45,2 КБ · Посмотрено: 7
  • printenv.txt
    1,2 КБ · Посмотрено: 5
Userr1981
  • 11 Окт 2020
Спешу отписаться, нашел пароль!
Userr1981
  • 11 Окт 2020
Слил дамп программатором, хотя через uart тоже нормально сливается. Исходя из лога u-boot, нашел адрес с которого начинается конфигурационный раздел в дампе, а там пароль!
1908
