natali сказал(а):
natali"]Я просил ,в теории объяснить мне как работает первичка,просьба актуальна.
Есть-же описание в обменнике.
POWER SUPPLIES
This CTV employs two power supplies, which are similar in design to previous models. The Power Supply located on the sub-board 'PWB-C' will supply the Dolby Prologic circuit and Audio Output Stages that are also located on PWB-C. Similar to the CS, CA10 and CW100 chassis, when this receiver is in standby mode, the outputs from the power supplies (including the supply to the Main Microprocessor circuit) will be muted by removal of the FET gate voltage. The Slave Processor (IC702) performs standby and timer on/off functions, additionally in this chassis the Slave Processor will control the degauss circuit.
START UP OPERATION
Rectified and smoothed mains voltage (+320VDC) is used to provide the start up voltage to the gate of Q701. Current flows via R713 and R714 charging C714 (C714 earth return is via T701 secondary winding pins 14 and 15). This allows a voltage at the gate of Q701 to rise slowly (Q701 will turn on when the gate reaches 4.5V). D712 ensures that Q701 gate voltage will not exceed 15V, preventing the FET being damage by voltage spikes. When Q701 turns on, current will flow from the bridge rectifier, through T701 primary winding (pins 12 and 17), Q701 source/drain junction, returning to the bridge rectifier via, R716. The current flowing through T701 primary will induce an e.m.f. into secondary windings
The e.m.f. produced at T701 pin 15 will flow through D715 and the collector emitter junction of the opto-coupler (IC705), charging C713. Once the charge on C713 reaches 0.6V Q703 will turn on, connecting Q701 gate to ground, turning Q701 off and discharging C714. At this point, the magnetic field within T701 will collapse causing the e.m.f at pin 15 to go negative turning Q703 off. Q701 will not turn on until sufficient charge has built up on C714. However, at this time the negative plate of C714 is approximately -12V; due to the collapsing field within T701. This results in the time period required to build sufficient charge on C714 to bias Q701 on increasing i.e. Q701 off time = the
time for the back 'e.m.f.' to decade to zero, plus C714 charge time form zero to 4.5V approx.).
VOLTAGE REGULATION
The feed back through the opto-coupler (IC705), provides voltage regulation. The +150V line is used as the controlling source and a reference is provided from the +16v supply.
Increase in load As the +150V rail falls due to an increase in load (high beam current), the trigger voltage of IC706 will fall, increasing IC706 cathode voltage, reducing the current flowing through the LED section of IC705. This has the effect of decreasing the conduction of the photo transistor part of IC705. This increases the voltage drop across the collector/emitter junction; thereby increasing the time taken to charge C713, delaying the point when Q703 turns on, turning Q701 off. Energy is transferred across T701 for a longer period, increasing the HT rail; hence, the frequency of the power supply will fall.
Decrease in load
As the +150V rail increase due to a decreasing load (low beam current), the trigger voltage of IC706 will rise decreasing IC706 cathode voltage which increases the current flow through the LED section of IC705. This has the effect of increase the conduction of the phototransistor within IC705. Thereby decreasing the voltage drop across the collector/emitter junction; which will decrease C713 charge time, advancing the point when Q703 turns off, turning off Q701 to turn on earlier. Energy is transferred across T701 for a shorter period, decreasing the HT rail; hence, the frequency of the power supply will increase. It can now be seen that this is a variable frequency power supply, typically the frequency will vary between 144kHz (no load) to 70kHz (high beam current).
OVER-VOLTAGE PROTECTION
D716 is used to prevent the secondary rails increasing beyond safe limits. If the e.m.f. at T701 pin 15 increases beyond safe limits D716 will conduct, increase the voltage across C713, thereby reducing its charge time, turning on Q703 earlier, turning off Q701, allowing the HT rails to fall. Once the HT starts to fall Q703 will turn off allowing the Power Supply to restart.
OVER-CURRENT CONTROL
Over current control is performed by monitoring the amount of current passing though the R716 (Q701 drain, earth return resistor). This resistor is an extremely low value, 0.47R, and Ohms Law dictates that the current flowing through it must be proportional to the voltage across it. The base voltage required for turning on Q702, is +0.6V then the voltage across R706 to ‘trip’ the circuit would have to be approximately 1.2V (this includes 0.6V drop across D720). Therefore a current of 2.5amps is required to operate the trip circuit.
The voltage developed across R716 will turn Q702 on via D713 and R719. Once Q702 turns on, C714 will discharge rapidly, removing Q701 gate bias. Q701 will remain turn off until the current through R716 decreases. At this point Q702 turns off allowing C714 to charge turning on Q701. If the overload is still present then Q702 will turn on again, thus repeating the cycle. In the case of a short circuit line output transistor the power supply will keep repeating this cycle. The HT rail and base of Q702 (if measured with a standard DVM) would normally read zero volts and the power supply appears not to be working. On some occasions when the short is not as heavy then a whistle may be heard.
