Сервис мануал и схема телевизора SONY KDL-19L4000; KDL-26L4000
Файл в формате PDF на английском языкеСостав:
- MainBoard: 1-857-143-B FLX00018285-101 - Ver 3.03
- Chassis: NEX
- Inverter (backlight): INV26S10A REV0.4
- PWM Inverter: OZ9966SN (24)
- MOSFET Inverter: AOD486A
- Trans Inverter: LT-U2610-1(2)
- Power Supply (PSU): DPS-175JP G1D
- PWM Power: L6562D (PFC), DLA001D (PWM Resonant), MIP2H2 (Standby)
- MOSFET Power: 2SK3569, STP20NM60FP
- IC MainBoard: PNX8541E1/2009, E5116AJBG, CXB1444R
- Tuner: ENG37E10K
- Control: RM-ED014
Модели:
- SONY KDL-19L4000
- SONY KDL-26L4000
TABLE OF CONTENTS
- 1. GENERAL
- Caution
- Specifications
- Connectors
- Self Diagnosis
- 2. DISASSEMBLY
- 2-1. Stand & Rear Cover Removal (19 inches)
- 2-2. Rear Cover Removal (26 inches)
- 2-3. Stand Removal (26 inches)
- 2-4. Loudspeaker Removal
- 2-5. Switch Unit Sub Assy Removal
- 2-6. H5 Board Removal
- 2-7. B Board Removal
- 2-8. Power Board Removal (19 inches)
- 2-9. Power Board Removal (26 inches)
- 3. ADJUSTMENTS
- 3-1. How to enter the Service Mode
- 3-2. Service Menu Structure
- 3-2-1. Service General Menu
- 3-2-2. Service Alignments Menu
- 3-2-3. Virgin Mode
- 3-2-4. OSD Service Menu
- 3-2-5. Country Selection Menu
- 3-2-6. Reset
- 3-3. White Balance Adjustment
- 3-3-1. Preparation
- 3-3-2. “COOL” White Balance Adjustment
- 3-3-3. “NEUTRAL” White Balance Adjustment
- 3-3-4. “WARM” White Balance Adjustment
- 4. DIAGRAMS
- 4-1. Block Diagram 1 (19 inches)
- Block Diagram 2 (26 inches)
- 4-2. Circuit Board Location
- 4-3. Schematic Diagrams and Printed Wiring
- Boards
- B Board Schematic Diagram
- G1D Board Schematic Diagram (26 inches)
- G Board Schematic Diagram (19 inches)
- H1 Board Schematic Diagram
- H5 Board Schematic Diagram
- B Printed Wiring Board
- G Printed Wiring Board (19 inches)
- G1D Printed Wiring Board (26 inches)
- H1 Printed Wiring Board
- H5 Printed Wiring Board
- 5. EXPLODED VIEWS
- 5-1a. Chassis (19 inches)
- 5-1b. Chassis (26 inches)
- 5-2. Bezel & Stand Assy
- 5-3a. Rear Cover & Power Supply Cords (19 inches) 44
- 5-3b. Rear Cover & Power Supply Cords (26 inches) 45
- Accessories & Connectors
- Remote Commander
Информация Ремонт ТВ SONY Программный ремонт Ремонт блока питания Шасси телевизора Ссылки на схемы
HYNNDAY H-LED43F502BS2S, main T.MT5510S.82, ищу прошивку EMMC U8 KLM8G1GETFТелевизор висит на заставке "Android". Пробовал подкидывать USB прошивку для данной модели. Запрашивал у производителя, по серийнику. Прошивка не подхватывается. При попытке прошить начинает перемигиваться красным- синим светодиод. Через несколько минут телевизор отключается...Genius
Решено SKYLINE 58U7510 led шасси HK T.RT.2851P839 необходима схемаСветики по догадкам скорее всего 6-ти вольтовые 3030 будут, тренд такой. Удачи.И90
Решено Sony KDL-32W4000 ищу прошивку NAND, EEPROMТелевизор Sony KD-L32W4000 Chassis EG1L Main 1-875-656-12 Процессор под радиатором NAND K9F5608U0D eeprom 24C32WP (возле тюнера) Панель LTY320HA02 Не работает кнопка HOME ни с пульта, ни с панели управления. Соответственно настроить на каналы телевизор не возможно. Через HDMI...athlon1000
ASANO 43LU8010T.шасси TP.MT5522S.PC822. Прошивка USB. Телевизорhttps://remont-aud.net/dump/lcd_pdp_tv/po_shassi/asano_43lu8010t_shassi_main_board_tp_mt5522s_pc822/335-1-0-108866rammer
Prima LC-26HU18GBУ блока должен быть партномер, вот и огласите его. Схема есть в сервисных мануалах на этот брэнд.И90
LG 43LM5500PLA ищу дампИщу дамп на LG 43LM5500PLA. Плата LD95H-EAX68406103. ТВ секунд 20 висит на заставке, потом черный экран. Хочу подкинуть заведомо исправный дамп, там видно будетmyth
