Инструкция по ремонту телефона Sony Ericsson C903
Файл в формате PDF на английском языкеСодержание:
ABOUT
- Contents
- Equipment List
TROUBLESHOOTING
- Power On/Off Problems
- USB and Software Flash Problems
- Dead Phone Problems
- Display Problems
- Display Illumination Problems
- Opto Sensor Problems
- On-Off Key Problems
- Numeric Keypad Problems
- Navigation Keypad Problems
- Volume Up and Down Button Problems
- Camera Button Problems
- Play & Camera Mode Button Problems
- Navigation Keypad LED Problems
- Numeric Keypad LED Problems
- Camera Button LED Problems
- Tally LED Problems
- Trickle Charge LED Problems
- Flash LED Problems
- Camera Lens LED Problems
- Camera Cover Detect Problems
- Main Camera Problems
- VGA/VTF Camera Problems
- Data Communication Problems
- Charging Problems
- USB/VBUS Charging Problems
- SIM Problems
- Memory Stick Problems
- Microphone Problems
- Earphone Problems
- Loudspeaker Problems
- Handsfree Aux Earphone Problems
- Handsfree Aux Microphone Problems
- Handsfree Connection Problems
- FM Radio Problems
- FM Radio Antenna Problems
- Bluetooth Problems
- GSM Network Problems
- WCDMA Problems
- A-GPS Problems
- Accelerometer Problems
- Vibrator Problems
- Real Time Clock Problems
- Slide Sensor Problems
- TV Out Problems
- System Connector Protection Test
- Current Consumption Test
- Backup Capacitor Test
- Charging Test
- ASIC Revision Test
- Measurement Points Pictures
MEASUREMENT POINTS
- Primary Side
- Secondary Side
- Camera SIM FPC
- Main Flex Assy FPC
- Navigation Keypad FPC
- Keypad FPC
- Top Schematic
- Audio Top
- Audio Analog
- Audio Digital
- Audio FM Radio
- Application & System Performance Top
- System Top
- System Control - Clocks & Resets
- System Memories
- System PoP IF
- Power Top
- Power Regulators & Charging
- Power Imaging
- Power ASICs
- Connectivity Top
- Connectivity Top
- Connectivity I2C Inter-Integrated Circuit; Последовательная асимметричная шина для связи между интегральными схемами. Использует линии связи (SDA и SCL) & ADC
- Connectivity Cards
- Connectivity
- Imaging Top
- Imaging Display
- Imaging Camera
- Imaging Camera
- Imaging LMU
- Imaging Flash LED
- Access Top
- Access GSM & UMTS
- Access Bluetooth
- Access AGPS
- Camera SIM FPC
- Keypad FPC
COMPONENT OVERVIEW
- Primary Side
- Secondary Side B - C
- Secondary Side L - Z
FUNCTIONAL OVERVIEW
- Technical Description
- Platform Block Diagram 103
- Block Diagram Power Distribution
- Block Diagram Clocking Concept
SUPRA STV-LC60GT5000U Ищу файл прошивки для панели V580DJ4-QE1 Rev.T4В сервисном меню нашел , что тип панели меняется через загрузку файла панели по USB. Factory menu--->Other--->Project ID ? Спасибо за ответ. Отпишусь через пару дней, сам рухнул с температурой.AndreySk
Решено UPS FSP EP1500 (ppf9000105) требуется схемаОт FSP тоже ответа нет, тему придётся закрыть.AZrx
SHARP LC60LE822ERU Ищу прошивку на телевизорИщу прошивку на телевизор LC60LE822ERU (майн DKEYDF455FM07)родную потеряли в прежнем месте ремонта, залили с SHARP_LC-40LE810E не включается. Пытался найти родной майн DKEYDF455FM07 не удачно.Генерал
Решено Rolsen RL-32L1002U MST6M48 прошивка U11 25q32Одолел гада. Оказывается в этих шасси используется 2 вида ОЗУ. Следовательно и прошивки разные, + несколько видов панелей. В общем перепаял ОЗУ с мертвой платы и забил прошивку нужную . Все поехало.LARTER
SHARP LC60LE822ERU Ищу прошивку на телевизорГенерал, а зачем у нас вот этот раздел ? :pain25: Был бы рядовой... А Генералу типа все позволено... где снял штаны, там и туалет. https://monitor.net.ru/forum/threads/533199/ФАРТ
