AIWA VX-D2120K (Service Manual) | Схема телевизора
  • , Схема и сервис мануал телевизора AIWA VX-D2120K
Сервис мануал и схема телевизора AIWA VX-D2120K​
Какая схема и сервис мануал телевизора AIWA VX-D2120K
TABLE OF CONTENTS
  • SPECIFICATIONS
  • TABLE OF CONTENTS
  • SERVICING NOTICES ON CHECKING
  • DISASSEMBLY INSTRUCTIONS
  • REMOVAL OF MECHANICAL PARTS AND P.C. BOARDS
  • REMOVAL OF DECK PARTS
  • REMOVAL OF ANODE CAP
  • KEY TO ABBREVIATIONS
  • SERVICE MODE LIST
  • PREVENTIVE CHECKS AND SERVICE INTERVALS
  • NOTE FOR THE REPLACING OF MEMORY IC
  • SERVICING FIXTURES AND TOOLS
  • PREPARATION FOR SERVICING
  • VCR TEST TAPE INTERCHANGEABILITY TABLE
  • MECHANICAL ADJUSTMENTS
  • CONFIRMATION AND ADJUSTMENT
  • CONFIRMATION AND ADJUSTMENT OF TAPE RUNNING MECHANISM
  • MECHANISM ADJUSTMENT PARTS LOCATION GUIDE
  • ELECTRICAL ADJUSTMENTS
  • ADJUSTMENT PROCEDURE
  • BASIC ADJUSTMENTS
  • ELECTRICAL ADJUSTMENT PARTS LOCATION GUIDE
  • PURITY AND CONVERGENCE ADJUSTMENTS
  • TROUBLESHOOTING GUIDES
  • IC DESCRIPTIONS
  • SERVO TIMING CHART
  • SYSTEM SWITCH MODE
  • SEMICONDUCTOR BASE CONNECTIONS
  • BLOCK DIAGRAMS
  • TV
  • Y/C/AUDIO/HEAD AMP
  • MICON/OPERATION
  • IF/21PIN/IN/OUT/POWER
  • T'TEXT
  • PRINTED CIRCUIT BOARDS (OPERATION/FRONT JACK/DECK)
  • OPERATION SCHEMATIC DIAGRAM
  • FRONT JACK SCHEMATIC DIAGRAM
  • DECK SCHEMATIC DIAGRAM
  • PRINTED CIRCUIT BOARDS (SYSCON/IF)
  • Y/C/AUDIO/HEAD AMP SCHEMATIC DIAGRAM
  • MICON SCHEMATIC DIAGRAM
  • CHROMA SCHEMATIC DIAGRAM
  • 21PIN IN/OUT SCHEMATIC DIAGRAM
  • POWER SCHEMATIC DIAGRAM
  • SOUND AMP SCHEMATIC DIAGRAM
  • T'TEXT SCHEMATIC DIAGRAM
  • IF SCHEMATIC DIAGRAM
  • PRINTED CIRCUIT BOARDS (MAIN/CRT/POWER SW)
  • DEFLECTION SCHEMATIC DIAGRAM
  • TV POWER SCHEMATIC DIAGRAM
  • CRT SCHEMATIC DIAGRAM
  • INTERCONNECTION DIAGRAM
  • WAVEFORMS
  • MECHANICAL EXPLODED VIEW
  • MECHANICAL REPLACEMENT PARTS LIST
  • ACCESSORY REPLACEMENT PARTS LIST
  • CHASSIS EXPLODED VIEW (TOP VIEW)
  • CHASSIS EXPLODED VIEW (BOTTOM VIEW)
  • CHASSIS REPLACEMENT PARTS LIST
  • ELECTRICAL REPLACEMENT PARTS LIST
Информация Ремонт ТВ AIWA Программный ремонт Ремонт блока питания Шасси телевизора Ссылки на схемы
  • Общая информация
  • Ремонт телевизоров AIWA
  • Программный ремонт AIWA
  • Ремонт блока питания AIWA
  • Шасси в ТВ AIWA
  • Не нашли схему ?
  • Samsung HW Q600A
  • Skyworth 55G3A
  • Решено TOSHIBA 40L7356RK прошивка через USB
  • GRUNDIG 40GUS8679 Sidney нужна прошивка по USB
  • Решено TCL L55E5690UDS прошивки спиай и еммс
  • Hyundai H-LED50EU7008 прошивка
  • Нужна Схема робота пылесоса Midea VCR16
АЛИБАБА
Скачивания
37
Посмотрено
969
Первый выпуск
Обновление
Рейтинг
Оценок: 0
Другие файлы АЛИБАБА
  • LG 32LB628U-ZB
    Прошивка телевизора LG 32LB628U-ZB Main Board: EAX65388005(1.0) Eeprom: 24C256 SPI Flash: W25Q80V NAND Flash: H27U1G8F2CTR Фото основной платы EAX65388005 (1.0)
  • LG 42LV3551-ZA
    Прошивка телевизора LG 42LV3551-ZA Main Board: EAX64272802(0) LCD Panel: T420HW08-V9 SPI Flash: W25Q80BVSIG NAND Flash: HY27UF081G2M Фото основной платы EAX64272802(0)
  • LG 42PN450B-ZA
    Прошивка телевизора LG 42PN450B-ZA Main Board: EAX65071308(1.2); EAX65071306(1.0) PDP Panel: PDP42T40010 Eeprom: 24C256 SPI Flash: MX25L8005 Фото основной платы EAX65071308(1.2)
  • LG 32LB565U-ZQ
    Прошивка телевизора LG 32LB565U-ZQ Main Board: EAX65388006(1.0) LCD Panel: NC320DXN SPI Flash: 25L8006E Фото основной платы EAX65388006 (1.0)
  • ORION OLT-24602
    Прошивка телевизора Orion OLT-24602 Main Board: TP.MS3463S.PA63 Version: V1R06 LCD Panel: V236BJ1-P03 SPI Flash: GD25Q64 Фото основной платы TP.MS3463S.PA63
  • ORION LED4063
    Прошивка телевизора Orion LED4063 Main Board: HK-T.SP9202P63 LCD Panel: SHARP K4143TP SPI Flash: 25Q32 Фото основной платы HK-T.SP9202P63
Поделиться ссылкой на файл
