Сервисный мануал и схема принтера HP LaserJet 1150; 1300; 1300n
Файл в формате PDF на английском языкеContents
- Figures
- Tables
- 1 Product information
- Introduction
- Hardware description
- Firmware description
- Product specifications
- Model and serial numbers
- Overview of printer
- Front and side view
- Back and side view
- Warranty statement
- Extended warranty
- Limited warranty for print cartridge life
- Print cartridge information
- Print cartridge date stamp
- Refilled print cartridges
- HP LaserJet printing supplies
- HP printing supplies returns and recycling program information
- Material safety data sheet
- 2 Installation and operation
- Operating environment
- Identifying printer components
- Printer control panel
- Control panel light patterns
- Selecting media
- Loading media
- Printer output paths
- 3 Maintenance
- Life expectancies of components
- User-replaceable parts
- Replacing the printer pickup roller
- Replacing the printer separation pad
- Cleaning the equipment
- Cleaning the print path
- Cleaning the print cartridge area
- Cleaning the printer pickup roller
- Cleaning the printer separation pad
- 4 Operational overview
- Basic functions
- Formatter system
- Control panel
- EconoMode
- MEt
- Enhanced I/O
- PJL overview
- Printer functions
- Engine control unit/power system
- Image formation system
- Printer paper-feed system
- Jam detection
- Basic sequence of operation (formatter-to-printer)
- 5 Removal and replacement
- Removal and replacement strategy
- Required tools
- Before performing service
- Print cartridge
- Parts removal order
- Differences between the printers
- Locating the printer differences
- Covers
- Left side cover
- Back cover
- Right side cover
- Top cover
- Control panel assembly
- Front cover assembly
- Internal assemblies
- Transfer roller
- Formatter (hp LaserJet 1300 series)
- Formatter (hp LaserJet 1150 printer)
- Laser/scanner assembly
- Fuser assembly
- Output rollers
- E-label assembly (hp LaserJet 1300 only)
- Motor
- Solenoid
- Fan assembly
- Right plate assembly
- Pickup assembly
- Pickup roller shaft
- Paper lift plate assembly
- Left plate assembly
- Bottom assemblies
- ECU
- Paper feed assembly
- Paper-feed roller
- 6 Troubleshooting
- Basic troubleshooting
- Errors
- Control panel light messages
- Fatal error secondary messages
- Accessory error secondary messages
- Checking the print cartridge
- Solving image-quality problems
- Solving paper-feed problems
- Functional checks
- Engine test
- Half self-test functional check
- Drum rotation functional check
- Heating element check
- High-voltage power supply check
- Paper path check
- Service mode functions
- NVRAM initialization
- Cold reset
- PJL software commands
- Troubleshooting tools
- Internal reports
- Repetitive image defect ruler
- Main wiring
- Locations of connectors
- Locations of LEDs, jumpers, and switches
- 7 Parts and diagrams
- Ordering parts and supplies
- Parts
- Related documentation and software
- Consumables
- Accessories
- How to use the parts lists and diagrams
- Common hardware
- Assembly locations
- Covers
- Internal components (1 of 2)
- Internal components (2 of 2)
- Left side plate assembly
- Right side plate assembly
- Electrical components
- Paper pickup assembly
- Paper feed guide assembly
- Fuser assembly
- Alphabetical parts list
- Numerical parts list
- Index
Решено Ищу схему на магнитолу LG SB 159 stmelkov66, тему закрой - https://monitor.net.ru/forum/threads/649799/segor
Сварочный аппарат Fubag IQ 160 схемаВсем привет. Помогите найти схему на сварочный аппарат Fubag IQ 160 . Попадаются "Fubag-и" но не IQ. В общих чертах по неисправноси - нет дежурного , при включении сетевого тумблера не вращается куллер и никакой индикации . Драйвер TOP246GN. Но это тема другого подраздела...Prorok
AKAI UA32LEZ1T2S Поделитесь пожалуйста прошивкой ТВДень добрый помогите с прошивкой для USB, может у кого есть? Поделитесь. ТВ Висит на загрузке андроит. ТВ AKAI UA32LEZ1T2S (думаю от других анологичных моделей должна подойти) MAIN P75-2841V6.0-A Матрица CX315DLEDM Привет друзья! Мне тоже очень нужна эта прошивка для AKAI...Furianin745
Panasonic TH-R42PV7 нужна прошивка через сд карту13 ошибка. Нужна прошивка через сд карту.telemaster1280
SAMSUNG UE46D8005YU ищю дамп emmcUE46D8005YU Lion18id,ты бы почитал в интернете по этим телевизорам серии D8000 и D7000 , глядишь и узнал бы что нужно указывать версию ПО из сервисного меню . Абы какой дамп работать не будет . Понятно почему нет дампов. хотя именно еммс нет на другие флешки...Lion18id
Решено NOMI 32HTS11 Нужен дамп под emmcRusliff, Я со всеми теликами на ты...... но не тут, запрещают мне на этом форуме помогать :gigi:Renegat
NOMI 32 HTS11 нужна прошивкаRusliff, Давай я за тебя напишу )) NOMI 32HTS11 Main TP.MT5510S.PB802 CPU MT5659DHNT Panel HV320WHB-N85 EMMC KLM8G1GEMERenegat
