Сервис мануал и схема монитора ACER AT4042P
Файл в формате PDF на английском языкеCONTENTS
- 1 SPECIFICATION
- 1-1 General Sepecificaation
- 1-2 Feature Summary
- 1-3 External Interface
- 1-3-1 Video/Audio Inputs
- 1-3-1-1 TV Antenna Interface
- 1-3-1-2 Component Intputs
- 1-3-1-3 PC Input
- 1-3-1-4 DVI input
- 1-3-1-5 SCART Input
- 1-3-2 Audio/Video Outputs
- 1-3-2-1 Composite Video Output
- 1-3-2-2 Analog Audio Output
- 1-3-2-3 Head Phone
- 1-3-3 Power Interface
- 1-3-3-1 Power Connector
- 1-3-3-2 Power Input Range
- 1-3-3-3 Power Consumption
- 1-3-4 Service Interface
- 1-4 User interface
- 1-4-1 Power Indicator
- 1-4-2 Remote Control Receiver
- 1-5 External Mounting Requirements
- 1-6 Environmental Requirements
- 1-6-1 Temperature Ranges
- 1-6-2 Humidity
- 1-6-3 Altitude
- 1-6-4 Vibration and Shock
- 2 Precautions and Notices
- 2-1 Precaution of assembly
- 2-2 Precaution of Operation
- 3 Operation
- 3-1 Operation of Remote Control Transmitter
- 3-2 Key function
- 3-3 OSD Main Explanation
- 3-3-1 Main Menu
- 3-3-2 Search Menu
- 3-3-3 Video Menu
- 3-3-4 Audio Menu
- 3-3-5 Time Menu
- 3-3-6 Setting Menu
- 3-3-7 Screen Menu
- 3-3-8 Pip Menu
- 3-8-1-1 PIP Input Mode
- 3-8-1-2 PIP Function Table List
- 4 Trouble shooting chart
- 4-1 PANEL Trouble shooting
- 4-2 Solution process of MGPC0
- 4-2-1 Panel cannot be lit up
- 4-2-1-1 Check peripheral circuits procedure
- 4-2-1-2 Check Image board procedure
- 4-2-2 Picture Display --Dynamic picture abnormal
- 4-2-3 DVI picture abnormal
- 4-2-4 Component picture abnormal
- 4-2-5 RGB Picture Abnormal
- 4-2-6 Video Picture Abnormal
- 4-2-7 DC Power Supply
- 4-3 TUNER&AUDIO BOARD FAULTS HANDLING
- 4-3-1 Check DC Power Supply
- 4-3-2 Tuner Faults Handling
- 4-3-3 Tuner&Audio Board Faults Handling
- 5 White-Balance Adjustment
- 5-1 Equipments list
- 5-2 Preparation and Adjustment process
- 6 DDC program and test
- 6-1 Equipments list and prepare
- 6-2 Program and test process
- 7 Flash Update
- 7-1 The list of Instrument
- 7-2 The operation explaining Flash Update
- 8 Software Administer Block diagram
- 8-1 Main Block diagram (Kernel part)
- 8-2 SOURCE key Block diagram
- 8-3 MENU key Block diagram
- 8-4 Mode Check Block diagram
- 8-5 SCART Key Choose Process
- 9 Block diagram & Explain
- 9-1 PDP block diagram and functions
- 9-2 Image board block diagram and signal introduce
- 9-2-1 Image board block diagram
- 9-2-2 Input signal introduce
- 9-3 TUNER board block diagram
- 10 Waveform of signal
- 10-1 Waveform of input signal
- 10-2 Signal waveform in the image board.
- 11 11Check and Measure
- 11-1 Image board
- 11-1-1 Power Check and Measure
- 11-1-2 Voltage value of IC necessary
- 11-2 AUDIO and TUNER Board CHECK
- 12 Mechanical Introduction
- 12-1 PDP Internal view
- 12-2 Mechanical of cabinet front disassembly
- 12-3 Disassembly and assembly
- 12-3-1 PDP stand removal
- 12-3-2 Back Cover Removal
- 12-3-3 Rear Low Cover removal
- 12-3-4 Main Board(MGPC) and TUNER AUDIO Board (TUPC)removal
- 12-3-5 PCB Plate Removal
- 12-3-6 Key Board Remove
- 12-3-7 Side AV Board Removal
- 12-3-8 Panel Module Removal
- 12-4 Panel Wiring diagram
- 13 PCB LAYOUT
- 13-1 Image broad PCB LAYOUT
- 13-2 TUNER board and AUDIO board PCB LAYOUT
- 14 Schematic diagram
Решено TOSHIBA 40L7356RK прошивка через USBlexa.smirnov84, здравствуйте. Написал на почту.Борис Горбунков
GRUNDIG 40GUS8679 Sidney нужна прошивка по USBВ тв GRUNDIG 40GUS8679 была заменена плата управления ZKR190R-3,V-0 Установили мейн ZKR190R-3,V-0 с GRUNDIG 49GUS86хх. Тв включается, есть заставка Grundig, но перевернутое двойное изображение. Нужна прошивка именно под мою модель тв. Серийный номер для поиска прошивки на фото.Serg*
Решено TCL L55E5690UDS прошивки спиай и еммсПрошивку купил но она не помогла толи в еммс дело то ли в процессоре.Ильшат
Hyundai H-LED50EU7008 прошивкаCharm, Помогите пожалуйста. Проблема с h-led43eu7008, аналогичная, как в шапке. 1680015982 Андрей-, Как решили проблему, поделитесь пожалуйста.xdemion
Схема и Биос на планшет Trekstor primetab t13bAlexandron, /forum/threads/204114/ В ЗАГОЛОВКЕ ТЕМЫ ОБЯЗАТЕЛЬНО УКАЗЫВАТЬ: - Тип разыскиваемого документа (Схема, Прошивка, и т.д.) - Тип аппарата (TV, VCR, Муз.центр, Автомаг. и т.д.)segor
