Сервис мануал и схема телевизора SONY KDL-26U2000; 32U2000; 40U2000
Файл в формате PDF на английском языкеСостав:
- Main Board: 1-871-490-11; 172783611; A-1202-962-A; I1205695A A1P
- Chassis: SE-1
- Inverter (backlight): KLS-400W2 Rev0.6
- PWM Inverter: BD9886FV (28), BA9201F (14)
- MOSFET Inverter: FDD6635 (3), FDD6637 (3)
- Trans Inverter: IT-136 071U
- Power Supply (PSU): 1-869-027-12 - A1169591D - G2
- PWM Power: MIP2H2 (Standby), CXD9841M, FA5501A (PFC)
- IC MainBoard: TDA9974AHS/8/12 , 4776 , 14052BG
- Tuner: BTP-HC401 (10)
- Control: Remote: RM-ED007, IR: 1-871-493-11 172783611
Модели:
- SONY KDL-26U2000 RM-ED007 AEP/UK
- SONY KDL-32U2000 RM-ED007 AEP/UK
- SONY KDL-40U2000 RM-ED007 AEP/UK
TABLE OF CONTENTS
- Caution
- Specifications
- Connectors
- Self Diagnosis
- 1. GENERAL
- 2. DISASSEMBLY
- 2-1. Stand Removal
- 2-2. Rear Cover Removal
- 2-3. Speaker Removal
- 2-4. A1/A1P Board Removal
- 2-5. BDT Board Removal
- 2-6. G1/G2 Board Removal
- 2-7. H1/H1P Board Removal
- 2-8. H2/H2P Board Removal
- 2-9. H3/H3P Board Removal
- 2-10. Bracket Removal
- 2-11. LCD Panel Removal
- 3. CIRCUIT ADJUSTMENTS
- 3-1. Electrical Adjustments
- 3-2. Test Mode 2
- 3-3. TT OSD Labels
- 4. DIAGRAMS
- 4-1. Block Diagrams(1)
- Block Diagrams(2)
- Block Diagrams(3)
- Block Diagrams(4)
- Block Diagrams(5)
- 4-2. Circuit Board Location
- 4-3. Schematic Diagrams and Printed Wiring
- Boards
- A1/A1P Board Schematic Diagram
- A1/A1P Printed Wiring Board
- BDT Board Schematic Diagram
- BDT Printed Wiring Board
- G1 Board Schematic Diagram
- (KDL-26U2000, KDL-32U2000)
- G1 Printed Wiring Board
- G2 Board Schematic Diagram (KDL-40U2000) 53
- G2 Printed Wiring Board (KDL-40U2000)
- H1/H1P Board Schematic Diagram
- H1/H1P Printed Wiring Board
- H2/H2P Board Schematic Diagram
- H2/H2P Printed Wiring Board
- H3/H3P Board Schematic Diagram
- H3/H3P Printed Wiring Board
- 4-4. Semiconductors
- 5. EXPLODED VIEWS
- 5-1. Chassis
- 5-2. Stand, Rear Cover, Power Leads
- 6. ELECTRICAL PARTS LIST
Информация Ремонт ТВ SONY Программный ремонт Ремонт блока питания Шасси телевизора Ссылки на схемы
Решено Sony KD-55XE9005 шасси 1-982-022-11 ищу прошивку IC4002 и IC4201.Прошивкой поделился участник форума, Благодарю.Jaret_DD
Ищу прошивку для ippon back verso 400Нужна именно прошивка, поскольку подобный контроллер чистый есть.sxemo-texnic
BBK 50LEX-7158 майн HK.T.RT2842P839 Ищу прошивку ЕММСhttps://aliexpress.ru/item/1005001703636249.html?sku_id=12000017220354545&spm=a2g2w.productlist.search_results.1.3080445fwiub4h нуу вот, с другими буквами.. думаю родной не далеко по цене ушел, вернее его вообще нету))ARTHUR
Philips 40pfl8008s замена процессора,патч дампа-ты невнимательно читаешь, Все я внимательно прочитал. Я же не думал, что ты решишь быть благотворителем. :pain25:ua3qgx
Решено Ищу схему переключетеля гирлянд "Домик-М".Дело сделано. Резисторы на у.э. поставил 200 Ом. По моим прикидкам 220-300 нормально будет. Однако, какие нашлись, такие и поставил. Лампочки переключаются, скорость регулируется.Afortunado
TOSHIBA 40LV703R Main Board: MST3740EU-T LCD Panel: LTA400HM02 T03Борис Горбунков, ты не увиливай, а решай проблему Господина. :goto: :gigi:Борис Горбунков
