Сервис мануал и схема телевизора SONY KDL-40W4500; 46W4500; 52W4500
Файл в формате PDF на английском языкеСостав:
- Main Board: 1-877-366-13 - A-1184-536-C BGE
- Chassis: EG1L 100Hz
- LCD Panel: LTY400HC02 001
- Inverter (backlight): SSB400W20S01 Rev 0.5
- PWM Inverter: LM2903
- Power Supply (PSU): IP5 1-876-467-21
- PWM Power: R2A20112 (PFC 16pin), CXD9841P (18), MIP2H2 (7)
- MOSFET Power: K3561 , K3934 , K3569
- IC MainBoard: TPA3100D2 , CXD9926ATQ , MB90F334A
- Control: RM-ED011
Модели:
- SONY KDL-40W4500 AEP/UK
- SONY KDL-46W4500 AEP/UK
- SONY KDL-52W4500 AEP/UK
TABLE OF CONTENTS
- 1. GENERAL
- Caution
- Specifications
- Connectors
- Self Diagnosis
- 2. DISASSEMBLY
- 2-1. Rear Cover Removal
- 2-2. Stand Removal
- 2-3. Loudspeaker Removal
- 2-4. Side Jack Bracket Assy Removal
- 2-5. BGE Board Removal
- 2-6. D4 Board Removal (52 inches)
- 2-7. D5 Board Removal (52 inches)
- 2-8. G5 Board Board Removal (52 inches)
- 2-9. H3E Board Removal
- 2-10. H4 Board Removal
- 2-11. IP5 Board Removal (40/46 inches)
- 3. SERVICE MENUS
- 3-1. How to enter the Service Mode
- 3-2. Product Version
- 3-3. Service Config
- 3-3-1. Set-Up
- 3-3-2. Sound
- 3-3-3. IF Adjust
- 3-3-4. White Balance
- 3-4. Error Menu
- 3-5. TT Mode
- 4. DIAGRAMS
- 4-1. Block Diagram
- 4-2. Circuit Board Location
- 4-3. Schematic Diagrams and Printed Wiring
- Boards
- BGE Board Schematic Diagram
- D4 Board Schematic Diagram (52 inches)
- D5 Board Schematic Diagram (52 inches)
- G5 Board Schematic Diagram (52 inches)
- H3E Board Schematic Diagram
- H4 Board Schematic Diagram
- IP5 Board Schematic Diagram (40/46 inches)
- BGE Printed Wiring Board
- D4 Printed Wiring Board (52 inches)
- D5 Printed Wiring Board (52 inches)
- G5 Printed Wiring Board (52 inches)
- H3E Printed Wiring Board
- H4 Printed Wiring Board
- IP5 Printed Wiring Board (40/46 inches)
- 5. EXPLODED VIEWS
- 5-1. Chassis
- 5-2. Bezel
- 5-3. Rear Cover & Power Supply Cords
- 6. ELECTRICAL PARTS LIST
Информация Ремонт ТВ SONY Программный ремонт Ремонт блока питания Шасси телевизора Ссылки на схемы
Решено SUPRA STV-LC2677WL V4L02 майн T.MS18VG.81B 11467 прошивка 25Q32 TVпрошивка которая в начале рабочая .большое спасибоPavka60
MYSTERY MTV-4029LTA2 нужна прошивка 25Q32.Понимаю матрица, но до матрицы надо исключить все варианты. За прошивку буду благодарен, хотя что залить в 25Q32 тоже проблема.Бурляй
AKAI UA40LEP1T2S Требуется прошивка по USBДоброе время суток. Требуется прошивка по USB на данный аппарат. Модель: AKAI UA40LEP1T2S Майн: P75-2841V6.0 Панель: CX400DLEDM Планка T-Con: V400HJ6-PE1 Rev. C3 Аппарат висит на загрузке (анимационные кружочки)tvv_vovik
QUARTON 32S1B маин:P50-2841TV8.2Avas, а почему решил что другой прошется ? Ремонтируй ТВ или ищи мастера или майн.service
