DataSheet OZ9967
LED controller that drives up to six (6) strings of LEDs in parallel confi guration, with multiple LEDs per string connected in series.Файл в формате PDF
FEATURES
- High frequency DC/DC boost converter controller
- Drives 6 LED strings in parallel
- Integrated LED current balance control circuit
- Up to 1MHz switching frequency
- External PWM or internal LPWM dimming control
- LED short circuit protection
- Over-current and over-voltage protection
- Soft start function
APPLICATIONS
- LCD Monitor
- LCD TV
GENERAL DESCRIPTION
The OZ9967 is an LED controller that drives up to six (6) strings of LEDs in parallel confi guration, with multiple LEDs per string connected in series. It provides six (6) LED current sense inputs in an “OR” confi guration to improve backlight reliability. This allows the backlight to remain functioning in the event that any string (s) is damaged during normal operation.
OZ9967 supports external Pulse Width Modulation (PWM) or internal Low frequency PWM (LPWM) dimming control. Plus, it provides an integrated circuit to balance the current fl ow through each LED string. The balance transistors are external to accommodate different power dissipation resulting from the forward voltage difference among the LED strings.
Решено Konka KDL32MN668ANTS прошивку emmc THGBMHG6C1LBAILСпасибо, будет возможность попробую.telemaster1280
Telefunken TF-LED43S05T2SUДобрый день ! нужна прошивка для TF-LED43S05T2SU сер. B06836010-00825 через USBfer.tv
Нужна принципиальная схема блока питания Актаком.kiborg, /forum/threads/204114/ Актаком АТН1232. 30В,2А В заголовок темы.segor
Samsung UE40D7000 ищу дамп ЕММС 1018.0ТВ через 20 сек отключается в дежурный режим Или ищу проверенный комплектurakov
автомагнитола Kenwood KDS-BT501U ищу прошивку флеши.Всем привет, ищу прошивку для проверки, постоянный обмен на шине, флешь 25LP064.mono
