Сервисный мануал на цветной лазерный принтер Lexmark C510
Файл в формате PDF на английском языкеTable of contents
- Laser notices
- Safety information
- Preface
- Definitions
- General information
- Maintenance approach
- Tools required for service
- Serial number
- Acronyms
- Specifications
- Resolution
- Model differences
- Technical specifications
- Physical specifications and weight
- Operating clearances
- Packaging and shipping dimensions
- Print speed and performance
- Time to first print
- Duty cycle
- Printer memory
- Paper and media specifications
- Media sizes
- Output capacity by media and source
- Media guidelines
- Connectivity
- Power and electrical specifications
- Environment
- Printer identification
- Options identification
- Printer theory of operation
- Printer paper path
- Printer systems description
- Basic principles of color printing
- Mechanical and electrical structures
- Printer component systems
- Basic process of color printing
- Print system and transfer system
- Structure of OPC belt (photo developer cartridge)
- Basic structure of the print system
- Details of the print system
- Charging process
- Exposing process
- Developing process
- First transfer (drum) process
- Belt discharge (erase lamp) process
- Belt cleaning process
- Details of the transfer system
- Second transfer (paper) process
- Transfer belt cleaning process
- Details of the optical system
- Details of the paper transportation system
- Fusing unit
- Fusing process
- Control system structure
- Electrical system and function
- Control of print process
- Print sequence diagram
- Laser drive control circuit
- Interface control
- Diagnostic information
- Start
- Service error codes
- Operator messages
- Paper jam messages
- Symptom tables
- Printer symptom table
- Print quality symptom table
- Printer service checks
- 901—Yellow developer clutch service check
- 902—Magenta developer clutch service check
- 903—Cyan developer clutch service check
- 904—Black developer clutch service check
- 905—Yellow toner retract solenoid service check
- 906—Magenta toner retract solenoid service check
- 907—Cyan toner retract solenoid service check
- 908—Black toner retract solenoid service check
- 910—Developer motor service check
- 911—Main motor service check
- 912—Power supply fan service check
- 913—Fuser fan service check
- 914—Laser fan service check
- 915—Erase lamp service check
- 916—Toner empty sensor (sender-TPD) service check
- 917—Toner empty sensor (receiver-TTR) service check
- 918—HVPS connection service check
- 919—Lower feed unit (secondary paper assembly) service check
- 2-59
- 920—Fuser thermistor service check
- 921,922,923,924,925—Fuser assembly service check
- 930,931,932—Laser unit assembly service check
- 985—Duplex connection error 1 service check
- 986—Duplex connection error 2 service check
- 990—Transfer belt unit service check
- 991—Transfer roller clutch service check
- 992—Transfer belt cleaning roller clutch service check
- 993—Fuser clutch service check
- 994—OPC belt marker sensor service check
- 995—High voltage power supply (HVPS) service check
- 996—Low voltage power supply (LVPS) service check
- Cover open service check
- Incorrect media service check
- Missing photodeveloper cartridge service check
- Missing toner cartridge service check
- OPC belt (photodeveloper) cartridge drive service check
- Operator panel service check
- Output tray full service check
- Paper size sensing service check
- Printer no power service check
- Toner feed service check
- Toner low/empty service check
- Transfer roller missing service check
- Tray empty service check
- Waste toner bottle service check
- Waste toner feed service check
- Paper feed service checks
- Printer paper feed service check
- Print quality service checks
- Background service check
- Back stain service check
- Banding service check
- Black line service check
- Color misregistration service check
- Insufficient fusing service check
- Insufficient gloss service check
- Jitter service check
- Missing image at edge service check
- Mixed color image service check
- Mottle service check
- Residual image service check
- Ribbing service check
- Toner drop service check
- Vertical line service check
- Vertical staggering image service check
- Vertical white band service check
- White band service check
- White line I service check
- White line II service check
- White spot / black spot service check
- White print service check
- Wrinkle / image migration service check
- Uneven density (right and left)
- Spacing table
- Roller specifications
- Diagnostic aids
- Disabling download emulations
- Paper jam sequence
- Diagnostic mode
- Diagnostics menu structure
- Print quality test pages
- Print registration
- Setting tray 2 left margin
- Setting top margin
- Print tests
- Hardware tests
- LCD test
- Button test
- Parallel wrap test
- ROM memory test
- DRAM memory test
- Serial wrap test
- Duplex tests
- Duplex left margin
- Device tests
- Quick disk test
- Disk test/clean
- Printer setup
- Setting the page count
- Viewing the permanent page count
- Serial number
- Setting configuration ID
- Parallel strobe adjustment
- Error log
- Viewing the error log
- Printing the error log
- Clearing the error log
- Restore EP factory defaults
- Exiting diagnostic mode
- Repair information
- Removal and cleaning precautions
- Handling the printed circuit boards with
- MOS ICs
- During transportation/storage:
- During replacement:
- During inspection:
- Photodeveloper cartridge
- Handling
- Parts not to be touched
- Printer removal procedures
- Precautions to take before maintenance work
- CRU/FRU and supplies removals
- Cleaning roller cover removal
- Transfer belt cleaning roller removal
- Transfer belt unit removal
- Transfer roller removal
- Fuser assembly removal
- Waste toner bottle removal
- Photodeveloper cartridge removal
- Duplex unit assembly removal
- Secondary paper feed assembly removal
- Cover removals
- Top cover assembly removal
- Front cover assembly removal
- Right cover removal
- Rear cover assembly removal
- Left cover removal
- Laser unit assembly (printhead) removal
- Laser unit fan assembly removal
- Erase lamp removal
- Right side removals
- Front door interlock switch removal
- Front door interlock switch with bracket
- Developer motor removal
- Waste toner bottle holder removal
- Developer drive assembly removal
- Toner sensor (sender) removal
- Cleaning roller clutch removal
- Main motor assembly removal
- Clutch removal
- Main drive gear assembly removal
- Waste toner feeder removal
- Rear removals
- RIP board removal
- Bracket assembly removal
- Paper guide assembly removal
- Paper guide (C) assembly removal
- Paper feed roller removal
- Paper exit assembly removal
- Registration assembly removal
- Left side removals
- Operator panel cable removal
- Engine controller board removal
- RIP board cage removal
- High voltage power supply (HVPS) removal
- Low voltage power supply (LVPS) with cage removal
- HVPS cage removal
- Toner present sensor removal
- Toner sensor (receiver) removal
- Toner retract solenoid and cam removal
- Left tray guide assembly removal
- Top removals
- Marker sensor assembly removal
- I/O board removal
- Waste toner auger removal
- Waste toner agitator removal
- Power supply fan removal
- Locations and connectors
- Printer
- Options
- Electronic components
- Sensor locations
- Printer circuit board locations
- Fan/motor locations
- Interlock switch locations
- Solenoid/clutch locations
- Symbol and part name table
- Wiring diagram / cable harness reference
- RIP board
- Input/output (I/O) board
- Low voltage power supply (LVPS) board
- High voltage power supply (HVPS) board
- Printer cables
- Cable 1 connector assignments
- Cable 1 connector pin assignments
- Cable 2 connector assignments
- Cable 2 connector pin assignments
- Cable 3 connector assignments
- Cable 3 connector pin assignments
- Cable 4 connector assignments
- Cable 5 connector assignments
- Cable 6 connector assignments
- Cable 6 connector pin assignments
- Cable 7 connector assignments
- Cable 7 connector pin assignments
- Cable 9 connector assignments
- Cable 9 connector pin assignments
- Cable 10 connector assignments
- Cable 10 connector pin assignments
- Cable 11 connector assignments
- Cable 11 connector pin assignments
- Cable 12 connector assignments
- Cable 12 connector pin assignments
- Cable 13 connector assignments
- Cable 13 connector pin assignments
- Preventive maintenance
- Parts catalog
- How to use this parts catalog
- Index
- Part number index
Решено Konka KDL32MN668ANTS прошивку emmc THGBMHG6C1LBAILСпасибо, будет возможность попробую.telemaster1280
Telefunken TF-LED43S05T2SUДобрый день ! нужна прошивка для TF-LED43S05T2SU сер. B06836010-00825 через USBfer.tv
Нужна принципиальная схема блока питания Актаком.kiborg, /forum/threads/204114/ Актаком АТН1232. 30В,2А В заголовок темы.segor
Samsung UE40D7000 ищу дамп ЕММС 1018.0ТВ через 20 сек отключается в дежурный режим Или ищу проверенный комплектurakov
автомагнитола Kenwood KDS-BT501U ищу прошивку флеши.Всем привет, ищу прошивку для проверки, постоянный обмен на шине, флешь 25LP064.mono
