Сервисный мануал на струйный принтер Canon PIXMA MP170; PIXMA MP450
Файл в формате PDF на английском языкеTABLE OF CONTENTS
- Part 1: MAINTENANCE
- 1. MAINTENANCE
- 1-1. Adjustment, Periodic Maintenance, Periodic Replacement Parts, and Replacement Consumables by
- Service Engineer
- 1-2. Customer Maintenance
- 1-3. Product Life
- 1-4. Special Tools
- 1-5. Serial Number Location
- 2. LIST OF ERROR DISPLAY / INDICATIONS
- 2-1. Operator Call Errors
- 2-2. Service Call Errors
- 2-3. Warnings
- 2-4. Troubleshooting by Symptom
- 3. REPAIR
- 3-1. Notes on Service Part Replacement (and Disassembling / Reassembling)
- 3-2. Special Notes on Repair Servicing
- 3-3. Adjustment / Settings
- (1) Paper feed motor adjustment
- (2) Main chassis and carriage rail adjustment
- (3) Document pressure sheet adjustment
- (4) Grease application
- (5) Waste ink counter setting
- (6) User mode
- (7) Service mode
- Service test print
- EEPROM initialization
- Waste ink counter reset
- Destination settings
- Button and LCD test
- 3-4. Verification Items
- (1) Service test print
- (2) EEPROM information print
- Part 2: TECHNICAL REFERENCE
- 1. NEW TECHNOLOGIES
- 2. CLEANING MODE AND AMOUNT OF INK PURGED
- 3. PRINT MODE
- 3-1. Resolution in Printing via Computer (Print on One or Both Sides of Paper, BK Cartridge,
- Monochrome Mode)
- 3-2. Resolution in Printing via Computer (Print on One or Both Sides of Paper, BK and CL Cartridges,
- Monochrome Mode)
- 3-3. Resolution in Printing via Computer (Print on One or Both Sides of Paper, BK and CL Cartridges,
- Color Mode)
- 3-4. Resolution in Printing via Computer (Print on One or Both Sides of Paper, CL Cartridge, Color or
- Monochrome Mode)
- 3-5. Resolution in Borderless Printing (Print on One or Both Sides of Paper, BK and CL Cartridges or
- CL Cartridge Only, Color or Monochrome Mode)
- 3-6. Resolution in Direct Printing
- 3-7. Resolution in Copying (Copy on One or Both Sides of Paper, Color or Monochrome Mode)
- 4. FAQ (Problems Specific to the MP170 / MP450 and Corrective Actions)
- Part 3: APPENDIX
- 1. BLOCK DIAGRAM
- 2. CONNECTOR LOCATION AND PIN LAYOUT
- 2-1. Main Board
- 2-2. MP450 Operation Panel Board L
- 2-3. MP450 Operation Panel Board R
- 2-4. MP170 Operation Panel Board
- 2-5. Card Slot Board (Card Slot Unit)
- 2-6. Carriage Board (Print Head Connector)
- 3. SPECIFICATIONS
MYSTERY MTV-4029LTA2 нужна прошивка 25Q32.https://drive.google.com/file/d/19fWl15R1vHVX3trZrJ-FqEG_KrGW8g4K/view?usp=sharingLeha
Решено HARTENS HTS-39HDR05B-S2 Нужна USB прошивка.Captain, премного благодарен, сейчас скачаю, буду пробовать. Отпишусь. :agree::up: Работает! Все ОК.КОЮР
Решено SUPRA STV-LC2677WL V4L02 майн T.MS18VG.81B 11467 прошивка 25Q32 TVпрошивка которая в начале рабочая .большое спасибоPavka60
AKAI UA40LEP1T2S Требуется прошивка по USBДоброе время суток. Требуется прошивка по USB на данный аппарат. Модель: AKAI UA40LEP1T2S Майн: P75-2841V6.0 Панель: CX400DLEDM Планка T-Con: V400HJ6-PE1 Rev. C3 Аппарат висит на загрузке (анимационные кружочки)tvv_vovik
