- Производитель
- Philips
DataSheet TEA1532
Green Switched Mode Power Supply (SMPS) controller ICDistinctive features
- Universal mains supply operation (70 V to 276 V AC)
- High level of integration, resulting in a very low external component count
- Fixed frequency Continuous Conduction Mode (CCM) operation capability
- Quasi-Resonant (QR) Discontinuous Conduction Mode (DCM) operation capability.
Green features
- Valley or zero voltage switching for minimum switching losses in QR operation
- Cycle skipping mode at very low loads; input power
- On-chip start-up current source.
Protection features
- Safe restart mode for system fault conditions
- Zero current switch-on in QR mode
- Undervoltage protection (foldback during overload)
- IC overtemperature protection (latched)
- Low and adjustable overcurrent protection trip level
- Soft (re)start
- Mains voltage-dependent operation-enabling level
- General purpose input for latched or safe restart protection and timing, e.g. to be used for overvoltage protection (OVP), output short-circuit protection or system
- Brown-out protection.
Applications
- Printer adapters and chargers. The device can also be used in all applications that demand an efficient and cost-effective solution up to 250 W.
Схема соединений TEA1532
samsung ue40eh5000wСвою прикладываем. сначала он не работал Короткое замыкание есть вольтарен поднял Короткое замыкание ушел после другой вольтарен я положил когда экран открыт так показываетalıdjan
SkyWorth 40E2AS mainboard 5851-A7NT12T-0P00 Ищу Схему TVС проца BL_ON/OFF Благодарю ) а все же полной схемы нет ?81beastie
Схема Тв Samsung, модель: ue46d5000pw, шасси: U57aсхему BN44-00422A Power Supply / схему BN44-00421A Power Supplyrparmas
найти схемы SMPS MINT1400 PCB 02-36230-2371-3 SL POWER ELECTRONICSнайти схемы за SMPS 24V 10A SL POWER ELECTRONICS модели MINT1400A2410L01, за Stille ImagiQ2 Главная плата: 02-36230-2371-3 SL POWER ELECTRONICS Плата управления: 02-36230-4272-3 SL POWER ELECTRONICSrparmas
Автомобильный видеорегистратор Prestigio RoadRunner 450gpsdl. Нужен дампИщу дамп с qh32bh1g на автомобильный видеорегистратор Prestigio RoadRunner 450GPSDLDUMOV
Решено Samsung LE40B530P7W Прошивка наСнял MainBoard, нашел парнишку с паяльным феном, выпаяли тюнер, прогрели три микросхемы. На данный момент проблема решилась. Спасибо откликнувшимся.nedva
