- Производитель
- THX Micro-elec
DataSheet THX203H
PWM Controller of High-performance Current ModeЦоколевка (распиновка) THX203H
Characteristics
- Set-in high-voltage power switch tube of 700V and few peripheral components
- With the modulation of lock pulse width, the testing is according to the pulse limit current.
- With the function of output frequency reduction, the non-output power consumption can be less than 0.3W.
- Inner-built ramp and anti-feedback compensation function
- The independent upper-limit current testing controller deals with over-current and over-load of the controller real-timely.
- The period emission pole is turned off and it outputs by deflected voltage, and the pressure resistance of the power tube is improved.
- Set-in current limit resistance with temperature compensation, which makes the current limit precise
- Set-in heat protection circuit
- Startup is accomplished with the magnification function of the switch power tube, and the power consumption of startup resistance is reduced more than10 times.
- Few peripheral components
- Low startup and operating current
- VCC over-voltage automatic limit
- Continuous wide-voltage output power reaches 12W, and the output power of peak value arrives at 18W.
Applied Field
- Adaptor (for example, travel charger, out power station)
- Open Frame (for example, DVD, DVB)
Hyundai H-LED32ET4100 main JUC7.820.00208835 Нужна прошивка LCDнарод тупо сливал не выложив состояния статус-регистров Они влияют на результат чтения программатором?artur008
tv Samsung ue65ks9002t нужна прошивка 25q80 ic804http://televid-sib.ru/index.php?topic=26680.msg179216#msg179216 https://remont-aud.net/dump/lcd_pdp_tv/samsung/samsung_ue55ks9000txxe_shassi_main_board_bn41_02504a_jazz_m_usit/241-1-0-94951artur008
Telefunken TF-LED43S05T2SU Ищу USB обновление длядоброго времени суток уважаемые. имею спросить следующее: TELEFUNKEN TF-LED43S05T2SU маин HK.T.RT2871P738 панель ST4251D01-7 заменил плату на аналогичную но от Hyundai H-LED43EU7001 залил прошивку...Polo
SUPRA STV-LC60GT5000U Ищу файл прошивки для панели V580DJ4-QE1 Rev.T4В сервисном меню нашел , что тип панели меняется через загрузку файла панели по USB. Factory menu--->Other--->Project ID ? Отвечаю. В сервисном меню пункта Other нет. Есть строка PID - 9K04G000S000003AndreySk
Решено UPS FSP EP1500 (ppf9000105) требуется схемаОт FSP тоже ответа нет, тему придётся закрыть.AZrx
SHARP LC60LE822ERU Ищу прошивку на телевизорИщу прошивку на телевизор LC60LE822ERU (майн DKEYDF455FM07)родную потеряли в прежнем месте ремонта, залили с SHARP_LC-40LE810E не включается. Пытался найти родной майн DKEYDF455FM07 не удачно.Генерал
