- Производитель
- NXP Semiconductors
DataSheet TEA1751; TEA1751T; TEA1751LT
HV start-up DCM/QR flyback controller with integrated DCM/QR PFC controllerDistinctive features
- Integrated PFC and flyback controller
- Universal mains supply operation (70 V (AC) to 276 V (AC))
- Dual-boost PFC with accurate maximum output voltage (NXP patented)
- High level of integration, resulting in a very low external component count and a cost-effective design
Green features
- On-chip start-up current source
- 2.3 PFC green features
- Valley/Zero Voltage Switching (ZVS) for minimum switching losses (NXP patented)
- Frequency limitation to reduce switching losses
- PFC is switched off when a low load is detected at the flyback output
- 2.4 Flyback green features
- Valley switching for minimum switching losses (NXP patented)
- Frequency reduction with fixed minimum peak current at low-power operation to maintain high efficiency at low output power levels
Protection features
- Safe restart mode for system fault conditions
- Continuous mode protection with demagnetization detection for both converters (NXP patented)
- UnderVoltage Protection (UVP) (foldback during overload)
- Accurate OverVoltage Protection (OVP) for both converters (adjustable for flyback converter)
- Mains voltage independent OverPower Protection (OPP)
- Open control loop protection for both converters. The open-loop protection on the flyback converter is safe restart
- OverTemperature Protection (OTP)
- Low and adjustable OverCurrent Protection (OCP) trip level for both converters
- General-purpose input for latched protection
Нужна прошивка на телевизор Mystery MTV-4334 LTA2 Версия V1T09VladimirSolka, не только чего, но и к чему. Надежнее будет обратиться к специалисту по ремонту телевизоров по месту жительства.ФАРТ
Решено Bravis LED-32E1800 Smart+T2 Black, шасси CV338-T42В личку гляньте Поделитесь пожалуйста прошивкой USB Bravis LED-32E1800 Smart+T2 Black.Буду очень признателен за ответ.Sanyok71
Rolsen RL-26X20 с DVD (шасси: PLZM01 REV06) прошивка A29040BL-70F, позиция Q002https://monitor.net.ru/forum/pages/file_upload/16256/ 1685548955 https://remont-aud.net/dump/lcd_pdp_tv/rolsen/rl_26x20/342-1-0-20598 1685549022 https://www.soft4led.com/rolsen-rl-26x20-software-firmware/Ильшат
LG M2382D-PZN, LD21L нужен комплект прошивокM82D EAX64392805 (1.1) LD21L Процессор: LGE2111A-T8 Матрица: LM230WF3 Плата ушатана предыдущими "мастерами". Я менял проц, пробитый по HDMI. Они епромку зачем то очистили. Паяли нанду. Возможно чем то тоже шили. Нужны прошивки доделать плату.VISMUT2401
