Схема и сервис мануал телевизоров SHARP LC-42SA1RU; SHARP LC-42SA1E; SHARP LC-42SA1RU
Файл в формате PDF на английском языкеМодели:
- SHARP LC-42SA1RU;
- SHARP LC-42SA1E;
- SHARP LC-42SA1RU
Содержание:
- SAFETY PRECAUTION
- IMPORTANT SERVICE SAFETY PRECAUTION
- Precautions for using lead-free solder
- CHAPTER 1. OPERATION MANUAL
- [1] SPECIFICATIONS
- [2] OPERATION MANUAL
- [3] DIMENSIONS
- CHAPTER 2. REMOVING OF MAJOR PARTS
- [1] REMOVING OF MAJOR PARTS
- CHAPTER 3. ADJUSTMENT PROCEDURE
- [1] After replacement of any PWB and/or IC for repair, note the following
- [2] SOFTWARE UPDATING
- [3] Entering and exiting the adjustment process mode
- [4] Remote controller key operation and description of display in adjustment process mode
- [5] Adjustment process mode menu
- [6] Special features
- [7] Video signal adjustment procedure
- [8] White Balance Adjustment
- [9] Initialization to factory settings
- [10] Lamp error detection
- [11] Public Mode (Hotel Mode)
- CHAPTER 4. TROUBLESHOOTING TABLE
- [1] TROBLESHOOTING TABLE
- CHAPTER 5. MAJOR IC INFORMATIONS
- [1] MAJOR IC INFORMATIONS
- CHAPTER 6. OVERALL WIRING DIAGRAM/BLOCK DIAGRAM
- [1] OVERALL WIRING DIAGRAM
- [2] BLOCK DIAGRAM
- [3] POWER BLOCK DIAGRAM
- CHAPTER 7. PRINTED WIRING BOARD
- [1] OPERATION UNIT PRINTED WIRING BOARD
- [2] R/C, LED UNIT PRINTED WIRING BOARD
- [3] MAIN UNIT PRINTED WIRING BOARD
- [4] AV UNIT PRINTED WIRING BOARD
- [5] POWER UNIT PRINTED WIRING BOAR
- [6] TUNER UNIT PRINTED WIRING BOAR
- CHAPTER 8. SCHEMATIC DIAGRAM
- [1] DESCRIPTION OF SCHEMATIC DIAGRAM
- [2] SCHEMATIC DIAGRAM
- Parts Guide
Фото основной платы KD890; DUNTKD890FM17
- MainBoard: KD890 DUNTKD890FM17
- Inverter (backlight): V1838..381 V1838.371/C2
- PWM Inverter: MIC4427 (8) OZ364SN (20)
- MOSFET Inverter: P2804ND5G (5)NIKOS 9563GH
- Power Supply (PSU): DPS-263AP RDENCA193WJQZ
- PWM Power: L6562 (PFC), DAS01A , DLA001 (PWM Push-pull), DAP011 (PWM Flyback), LM358
- IC MainBoard: VCT69936 B3000, MP1410ES, EPM24, Si19021CTU, CM052B, PIC16F913, FRC9429AB2
- Тuner: DUNTKD608WE
- Control: GA531WJSA
Информация Ремонт ТВ SHARP Программный ремонт Ремонт блока питания Шасси телевизора Ссылки на схемы
Samsung UE49MU6450UXRU прошивка 25Q40sergiy, скачал. Огромное спасибо. О результате отпишусь позже.Sergey_1
Парогенератор Tefal GV7460. Ищу Servis Manual.Парогенератор Tefal GV7460. Ищу Servis Manual. Или схему..Montajnik
avel AVS2230MPP прошивка Spi Q32C-104HIPSandu, сперва смотреть две преобразователи FR9886 (So-8) и пятиногий преобразователь sot25-25 на кз в случае заменить/ заменишь дальше видно будет 1656422764 Sandu, Ты можешь слить прошивку Q32 и выложить сюда?ryzp
Витязь 43LU1204 Прошивка USBСаша, ну глаз могу лечить или ещё что, я много что умею, на рыбках тренировался. Маг короче Старый становлюсь. Не все сразу понял. :pray:ФАРТ
BQ 58fsu32b завис на логотипеBq58fsu32b. main hk.t.rt 2851v09. в интернете ни чего не могу найти. может кто то сливал дамп? покажи свой слитый дамп , тогда сможем помочь ... 1656213188 тв в сервисе. (горе мастера не могут его сделать, видимо сервис не айс). дамп еще не сливал.spybot888
