Datasheet MAX17113, Закачал: Jovani
MAX17113 - Low-Cost, Multiple-Output Power Supply for LCD TVs
- Optimized for 10.8V to 13.2V Input Supply
- 8V to 16.5V Input Supply Range
- Selectable Frequency (450kHz/600kHz)
- Current-Mode Step-Up Regulator
- Built-In 24V, 3.3A, 80m? n-Channel MOSFET
- High-Accuracy Output Voltage (1%)
- True Shutdown
- Fast Load-Transient Response
- High Efficiency
- 10ms Internal Soft-Start
- Current-Mode Step-Down Regulator
- Built-In 24V, 3A, 100m? n-Channel MOSFET
- Adjustable Output Voltage Down to 1.5V
- Skip Mode at Light Load (EN2 = AGND)
- High Efficiency
- 3ms Internal Soft-Start
- Adjustable Positive and Negative Charge-Pump Regulators
- Soft-Start and Timer-Delay Fault Latch for All Outputs
- Logic-Controlled High-Voltage Integrated Switches with Adjustable Delay
- 120mA p-Channel FET for AVDD Sequencing
- Input Undervoltage Lockout and ThermalOverload
- Protection
- 40-Pin, 5mm x 5mm Thin QFN Package
