Сервис мануал и схема телевизора AKAI LEA-19H03P
Файл в формате PDF на английском языкеСодержание:
- Chapter 1.General Information
- 1-1. Document Information
- 1-2. General Guidelines
- 1-3. Important Notice
- 1-3-1. Follow the regulations and warnings
- 1-3-2. Be careful to the electrical shock
- 1-3-3. Electro static discharge (ESD)
- 1-3-4. About lead free solder (PbF)
- 1-3-5. Use the genewing parts (specified parts)
- 1-3-6. Safety check after repairment
- 1-3-7. Ordering Spare Parts
- 1-3-8. Photo used in this manual
- 1-4. How to Read this Service Manual
- 1-4-1. Using icons:
- Chapter 2. Specification
- 2-1. Specification list
- 2-2. External pictures (four faces)
- Chapter 3. Disassemble and Assemble
- 3-1. Remove the Stand
- 3-2. Remove the Back Cover
- 3-3. Remove the Remove the Main Board & Small Board
- 3-3-1. Remove the Mainboard and the Driver Board
- 3-3-2. Remove the Remote Control Board
- 3-3-3. Remove the Keypad Board
- 3-3-4. Remove the Speakers
- Chapter 4. Location of Controls and Components
- 4-1. Board Location
- 4-2. Main Board
- 4-2-1. Function Description:
- 4-2-2. Connector definition
- 4-3. Driver Board
- 4-4. Remote Control Board
- 4-5. LED Panel
- 4-4. LCD Panel
- Chapter 5. External Equipment Connections
- 5-1. Antenna Connection
- 5-2. VCR Connection
- 5-3. DVD Connection
- 5-4. HDMI or DVI Connection
- 5-5. PC Connection
- 5-6. Monitor Out Connection
- 5-7. Headphones Connection
- 5-8. Power Source
- 5-9. Recommendation input Format
- Chapter 6. Operation Instructions
- 6-1. Front Panel Controls
- 6-2. Back Panel Controls
- Chapter 7. Electrical Parts
- 7-1. Block Diagram
- 7-2. Wiring Connection Diagram
- 7-3. Circuit Diagram
- Chapter 8. Measurements and Adjustments
- 8-1. Service Mode
- 8-1-1.How to enter into Service Mode
- 8-1-2.How to exit
- 8-2. Measurements and Adjustments
- 8-2-1. Factory Menu 1
- 8-2-2. Factory Menu 2
- 8-2-3. Factory Menu 3
- 8-2-4. Factory Menu 4
- 8-2-5. Factory Menu 5
- 8-2-6. Factory Menu 6
- Chapter 9. Trouble shooting
- 9-1. Simple check
- 9-2. Mainboard Failure Check.
- 9-3. Pannel Failure
- LCD Panel specification
- Disassembly
- Exploded View Diagram
- Spare parts list
- V-Chip Password
- Software Upgrade
Информация Ремонт ТВ AKAI Программный ремонт Ремонт блока питания Шасси телевизора Ссылки на схемы
avel AVS2230MPP прошивка Spi Q32C-104HIPSandu, сперва смотреть две преобразователи FR9886 (So-8) и пятиногий преобразователь sot25-25 на кз в случае заменить/ заменишь дальше видно будет 1656422764 Sandu, Ты можешь слить прошивку Q32 и выложить сюда?ryzp
Витязь 43LU1204 Прошивка USBСаша, ну глаз могу лечить или ещё что, я много что умею, на рыбках тренировался. Маг короче Старый становлюсь. Не все сразу понял. :pray:ФАРТ
BQ 58fsu32b завис на логотипеBq58fsu32b. main hk.t.rt 2851v09. в интернете ни чего не могу найти. может кто то сливал дамп? покажи свой слитый дамп , тогда сможем помочь ... 1656213188 тв в сервисе. (горе мастера не могут его сделать, видимо сервис не айс). дамп еще не сливал.spybot888
Нужна прошивка на духовой шкаф whirlpool , Mod:AKZ444 ,service 10Всем привет! Помогите с прошивкой на духовой шкаф AKZ444 servese 10Сергей ж
UE32D6510WSXRU BN41-01587E версия 1018.0 прошивкаПрошивка 100%. ТВ поступил с отсутствием звука, слегка погрел феном проц, звук появился. Проц заменён на новый. Теперь выключается через 30 сек. Похоже, пока менял проц, вышла из строя EMMC, не читается.Sergey_S
Решено SAMSUNG LE26C350D1W помощь в прошивке ONE NAND IC1201 KFG1G16U2DВ общем наверное MMMMAX прав,но у меня нет опыта(то есть есть,но отрицательный) по реболу процессоров. Сегодня раза три нормально включился,потом стал включаться ,но без изображения. Затем только отмаргиванием светодиода 6 раз без изо и звука. Клиент купит новый тв.nail--72
