Сервис мануал и схема видеокамеры SONY DCR-HC90; DCR-HC90E
Файл в формате PDF на английском языкеDIGITAL VIDEO CAMERA RECORDER
TABLE OF CONTENTS
- 4. PRINTED WIRING BOARDS AND
- SCHEMATIC DIAGRAMS
- 4-1. FRAME SCHEMATIC DIAGRAM
- 4-2. SCHEMATIC DIAGRAMS
- CD-540 (CCD IMAGER, TG) SCHEMATIC DIAGRAM
- CK-145 (EVF CONNECT) SCHEMATIC DIAGRAM
- FP-059 FLEXIBLE (RELAY) SCHEMATIC DIAGRAM
- IR-055 (PITCH/YAW SENSOR AMP) SCHEMATIC DIAGRAM
- LD-176 (LENS MOTOR DRIVE/SHUTTER CONTROL) SCHEMATIC DIAGRAM
- VC-380 (1/18) (DC/DC CONVERTER) SCHEMATIC DIAGRAM
- VC-380 (2/18) (CDS A/D CONVERTER) SCHEMATIC DIAGRAM
- VC-380 (3/18) (CAMERA PROCESS) SCHEMATIC DIAGRAM
- VC-380 (4/18) (DV SIGNAL/MPEG MOVIE/DIGITAL STILL/AUDIO SIGNAL PROCESS) SCHEMATIC DIAGRAM
- VC-380 (5/18) (DV INTERFACE) SCHEMATIC DIAGRAM
- VC-380 (6/18) (DVD SIGNAL/RF SIGNAL PROCESS) SCHEMATIC DIAGRAM
- VC-380 (7/18) (REC/PB RF AMP) SCHEMATIC DIAGRAM
- VC-380 (8/18) (AUDIO/VIDEO INTERFACE) SCHEMATIC DIAGRAM
- VC-380 (9/18) (AUDIO INTERFACE) SCHEMATIC DIAGRAM
- VC-380 (10/18) (MIC AMP) SCHEMATIC DIAGRAM
- VC-380 (11/18) (RGB OUT) SCHEMATIC DIAGRAM
- VC-380 (12/18) (HI CONTROL) SCHEMATIC DIAGRAM
- VC-380 (13/18) (HI CONTROL/DIGITAL STILL CONTROL) SCHEMATIC DIAGRAM
- VC-380 (14/18) (64MBIT SDRAM) SCHEMATIC DIAGRAM
- VC-380 (15/18) (CAMERA/MECHA CONTROL) SCHEMATIC DIAGRAM
- VC-380 (16/18) (MECHA CONTROL) SCHEMATIC DIAGRAM
- VC-380 (17/18) (EVF RGB DRIVE, TG) SCHEMATIC DIAGRAM
- VC-380 (18/18) (CONNECTOR) SCHEMATIC DIAGRAM
- 4-3. PRINTED WIRING BOARDS
- CD-540 (CCD IMAGER, TG) PRINTED WIRING BOARD
- CK-145 (EVF CONNECT) PRINTED WIRING BOARD
- FP-059 FLEXIBLE (RELAY) PRINTED WIRING BOARD
- IR-055 (PITCH/YAW SENSOR AMP) PRINTED WIRING BOARD
- LD-176 (LENS MOTOR DRIVE/SHUTTER CONTROL) PRINTED WIRING BOARD
- VC-380 (DC/DC CONVERTER, CDS A/D CONVERTER, CAMERA PROCESS, DV SIGNAL/MPEG MOVIE/DIGITAL STILL/AUDIO SIGNAL PROCESS, DV INTERFACE, DVD SIGNAL/RF SIGNAL PROCESS, REC/PB RF AMP, AUDIO/VIDEO INTERFACE, AUDIO INTERFACE, MIC AMP, RGB OUT, HI CONTROL, HI CONTROL/DIGITAL STILL CONTROL, 64MBIT SDRAM, CAMERA/MECHA CONTROL, MECHA CONTROL, EVF RGB DRIVE, TG, CONNECTOR) PRINTED WIRING BOARD
- 4-4. WAVEFORMS
- 4-5. MOUNTED PARTS LOCATION
- 5. REPAIR PARTS LIST
- 5-2. ELECTRICAL PARTS LIST
Hamber 50hrp8509 висит на андроидскачивал с сайта AUD ТАМ битая. больше ни где не нашел. При включении загорается экран начинается загрузка и так до бесконечности. Нужно обновление через usbиванчик000
Решено Бюллетень на Samsung F5, F6 серий (дублирование шлейфа питания)А что мешает все контакты продублировать c майна на блок питания? Лень ведет к попадалову! Да, так и сделал, сегодня поборол лень:gigi:Бaрмалей
Решено Нужна схема плазменной резки Plasma ARC 251/1С сожалением сообщаем Вам, что руководство и запасные части для такой машины больше не доступны Telwin.comAndris
Akai UA55EK1100UТебе дают на форуме http://teleservis.com.ua/forum/viewtopic.php?t=1387 , но если ты глуп и даже составить тему правильно не можешь, то таким помогать не стоит. Тыкать будешь своей бабушке.Xanzik
Решено MYSTERY MTV-3228LT2 прошивка 25Q64 версия V8P07samilo, Добрый день не поделитесь прошивкой на это телевизор?maxst83
