Сервис мануал и схема телефона Panasonic X300
Файл в формате PDFСодержание:
- 1. INTRODUCTION
- 1.1. Purpose of the Manual
- 1.2. Structure of the Manual
- 1.3. Servicing Responsibilities
- 2. GENERAL DESCRIPTION
- 2.1. General
- 2.2. Features
- 2.3. Handportable Main Kits
- 3. OPERATING INSTRUCTIONS
- 3.1. General
- 3.2. Liquid Crystal Display
- 3.3. Location of Controls
- 3.4. Concept of Operation
- 3.5. Alpha Entry
- 3.5.1. Character Set / Key Assignments
- 3.5.2. Editing Alpha Entry
- 3.6. Menu Structure
- 3.7. Incoming Call Line Identification (CLI)
- 3.8. Public Man Machine Interface (MMI)
- 3.8.1. General
- 3.8.2. Reading the Phonebook Memory Location
- 3.8.3. Presentation of IMEI
- 3.8.4. Security
- 3.8.5. Call Hold
- 3.8.6. Call Waiting
- 3.8.7. Call Line Identification
- 3.8.8. Telecommunication Services used for Public MMI
- 3.8.9. Call Divert
- 3.8.10. Call Bar
- 3.9. Troubleshooting
- 3.10. Important Error Messages
- 3.11. Security Codes
- 3.12. Glossary of Terms
- 4. TECHNICAL SPECIFICATIONS
- 4.1. Tx Characteristics
- 4.1.1. Frequency Error
- 4.1.2. Modulation Phase Error
- 4.1.3. Output RF Spectrum due to Modulation
- 4.1.4. Output RF Spectrum due to Switching Transients
- 4.1.5. Spurious Emissions at Antenna Connector
- 4.1.6. Residual Peak Power
- 4.2. Rx Characteristics
- 4.2.1. Sensitivity
- 5. TECHNICAL DESCRIPTION
- 5.1. RF Overview
- 5.1.1. RF Block Diagram
- 5.1.2. RF Function Block
- 5.1.3. Functional Description
- 5.2. Baseband Overview
- 5.2.1. Introduction
- 5.2.2. Digital Baseband Processor
- 5.2.3. Keypad
- 5.3.4. Subscriber Identity Module (SIM)
- 5.3.5. CPU Memory
- 5.3.6. LCD
- 5.3.7. Real Tim Clock (RTC)
- 5.3. Audio System
- 5.3.1. Voiceband Baseband Codec
- 5.3.2. Microphone
- 5.3.3. Receiver
- 5.3.4. Loud Speaker
- 5.4. Power Management Subsystem
- 5.4.1. Power Source
- 5.4.2. Regulator Control
- 5.4.3. Voltage Regulation
- 5.5. Battery Charging and Monitoring
- 5.5.1. Charging Current
- 5.5.2. Deeply Discharged Batteries
- 5.6. Test Point
- 5.6.1. Test Point Layout
- 6. DISASSEMBLY / REASSEMBLY INSTRUCTIONS
- 6.1. General
- 6.1.1. Call Bar
- 6.2. Disassembly
- 6.3. Reassembly
- 7. REPAIR PROCEDURES
- 7.1. Introduction
- 7.2. Lead Free (PbF) solder
- 7.3. External Testing
- 7.3.1. General Information
- 7.4. Test Equipment Setup
- 7.4.1. Equipment Required
- 8. SOFTWARE DOWNLOAD & ADJUSTMENT PROCEDURE
- 8.1. Service Software Upgrade
- 8.2. MMI Test
- 8.3. Adjustment Procedure
- 8.3.1. Equipment Setting for TX/RX adjustment
- 8.3.2. Main Subjects
- 8.3.3. Test Operation Procedure
- 8.3.4. Enter Test
- 8.3.5. TX Test
- 8.3.6. RX Test
- 8.3.7. Battery
- 9. REPLACEMENT PARTS LIST
- 9.1. Exploded View
- 9.2. Case and Cover Parts List
- 9.3. Main PCB
- 10. BLOCK DIAGRAM
- 10.1. Baseband
- 10.2. RF Band
- 11. CIRCUIT DIAGRAM
- 11.1. Baseband
- 11.2. RF Band
- 11.3. Analogue Baseband and Power Management
- 11.4. LCD and Camera
- 12. LAYOUT DIAGRAM
- 12.1. Main PCB
Skyworth 55G3AUlugbek_1212, почитай внимательно правила и исправь. 2. Обязательно укажите, прошивку чего (позиционный номер) Вы ищете, причину поиска прошивки.ua3qgx
GRUNDIG 40GUS8679 Sidney нужна прошивка по USBВ тв GRUNDIG 40GUS8679 была заменена плата управления ZKR190R-3,V-0 Установили мейн ZKR190R-3,V-0 с GRUNDIG 49GUS86хх. Тв включается, есть заставка Grundig, но перевернутое двойное изображение. Нужна прошивка именно под мою модель тв. Серийный номер для поиска прошивки на фото.Serg*
Решено TCL L55E5690UDS прошивки спиай и еммсПрошивку купил но она не помогла толи в еммс дело то ли в процессоре.Ильшат
Hyundai H-LED50EU7008 прошивкаCharm, Помогите пожалуйста. Проблема с h-led43eu7008, аналогичная, как в шапке. 1680015982 Андрей-, Как решили проблему, поделитесь пожалуйста.xdemion
Схема и Биос на планшет Trekstor primetab t13bAlexandron, /forum/threads/204114/ В ЗАГОЛОВКЕ ТЕМЫ ОБЯЗАТЕЛЬНО УКАЗЫВАТЬ: - Тип разыскиваемого документа (Схема, Прошивка, и т.д.) - Тип аппарата (TV, VCR, Муз.центр, Автомаг. и т.д.)segor
