volodiaz Новичок Сообщения: 2
Состав : шасси SPV7050-V02, матрица LJ96-05080D
LCD телевизор MYSTERY MTV-1603w .Нужен вход в сервис, надо отрегулировать размер в режиме ZOOM, хотябы до растянутого 14 на 9.
Заранее благодарен. |
MASTER+ monitor.net.ru  Сообщения: 10951
volodiaz, а где состав? У мастера спросить? |
Уточняю - прoцессорный блок Sunplus SPV7050-v02, если у кого есть сервис-мануал буду крайне признателен.
Вот краткая инфа:
Key Features:
The SPV7050 is a highly integrated SoC for the Multi-Function Monitor (MFM) or Entry-Level LCD TV applications. It provides on-chip functions including high-speed video ADCs with PLL, HDMI 1.2 Rx, TV decoder with 2-D comb filter, 4-pair Audio Line-In, 2-pair Audio Line-Out, one SIF demodulator and audio decoder, 2D de-interlacing, color management, font-based OSD engine, embedded RISC CPU and a dual channels 8-bit LVDS transmitter. It also supports LCD TV up to 1080p input resolution and WUXGA 1920X1200 reduced blanking output resolution. The SPV7050 provides not only the best BOM cost but also good performance for entry level TV system. With Sunplus' other powerful companion chips, the SPV7050 can apply to different TV applications such as pure ATV, DVB-T DTV with recording function, DTMB DTV with recording function, ISDB DTV, multimedia TV and DVD combo TV.
FEATURES
* Complete hardwaer and software production reference designs for worldwide TV systems
* Integrated HDMI 1.2 compliant receiver with HDCP
* Integrated field-proven worldwide standards video decoder and multi-standard TV sound decoder with audio post processing
* Advanced scaling with moire cancellation
* Optimized picture setting for MFM/entry level TVs
* Embedded 32-bit RISC CPU & FOSD engine for smooth operation and OSD display
* Embedded VBI data decoder which can support 10 pages Teletext 1.5 without external memory needed, WSS, VPS, closed-caption and V-chip
* Embedded audio DAC for BOM cost saving
* LQFP 128 package for easy implementation on 2 layers PCB
BENEFITS
* Ready for mass production total system solutions for LCD TV, DVB-T DTV with recording function, DTMB DTV with recording function, ISDB DTV, multimedia TV and DVD combo TV
APPLICATIONS
* ATV for Southern American, European, Pan-Asian and Russian Market
* DTV for European, Pan-Asian and Russian Market (with SPHE1003)
* Multimedia TV for European, Pan-Asian and Russian Market (with SPHE8104D)
* DTMB DTV (with SPHE1002+SPHE6630)  |
CHETLAN Участник Сообщения: 1211
volodiaz, какую то чепуху выложил вместо состава (с инета скачал), может инструкцию почитать глядишь и звякнет  |
aka_google Гость 89.190.*.*
menu 1178
или
sourge 1178
может поможет |
sasa1 Предупреждений: 1 Сообщения: 16
Тема старая но решения нет. чтоб не создавать новую тему может у кого появилось решение как войти в сервис для шасси SPV7050-V02 |
Вход в сервис MENU 9527 но кроме информацыи о системе и настройках цвета и звука там ничего нет . Кто может знает вход в инженерное меню для более полных настроек |
sasa1, там вроде нет другого способа, попробуй в край MENU-2-5-8-0 или SOURCE-2-5-8-0, а на мой взгляд проще флешь перелить, если чего не так. |
