PHILIPS 42PFL3606H/58 шасси TPM6.1ELA перезагрузка
Krik99
07-05-2017 10:50
Добрий день
панель LC420WUY(SC)(B1)
MAIN 715G4609-M4B-000-005B
бп 715G4802-P01-H20-003H
После включения появляется логотип и циклическая перезагрузка. Напряжения бп в норме. Подозрения на нанд. Помогите разобратся с логом
Код:
 oot-
DRAM Channel A Calibration.
Byte 0 : DQS(11 ~ 42), Size 32, Set 24.
Byte 1 : DQS(3 ~ 39), Size 37, Set 19.
Byte 2 : DQS(3 ~ 38), Size 36, Set 18.
Byte 3 : DQS(-1 ~ 37), Size 39, Set 16.
DRAM A Size = 256 Mbytes.
oot
Start Pmain
0x00004000
NID=0x9500f1ec
LZHS addr:0x00100040
LZHS size:0x00095fd0
LZHS checksum:0x00000086
oot
Start Lmain
MT5365 Boot Loader v0.9
[PCMCIA]Set PCMCIA Access IF : SPI
SPIHW_Init ----- Set SPI PinMux
SPI dummy delay:0x10
External CI Version : MT5135
Output clock from main chip.
PCMCIA Reset Demod GPIO=35, 0->1
SPI_SetPll(), spi clock: 27 Mhz
External CI is dead !
Version Code : 0x0
ExternalIc_Init: Daughter board is not connected.
PCMCIA_GPIO_Init: Daughter board is not connected.
MUdisable internal edid------------------
SIF_Master0: new design
SIF_Master1: old design
Boot reason: A/C power on!!T8032 init A/C on case loader stage...
Load T8032 FW (addr: 0x 2d381c4, size: 24576)success!!
T8032 FW version: 18
T8032 change to loader stage...
LDR_FlashCopy 0xf010 0x34d00 0x80
Switch NAND pinmux
Detect NAND flash ID: 0x9500F1EC
Detect SS K9F1G08U
No U
PDWNC_TPV_DetermineNextState : system booting
[PDWNC] Virgin Mode Status : 0x0, Offset :0x38
PDWNC_TPV_DetermineNextState : event = PDWNC_POWER_DOWN_AC_POWER
Current = 0x1, Event = 0x6, Next = 0x1
Wakeup keypad array = 4
Boot reason: A/C power on!![PDWNC]PDWNC_ReadWakeupReason = 0x6
[PDWNC]Enter normal mode, LED changes to normal
PDWNC_TPV_EnterNextState : u4Next = 0x1
A_Mute GPIO=11 release
AMP mute GPIO=cb release
Reset Demod GPIO=23, 0->1
Daughter board is not connected!!
Display 0x02d9eadc background:0x00000000
2 bytes panel index is : 123 (0x  7b)
Find panel index 123 from EEPROM
[LVDS] DVOPLL init control word only
[MLVDS]_u1TconMode=0x1
[MLVDS]TCLK_PCLK_RATION_NUBoot reason: A/C power on!!---------- Panel[123] PANEL_MLVDSV5GIP60_LC420WUmFreq50Hz=100
Delay[LvdsOn=20, BacklightOn=300, BacklightOff=300, LvdsOff=20]
MaxOverscan=30
Current panel setting is PANEL_MLVDSV5GIP60_LC420WU
NAND load image from SysImgA(part:1) to dram(0x2fe6a00), size=0xdf550c
secure boot ok
LZHS hardware decode start
LZHS hardware decode done
Starting image...
Booting
Nucleus Heap is at 0x012e8588(0x0ad0cf80)
Main task stack is at 0x012e8598 (0x00002000)
Dram Size: 0x10000000
Memory for Image at 0x00010000(0x012d2d88):
Memory Reserved for MMU04004000)
drv_init as EU[CLI]SPI_DemodSingleRead timeout !
[CEC]EEPROM ok. u4Val = 1.
---------------------------------TMDS361 init-------------------------------------
TMDS361 is GPIO mode
HDMI fast booting init...
TunerInit.....................EEPROM(tuner): Ofst0=0x21b,Ofst1=0xbcb,Ofst2=0x112b,def=0x69
[MUet=0x40000, size=0x1e00000
[NAND][BDM] Partition: 1, Bad Block Count: 0
[NAND]NAND_BDM_Mount: Partid=3, offset=0x1e40000, size=0x1e00000
[NAND][BDM] Partition: 3, Bad Block Count: 0
[NAND]NAND_SDM_Mount: Partid=5, offset=0x3c40000, size=0x43c0000
[NAND][SDM] Partition: 5, Bad Block Count: 1
[NPTV]FlashPQ ID OK
[NPTV]Restore Flash SmartPic Successful
[NPTV]GAMMA SCRIPT=LC420WU_bHDMIState change from HDMI_STATE_NOTREADY to HDMI_STATE_INIT
_bHDMIState change from HDMI_STATE_INIT to HDMI_STATE_PWON
HDMI Analog PHY Reset ........
_bHDMIState change from HDMI_STATE_PWON to HDMI_STATE_PWON2
_bHDMIState change from HDMI_STATE_PWON2 to HDMI_STATE_SCDT
[PCMCIA]CI 5V Power On
ofst0=0x21b, ofst1=0xbcb, ofst2=0x112b, def=0x69
[NPTV]Verf PE Table Pread TunerType from EEPROM, addr0x21b=0x69, addr0xbcb=0x69, addr0x112b=0x69
Find corresponding tuner for registration. (total 2 tuners in pool)(TunerType=0x69)
Register DVBT Tunerall type = 105
Tuner TDTKG931D init done!
Read NAND Flash AQ Comm Data Success!
load cdnotch code sz 80 offset 143130 0xFA7A600
Image ROBase:0x00010af0 ROLimit:0x006f8480
Protect readonly by region 1: from 0x00000000 ~ 0x00000040.
MMU[CLI]SPI_DemodSingleRead timeout !
DTV>assed
Driver Logo Disabled!
OSD_SetTVEOut: 1
 osd flip en
 osd mirror en
DVBT_Initialize failed
PDNAME_CALL(PD_REMAP_TER_DIG,Open) fail
#### Enter Dummy mode ####
[NPTV]FlashPQ ID OK
[NPTV]QTY SCRIPT=LC420WUtotal: 5612, avail: 3450, free: 3450
[FM](/dev/flash_sunris[NPTV]Enable AdaptiveLuma
e_0) is mounted to (/mnt/sunr) successfully(0)
total: 9188, avail: 8282, free: 8282
[FM](/dev/nand_21_0) is mounted to (/mnt/demo) successfully(0)
total: 1014, avail: 802, free: 802
[FM](/dev/flash_fs_tp_0) is mounted to (/mnt/aud) successfully(0)
{CI_glue}:ci_eng_init
{CI_glue}- expect PROD key
## TunerOpenFailure ##
{CI}CI_RegInterrupt_nfy
{CI_glue}- c[1]
{DT} Real Time Clock is available on this system.
reason: 0x00000006 - 0x00000000
wakeup reason = 6
[ACFG_CU{CDB} Loading metadata (version 7)
[ACFG_CUacfg_custom_get_svl_tsl_dual_bank: MAIN
rm_op.c: ABORT    Line#:   3970  Code: 0x004900oot-
Byte 1 : DQS(3 ~ 40), Size 38, Set 19.
oot
Start Pmain
0x00004000
NID=0x9500f1ec
oot
Start Lmain
Version Code : 0x0
MUBoot reason: Watch dog0 reset (0x1000000)
!!-------------use external edid, disable internal edid------------------
Switch NAND pinmux
Detect SS K9F1G08U
No UBoot reason: Watch dog0 reset (0x1000000)
!![PDWNC]PDWNC_ReadWakeupReason = 0x1a
[MLVDS]TCLK_PCLK_RATION_NUTG on phase 3: 0xffff
!!---------- Panel[123] PANEL_MLVDSV5GIP60_LC420WUio=16, turn on value=1
Pixel Shift=0 (1920 x 1080)
LDR_OsdDisplay(13, 0x02d42470, 400, 100)
Color:13 BmpAddr:0x02d42470 Width:400 Height:100
OSD_SetTVEOut: 1
 osd flip en
 osd mirror en
Panel 1920 x 1080
NAND load lzhs header from SysImgA(part:1) to dram(0x2fe6a00), size=2048
NAND_BDM_Mount: Partid=1, offset=0x40000, size=0x1e00000
Decompression image to 0x00010000...
secure boot ok
Starting image...
Booting
Memory Reserved for MMUon done
[MU0, size=0x1e00000
[NPTV]FlashPQ ID OK
[NPTV]GAMMA SCRIPT=LC420WU[CLI]SPI_DemodSingleRead timeout !
DTV>assed
OSD_SetTVEOut: 1
 osd flip en
 osd mirror en
[NPTV]FlashPQ ID OK
[NPTV]QTY SCRIPT=LC420WUavail: 802, free: 802
{CI_glue}- c[1]
reason: 0x00000004 - 0x00000000
wakeup reason = 4
[ACFG_CUet form plf is 1
[ACFG_CUoot-
oot
Start Pmain
0x00004000
NID=0x9500f1ec
oot
Start Lmain
ШЕФ3
аЦкий открывун
07-05-2017 13:25
Krik99, И что хочешь гы-гы ? Расписывай все М/С в составе.
Krik99
07-05-2017 15:02
Проц под радиатором из схемы MT5366
NAND K9F1G08U0C
TDTK-G731D Tuner (DVB T/C, analogue)
MT5135AE DVB T/C demodulator
TMDS251PAGR HDMI Switch
TPA6132A2RTER Earphone R/L output
STA339BWTR Audio amplifier
MAX17113ET Multi DC/DC
MAX9668ETP GAMMA
TPS65192RHDR Level shifter
схема http://archive.espec.ws/files/PHILIPS%20chassis%20tpm6.1e.pdf
ШЕФ3
аЦкий открывун
07-05-2017 15:12
По HDMI\USB нет коротких?, DC/DC на майн в норме?
Krik99
07-05-2017 16:48
ШЕФ3 писал:
На HDMI\USB есть 5в. Замеры на DC/DC:
Panel_12v=12.18v
TCON_VCC=3.22v
VGL=5.0v
TCON_VDD=16.26v
VGH=28.0v
Остальные линейные стабы в норме. Забыл сказать, вроде как паялся тюнер до меня. Подкинуть нет такого, как проверить?
Если принудительно включить бп, то перезагрузка остаётся, только бп не вырубает.
ШЕФ3
аЦкий открывун
07-05-2017 18:27
Krik99, Есть чем шить Нанд?
Не написал питания Ядра, РАМ Нет
Krik99
08-05-2017 09:55
ШЕФ3 писал:
DVDD3V3=3.31v
VCCK=1.09v
DDRV=1.82v
Программатора нет. Есть идея, знаю что не профессионально но.. Есть usb флешка, так там нанд с такойже распиновкой только размер другой. Смогу ли я через такой "программатор" слить полный дамп? И следуюший вопрос, если на новом нанде не попасть на бэды то будет работать?
ШЕФ3
аЦкий открывун
08-05-2017 10:08
Поищи "Лоадырь" с флэшки для начала.
Список форумов» Телевизоры» ЖК (LCD)» PHILIPS 42PFL3606H/58 шасси TPM6.1ELA перезагрузка
  • Philips 42PFL3606H/60 (шасси: TPM6.1E LA) не включается
  • TV PHILIPS 42PFL3606H/60 шасси ch.TPM5.1E LA
  • Philips 42PFL3312/10 шасси LC7.1ELA шум трансформатора.
  • Philips 42PFL4606H/58 шасси TPM7.1ELA на экране CI Plus key.
  • Philips 42PFT6309/60 шасси: TPM14.1E LA перезагрузка
