Ôàéëû  •  Ññûëêè  •  Ïðîøèâêè  •  Ïðàâèëà  •  Àðõèâ  •   FAQ  •  Ó÷àñòíèêè  •  Ïîèñê
Ðåãèñòðàöèÿ  •  Âõîä
 Íàéòè ôàéë   Íîâûå ôàéëû
Ñïèñîê ôîðóìîâ» Ôàéëî-îáìåííèê» Ñõåìû» CD & DVD» Firmware for Mustek V 56 LM-2E
Îïèñàíèå ôàéëà:
  • mustek v56lm 2e fixed cyrillic subtitles
  • WARNING!!!
    THE FIRMWARE IS TESTED AND WORKS ONLY ON MUSTEK V 56LM-2E DVD PLAYER.
    USE THIS FIRMWARE AT YOUR OWN RISK. YOU CAN NOT HOLD ME RESPONSIBLE FOR ANY DAMAGES!!!
    ÏÐÅÄÓÏÐÅÆÄÅÍÈÅ!!!
    ÒÎÇÈ FIRMWARE Å ÈÇÏÐÎÁÂÀÍ È ÐÀÁÎÒÈ ÑÀÌÎ ÍÀ MUSTEK V 56LM-2E ÏËÅÉÚÐ.
    ÈÇÏÎËÇÂÀÉÒÅ ÃÎ ÍÀ ÑÎÁÑÒÂÅÍ ÐÈÑÊ. ÍÅ ÌÎÆÅ ÄÀ ÌÅ ÄÚÐÆÈÒÅ ÎÒÃÎÂÎÐÅÍ ÇÀ ÊÀÊÂÈÒÎ È ÄÀ Å ÅÂÅÍÒÓÀËÍÈ ÍÀÍÅÑÅÍÈ ÂÐÅÄÈ.
    The upgrade method for DVD player V56LM-2E.
    1) First, record the upgrade software(BANK30.ROM) in a NEW CD-R/RW disc: ISO 9600; MODE 1; Finalize.
    2) Please correctly connect DVD player to colour TV, then power on DVD player,open the CD tray,put the CD-R/RW disc on the CD tray,close the CD tray.Then the upgrade will be automatically finished.
    3) During upgrade the S/W, There at the top left corner of TV screen will ordinal display the following
    words:Flash,Bank 30.rom,Reading,Flash,Erase,Writing (Flash 3-5 times), Done.Then TV screen become dark.
    4) When TV screen has become dark and DVD player indication LED has become from green to
    red, This means the upgrade has finished.You may power off DVD player.
    THEN power on and take off the CD-R/RW disc to avoid new flashing.
    The total time of upgrade about 1 minute.
    Note: Don't power off DVD player during the upgrade process !!!
    Áúëãàðñêè åçèê:
    Ïðîöåäóðà çà úïãðåéä íà DVD pleyer V56LM-2E
    1) Çàïèøåòå íà íîâî CD-R/RW äèñê ñîôòóåðà çà úïãðåéä BANK30.ROM âúâ ôîðìàò ISO9600,MODE1,Finalize
    2) Ïîñòàâåòå CD-òî â DVD pleyer è èç÷àêàéòå àâòîìàòè÷íàòà ïðîöåäóðà äà ôèíèøèðà.
    3) Ïðîöåäóðàòà ñå èçïèñâà â ëåâèÿò ãîðåí úãúë íà åêðàíà ïîäðåä: Flash, Erase, Writing (Ìèãàùî 3-5 ïúòè), Done. Ñëåä òîâà åêðàíà íà òåëåâèçîðà ñòàâà ÷åðåí.
    4) Îñâåí åêðàíà ÷å å ÷åðåí ñâåòâà äèîäà íà çàõðàíâàíåòî íà DVD-òî â ÷åðâåíî, à íà äèñïëåÿò ìó ïèøå LOAD. Ñ òîâà ïðîöåäóðàòà å ïðåêëþ÷èëà. Èçêëþ÷âàòå DVD-to îò êîï÷åòî.
    Ïðè âêëþ÷âàíå âåäíàãà èçâàäåòå CD-òî ñ úïäåéòà, çàäà íå ïî÷íå íàíîâî ïðîöåäóðàòà çà úïãðåéä.
    ÂÍÈÌÀÍÈÅ!!: Íå èçêëþ÷âàéòå óñòðoéñòâîòî (DVD pleyer) äîêàòî òå÷å ïðîöåäóðàòà íà úïãðåéäà!!
    Çà äà èìà Ñóáòèòðè íà Áúëãàðñêè åçèê òðÿáâà OSD Menu äà å íà RUSSIAN (òîåñò íà Ðóñêè åçèê)
Ðàçìåð:868,95 KÁ
Çàêà÷àë: Schematic - Service - Manual
Äàòà:18-12-2006 16:56
Îáíîâëåíèå:Íåò
Ïîñëåäíåå ñêà÷èâàíèå:20-08-2008 13:11
Ñêà÷èâàíèé:122
Íåçàðåãåñòðèðîâàííûå ïîñåòèòåëè ìîãóò ñêà÷èâàòü òîëüêî ñ ñàéòà http://master-tv.com
Òåêóùèé ôàéë» Ñõåìû» CD & DVD» Firmware for Mustek V 56 LM-2E
Èíôîðìàöèÿ ïî ðåìîíòó äëÿ ñïåöèàëèñòîâ - ñïðàâî÷íèêè, èíñòðóêöèè, ýíöèêëîïåäèÿ, ñîâåòû è ñåêðåòû ðåìîíòà,  íàñòðîéêà, ñåðâèñíûå ðåæèìû
