| Описание файла: | Casio_EX-Z750_Firmware_Update_v1.02(en)- Заключительное обновление продукта Casio EX-Z750
- Digital Cameras [ EX-Z750 Firmware Update ] - CASIO WORLDWIDE
Dec.2005
EX-Z750 Firmware Update Software.....Version 1.02
Improvements Provided by This Update
V1.01-V1.02
•Adds old photo scene "Revive Shot" to snapshot BEST
SHOT scenes.
V1.00-V1.01
•Zooming of portrait orientation images (without
changing to landscape orientation).
Applicable Users
EXILIM owners whose camera is still running Version
1.00-1.01 firmware.
Important:
If firmware update installation is interrupted due to
low battery power, your camera will no longer be able to
operate. Be sure to load a fresh set of new batteries
into the camera before starting the firmware update
installation procedure. Note that you perform firmware
update at your own risk.
Attention users in Russia and the Ukraine
Updating the firmware of your camera to Version
1.02 will cause your camera to lose its ability
to display messages in Russian. After updating,
you will be able to display messages in the
following languages only: English, French,
German, Spanish, Italian, Portuguese, Japanese,
Chinese, or Korean. Update your firmware to
Version 1.02 only if you agree to lose Russian
display messages. Note also that there are no
plans to offer a Russian language version of
firmware update Version 1.02.
To check your firmware version
On your EX-Z750 camera, hold down the [MENU] button as
you press the [POWER ON/OFF] switch to turn on the
camera. Keep [MENU] depressed until the version of your
camera's firmware appears on the monitor screen.
1.If "Ver.1.00-1.01" appears, you need to download this
update software and install it on your camera.
2.If "Ver.1.02" appears, it means that your camera
already is running the latest firmware version, so you
do not need to install this update.
Requirements for Installing This Update on Your Camera
•To install this firmware update on your camera, you
must copy it into the root directory (the top directory
on the drive) of built-in camera memory or on a memory
card. Because of this, you need to have the USB cable
(that comes bundled with the camera) on hand or a card
slot available on your computer.
User License Agreement Covering Update Software Download
*In order to download and use the update software, you
must first read and agree to be bound by the terms and
conditions of the End User Software Licensing Agreement
(Agreement) below.
*If, after carefully reading the Agreement, you agree to
be bound by its terms and conditions, click the [I
agree] button to advance to the download procedure.
*Regardless of whether or not you actually do agree, by
downloading this update software, you indicate your
agreement to be bound the terms and conditions of the
Agreement and establish a contractual agreement between
you and CASIO COMPUTER CO., LTD. (CASIO).
*If you do not agree with the terms and conditions of
the Agreement, click [I do not agree] and do not
download the update software.
1License
CASIO, as the owner of this Software and other
intellectual asset rights, grants you the
following non-exclusive, non-transferrable,
copyright license subject to the terms of this
Agreement.
1)You may install and use this Software on your
CASIO EX-Z750 Digital Camera.
2)You may make one copy of this Software on a
memory card for the purpose of installing the
software on your EX-Z750 Digital Camera.
2Prohibitions
1)Except as permitted by this Agreement, you may
not copy this Software either in part or its
entirety.
2)You may not modify, alter, adapt, reverse
engineer, disassemble, decompile or otherwise
attempt to derive the source code of the Software.
3)You may not resell, rend, lease, loan, or
distribute this Software, or place the Software on
a server or make it accessible by means of a
network.
4)You may not sublicense or transfer this Software
to a third party.
5)You may not use this Software for any unlawful
purpose, or in any manner inconsistent with this
Agreement.
3Period of Agreement
1)This Agreement becomes binding as soon as you
download the Software.
2)This Agreement becomes null and void when you
destroy all of your copies of this Software.
3)CASIO may terminate this license at any time if
you are in breach of the terms of this Agreement.
Upon termination, you will immediately destroy the
4Limitation of Liability
1)This Software is provided "as is," and CASIO
makes no express warranty concerning the
Software's ability to operate properly or to be
free of defects, or concerning the correction of
defects in the future, or the suitability of the
Software functions for any particular purpose.
2)In no event shall CASIO be liable for any
damages whatsoever (including, without limitation,
damages for loss of profits, business
interruption, loss of information) arising out of
the use of or inability to use this software, even
if CASIO has been adviced of the possibility of
such damages.
5Other
1)Items not covered by the Agreement or items that
require further negotiation shall be settled by
mutual agreement between you and CASIO.
2)Any claim arising under or relating to this
Agreement shall be governed by the laws of Japan.
3)Any dispute arising under or relating to this
Agreement shall come under the jurisdiction of the
Tokyo District Court.
| Закачал: |
Schematic - Service - Manual
