at45db081d как поменять страницу с 256 на 264
senvi
16-08-2014 06:12
причем 256-заводская устанановка
pelesha
16-08-2014 11:08
senvi, мало информации даешь;где стоит? каким программатором пользуешся?
andreieinav
18-08-2014 10:00
Write Protect: When the WP pin is asserted, all sectors specified for protection by the Sector
Protection Register will be protected against program and erase operations regardless of
whether the Enable Sector Protection command has been issued or not. The WP pin functions
independently of the software controlled protection method. After the WP pin goes low, the
content of the Sector Protection Register cannot be modified.
If a program or erase command is issued to the device while the WP pin is asserted, the device
will simply ignore the command and perform no operation. The device will return to the idle state
once the CS pin has been deasserted. The Enable Sector Protection command and Sector
Lockdown command, however, will be recognized by the device when the WP pin is asserted.
The WP pin is internally pulled-high and may be left floating if hardware controlled protection will
not be used. However, it is recommended that the WP pin also be externally connected to VCC
whenever possible.
Low Input
Как-то так!
Крутой!
Список форумов» Промышленная электроника» at45db081d как поменять страницу с 256 на 264
  • Панель оператора Siemens OP77B.Как поменять системное время?
