Koka2 Предупреждений: 1 Сообщения: 130
Подскажите по параметрам адсл линии, нормальная линия или не очень:
| Код: | noise margin upstream: 11 db
output power downstream: -2 db
attenuation upstream: 8 db
tone 0- 31: 00 00 00 06 88 aa bb bb cc cc bb bb aa 98 77 64
tone 32- 63: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 64- 95: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 96-127: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 128-159: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 160-191: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 192-223: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 224-255: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 256-287: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 288-319: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 320-351: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 352-383: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 384-415: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 416-447: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 448-479: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 480-511: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
noise margin downstream: 24 db
output power upstream: 12 db
attenuation downstream: 11 db
tone 0- 31: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 32- 63: 00 00 00 00 00 12 22 22 22 52 66 66 56 66 67 66
tone 64- 95: 77 77 77 72 76 66 66 66 66 66 65 52 22 22 62 26
tone 96-127: 66 42 25 25 21 52 52 26 66 62 65 66 62 66 66 62
tone 128-159: 62 26 62 62 66 62 56 25 62 26 52 45 56 25 22 22
tone 160-191: 66 66 22 22 55 55 55 24 22 22 22 22 22 22 22 22
tone 192-223: 24 22 24 25 55 22 22 22 52 52 22 25 52 25 52 55
tone 224-255: 55 50 55 55 52 22 22 22 22 22 02 21 11 11 11 11
tone 256-287: 11 11 11 01 01 11 11 11 11 11 11 11 11 11 11 12
tone 288-319: 21 22 12 22 22 22 22 22 22 22 22 22 22 22 22 22
tone 320-351: 22 22 22 22 22 25 52 52 54 22 52 52 22 22 55 55
tone 352-383: 25 52 22 26 55 56 56 66 66 66 66 65 66 66 66 66
tone 384-415: 66 66 66 66 66 66 66 66 66 66 62 62 62 26 22 65
tone 416-447: 22 52 52 25 22 25 22 55 22 22 22 22 22 52 52 25
tone 448-479: 22 22 22 22 25 22 22 22 22 24 22 22 22 22 22 22
tone 480-511: 22 22 22 22 22 22 22 22 11 11 11 11 00 00 00 00 |
сейчас скорость 3-4 мб. |
Scorpio2007 Участник Сообщения: 686
| Koka2 писал: | Подскажите по параметрам адсл линии, нормальная линия или не очень:
сейчас скорость 3-4 мб. | Судя по
| Цитата: | Затухание сигнала (Line Attenuation):
до 20 dB — отличная линия
от 20 dB до 40 dB — рабочая линия
от 40 dB до 50 dB — рабочая линия
от 50 dB до 60 dB — рабочая линия пропадает синхронизация
от 60 dB и выше — работа оборудования невозможна
Отношение сигнал/шум (Signal-to-Noise Ratio (SNR)):
6dB и ниже — плохая линия, присутствуют проблемы синхронизации;
7dB-10dB — возможны сбои;)))
11dB-20dB — хорошая линия, без проблем с синхронизацией;
20dB-28dB — очень хорошая линия;
29dB и выше — отличная линия.))) | линия на 4+. Скорость "3-4мб" - это где? Дай точные цифры downstream/upstream из модема! Судя по исходным данным должно быть не меньше чего-то вроде 6144/640 Кбит/сек. Если downstream будет меньше 4096, то, вероятно, со стороны провайдера залочена скорость на DSLAM (в местном УЭС такое широко практиковалось, чтобы меньше валили халявными торрентами дохлый внешний канал). |
| Koka2 писал: | | DSL 4926 kbps / 769 kbps | ИМХО, downstream маловат, тем более - относительно upstream`а. Соотношение 6,4:1, а обычно оно порядка 8:1 бывает. Конденсаторов вздутых в модеме нет случайно?
Типовые причины низкой скорости связи: залочка порта провайдером (это без знакомых внутри конторы не вылечить); наличие промокающих скруток где-то на магистральных кабелях, либо линия к дому из "полёвки", а не витой пары (лечится заваливанием провайдера жалобами на плохое качество связи и плохое состояние кабельной линии - раньше меняли оперативно на витуху, сейчас не в курсе); проблемы с разделкой кабеля в розетках в доме (наличие параллельных телефонов ДО сплиттера, отсутствие сплиттера, полёвка, зажатая в клеммах вместе со стальными жилками и т.п.). |
На АТС порт залочен, звонок в техподдержку. Теперь как положено 15 мБ. Спасибо за помощь. |
kripton радио активный Сообщения: 1553
Не сказал, какой тарифный план. Может тебе больше не положено. |
| kripton писал: | | Не сказал, какой тарифный план. Может тебе больше не положено. | Обычно тарифный план ограничивает скорость только за пределы региона или даже макрорегиона (федерального округа). Т.к. шейперы стоят в областных центрах (по крайней мере, у нас в ПФО так). Соответственно, внутри региона скорость ограничена только физическими возможностями оборудования и линии. |
Scorpio2007, Неа. На порту DSLAMa выставляется скорость ADSL линии. Будет зависеть от тарифного плана.
Если у тебя по тарифу 8 Мбит, зачем линию поднимать на 22 Мбит? достаточно 10. |
kripton, может в Сибири так, из-за проблем с магистралями и низкой конкуренцией, а в Волга-телекоме (т.е. по всему ПФО) так, как я описал. И это даже прописано было в условиях тарифного плана (скорость внутри макрорегиона ограничена только возможностями линии и абонентского модема). Конкуренция заставила. И всё равно бегут у нас клиенты из РТ к конкурентам, у которых и быстрее и дешевле.
ЗЫ: я сам несколько лет (пока не ушёл к конкурентам на оптику) платил за 2 Мбит/сек, а реально у меня линк 8 Мбит/сек (больше не позволяло расстояние и качество линии) был почти всегда забит торрентами под завязку (в клиенте ограничивал скорость глобально на 6Мбит и он не мешал веб-серфингу). |
